This article lists the SCCM Technical Preview build numbers, version numbers, new features, and release dates. Microsoft adds new features to each version of Configuration Manager’s technical preview builds. This is an insight into what’s coming up in the next release of SCCM’s current branch.
There have been many TP releases so far, and in this article we will attempt to keep track of the release history for technical preview builds. Setting up a technical preview in your lab is easy, and you can test out new features before they get added to the upcoming current branch release.
When a new technical preview release is installed, Configuration Manager updates the build number, the version of the console, and the version of the clients. You must always update the client agents to the latest version after installing the latest SCCM technical preview build.
Release Cadence for ConfigMgr Technical Preview
As per the latest SCCM release cadence, there will be four ConfigMgr Technical Preview (TP) releases per year. Two versions will be released before each production SCCM current branch release, and one of the technical preview releases will be a baseline release. (TP baseline is a 180-day evaluation.)
Technical Preview Evaluation
Microsoft allows you to try the SCCM Technical Preview builds for 360 days. The users can test it on their lab setup and provide feedback. To use the technical preview, you must first install a SCCM baseline version of the technical preview build. After you install the technical preview baseline version, use the in-console updates to get the most recent one.
If the ConfigMgr TP version isn’t updated for over 360 days, the TP version will expire. The technical preview lab must be rebuilt if the version has expired.
Note: The SCCM Configuration Manager Technical Preview versions must be tested only in a lab environment. Microsoft will not provide support for SCCM technical preview versions. Therefore, before making any changes, backup your SCCM site.
Download latest version of SCCM Technical Preview
To obtain the latest technical preview build, visit the Microsoft Evaluation Center. You will need to complete a form with your name, organization, country, phone number, and other pertinent information. Once you do that, you will get a download link for the latest technical preview version. Click on the download link to get the Technical Preview zip file and extract it to a folder to get the setup file.
SCCM Technical Preview Build Numbers and Version Numbers
The below table lists the SCCM Technical Preview build and version numbers, along with release dates. The hyperlink points to the new features introduced in each technical preview release. This table will be updated as and when the new versions of technical previews are released.
| Technical Preview version | Technical Preview Build | New Features | Release Date |
| SCCM Technical Preview 2411 | 5.0.9133.1000 | Link | November 28, 2024 |
| SCCM 2405 Technical Preview | 5.0.9129.1000 | Link | June 6, 2024 |
| SCCM 2401 Technical Preview | 5.0.9124.1000 | Link | January 26, 2024 |
| SCCM 2311 Technical Preview | 5.0.9123.1000 | Link | November 28, 2023 |
| SCCM 2307 Technical Preview | 5.0.9113.1000 | Link | July 28, 2023 |
| SCCM 2305 Technical Preview | 5.0.9111.1000 | Link | May 26, 2023 |
| SCCM 2303 Technical Preview | 5.0.9110.1000 | Link | March 19, 2023 |
| SCCM 2302 Technical Preview | 5.0.9102.1000 | Link | February 24, 2023 |
| SCCM 2301 Technical Preview | 5.0.9100.1000 | Link | December 1, 2022 |
| SCCM 2212 Technical Preview | NA | Version Skipped | NA |
| SCCM 2211 Technical Preview | 5.0.9098.1000 | Link | 2022-11-30 |
| SCCM 2210 Technical Preview | 5.0.9091.1010 | Link | 2022-10-19 |
| SCCM 2209 Technical Preview | 5.0.9090.1000 | Link | 2022-09-23 |
| SCCM 2208 Technical Preview | 5.0.9089.1000 | Link | 2022-08-30 |
| SCCM 2207 Technical Preview | 5.0.9085.1000 | Link | 2022-07-05 |
| SCCM Technical Preview 2206 | 5.0.9084.1000 | Link | 2022-06-16 |
| SCCM Technical Preview (Version 2205) | 5.0.9083.1000 | Link | 2022-05-22 |
| SCCM Technical Preview (Version 2204) | 5.0.9081.1000 | Link | 2022-04-28 |
| SCCM Technical Preview (Version 2203) | 5.0.9075.1000 | Link | 2022-03-01 |
| SCCM Technical Preview (Version 2202) | 5.0.9072.1000 | Link | 2022-02-18 |
| SCCM Technical Preview (Version 2201) | 5.0.9071.1000 | Link | 2022-01-28 |
| SCCM Technical Preview (Version 2112) | 5.0.9070.1000 | Link | 2021-12-11 |
| SCCM Technical Preview (Version 2111) | 5.0.9064.1000 | Link | 2021-11-02 |
| SCCM Technical Preview (Version 2110) | 5.0.9062.1000 | Link | 2021-10-09 |
| SCCM Technical Preview (Version 2109) | 5.0.9061.1000 | Link | 2021-09-28 |
| SCCM Technical Preview (Version 2108) | 5.0.9060.1000 | Link | 2021-08-31 |
| SCCM Technical Preview (Version 2107) | 5.0.9059.1000 | Link | 2021-07-29 |
| SCCM Technical Preview (Version 2106) | 5.0.9056.1000 | Link | 2021-06-24 |
| SCCM Technical Preview (Version 2105.2) | 5.09052.1000 | Link | 2021-06-01 |
| SCCM Technical Preview (Version 2105) | 5.0.9051.1000 | Link | 2021-05-12 |
| SCCM Technical Preview (Version 2104) | 5.0.9050.1000 | Link | 2021-04-21 |
| SCCM Technical Preview (Version 2103) | 5.0.9047.1000 | Link | 2021-03-03 |
| SCCM Technical Preview (Version 2102) | 5.0.9045.1000 | Link | 2021-02-23 |
| SCCM Technical Preview (Version 2101) | 5.0.9044.1000 | Link | 2021-01-29 |
| SCCM Technical Preview (Version 2012) | 5.0.9043.1000 | Link | 2020-12-14 |
| SCCM Technical Preview (Version 2011) | 5.0.9042.1000 | Link | 2020-11-25 |
| SCCM Technical Preview (Version 2010.2) | 5.0.9039.1000 | Link | 2020-10-31 |
| SCCM Technical Preview (Version 2010) | 5.0.9032.1000 | Link | 2020-09-30 |
| SCCM Technical Preview (Version 2009) | 5.0.9030.1000 | Link | 2020-09-11 |
| SCCM Technical Preview (Version 2008) | 5.0.9028.1000 | Link | 2020-08-07 |
| SCCM Technical Preview (Version 2007) | 5.0.9026.1000 | Link | 2020-07-14 |
| SCCM Technical Preview (Version 2006) | 5.0.9024.1000 | Link | 2020-06-28 |
| SCCM Technical Preview (Version 2005) | 5.0.9023.1000 | Link | 2020-05-29 |
| SCCM Technical Preview (Version 2004) | 5.0.8991.1000 | Link | 2020-04-30 |
| SCCM Technical Preview (Version 2003) | 5.0.8974.1000 | Link | 2020-03-31 |
| SCCM Technical Preview (Version 2002.2) | 5.0.8961.1000 | Link | 2020-02-29 |
| SCCM Technical Preview (Version 2002) | 5.0.8953.1000 | Link | 2020-02-15 |
| SCCM Technical Preview (Version 2001.2) | 5.0.8946.1000 | Link | 2020-02-03 |
| SCCM Technical Preview (Version 2001) | 5.0.8938.1000 | Link | 2020-01-22 |
| SCCM Technical Preview (Version 1912) | 5.0.8923.1000 | Link | 2019-12-13 |
| SCCM Technical Preview (Version 1911) | 5.0.8909.1000 | Link | 2019-11-06 |
| SCCM Technical Preview (Version 1910) | 5.0.8899.1000 | Link | 2019-10-22 |
| SCCM Technical Preview (Version 1909) | 5.0.8884.1000 | Link | 2019-09-27 |
| SCCM Technical Preview (Version 1908.2) | 5.0.8871.1000 | Link | 2019-08-30 |
| SCCM Technical Preview (Version 1908) | 5.0.8860.1000 | Link | 2019-08-07 |
| SCCM Technical Preview (Version 1907) | 5.0.8855.1000 | Link | 2019-07-12 |
| SCCM Technical Preview (Version 1906) | 5.0.8842.1000 | Link | 2019-06-13 |
| SCCM Technical Preview (Version 1905) | 5.0.8827.1000 | Link | 2019-05-20 |
| SCCM Technical Preview (Version 1904) | 5.0.8817.1000 | Link | 2019-04-29 |
| SCCM Technical Preview (Version 1903) | 5.0.8800.1000 | Link | 2019-04-03 |
| SCCM Technical Preview (Version 1902.2) | 5.0.8787.1000 | Link | 2019-02-19 |
| SCCM Technical Preview (Version 1902) | 5.0.8782.1000 | Link | 2019-02-08 |
| SCCM Technical Preview (Version 1901) | 5.0.8772.1000 | Link | 2019-01-23 |
| SCCM Technical Preview (Version 1812) | 5.0.8756.1000 | Link | 2018-12-14 |
| SCCM Technical Preview (Version 1811) | 5.0.8748.1000 | Link | 2018-12-03 |
| SCCM Technical Preview (Version 1810.2) | 5.0.8735.1000 | Link | 2018-10-16 |
| SCCM Technical Preview (Version 1810) | 5.0.8729.1000 | Link | 2018-10-01 |
| SCCM Technical Preview (Version 1809) | 5.0.8717.1000 | Link | 2018-09-12 |
| SCCM Technical Preview (Version 1808) | 5.0.8707.1000 | Link | 2018-08-17 |
| SCCM Technical Preview (Version 1807) | 5.0.8700.1000 | Link | 2018-07-30 |
| SCCM Technical Preview (Version 1806.2) | 5.0.8685.1000 | Link | 2018-06-27 |
| SCCM Technical Preview (Version 1806) | 5.0.8672.1000 | Link | 2018-06-04 |
| SCCM Technical Preview (Version 1805) | 5.0.8659.1000 | Link | 2018-05-11 |
| SCCM Technical Preview (Version 1804) | 5.0.8648.1000 | Link | 2018-04-24 |
| SCCM Technical Preview (Version 1803) | 5.0.8636.1000 | Link | 2018-03-27 |
| SCCM Technical Preview (Version 1802) | 5.0.8627.1000 | Link | 2018-02-09 |
| SCCM Technical Preview (Version 1801) | 5.0.8611.1000 | Link | 2018-01-22 |
| SCCM Technical Preview (Version 1712) | 5.0.8595.1000 | Link | 2017-12-16 |
| SCCM Technical Preview (Version 1711) | 5.0.8582.1000 | Link | 2017-11-17 |
| SCCM Technical Preview (Version 1710) | 5.0.8570.1000 | Link | 2017-10-30 |
| SCCM Technical Preview (Version 1709) | 5.0.8559.1000 | Link | 2017-09-28 |
| SCCM Technical Preview (Version 1708) | 5.0.8549.1000 | Link | 2017-08-26 |
| SCCM Technical Preview (Version 1707) | 5.0.8542.1000 | Link | 2017-07-28 |
| SCCM Technical Preview (Version 1706) | 5.0.8533.1000 | Link | 2017-06-25 |
| SCCM Technical Preview (Version 1705) | 5.0.8525.1000 | Link | 2017-06-03 |
| SCCM Technical Preview (Version 1704) | 5.0.8514.1000 | Link | 2017-04-21 |
| SCCM Technical Preview (Version 1703) | 5.0.8506.1000 | Link | 2017-03-31 |
| SCCM Technical Preview (Version 1702) | 5.0.8496.1000 | Link | 2017-02-24 |
| SCCM Technical Preview (Version 1701) | 5.0.8482.1000 | Link | 2017-01-21 |
| SCCM Technical Preview (Version 1612) | 5.0.8471.1000 | Link | 2016-12-16 |
| SCCM Technical Preview (Version 1611) | 5.0.8465.1000 | Link | 2016-11-23 |
| SCCM Technical Preview (Version 1610) | 5.0.8455.1000 | Link | 2016-10-23 |
| SCCM Technical Preview (Version 1609) | 5.0.8455.1000 | Link | 2016-09-27 |
| SCCM Technical Preview (Version 1608) | 5.0.8433.1000 | Link | 2016-08-22 |
| SCCM Technical Preview (Version 1607) | 5.0.8426.1000 | Link | 2016-07-29 |
| SCCM Technical Preview (Version 1606) | 5.0.8410.1000 | Link | 2016-06-21 |
| SCCM Technical Preview (Version 1605) | 5.0.8396.1000 | Link | 2016-05-16 |
| SCCM Technical Preview (Version 1604) | 5.0.8385.1000 | Link | 2016-04-21 |
| SCCM Technical Preview (Version 1603) | 5.0.8372.1000 | Link | 2016-03-17 |
| SCCM Technical Preview (Version 1602) | 5.0.8360.1000 | Link | 2016-02-17 |
| SCCM Technical Preview (Version 1601) | 5.0.8347.1000 | Link | 2016-01-21 |
| SCCM Technical Preview (Version 1512) | 5.0.8336.1000 | Link | 2015-12-18 |
| SCCM Technical Preview (Version 1511) | 5.0.8325.1000 | Link | 2015-11-12 |
| SCCM Technical Preview (Version 1510) | 5.0.8315.1000 | Link | 2015-10-14 |
| SCCM Technical Preview (Version 1509) | 5.0.8299.1000 | Link | 2015-09-22 |
| SCCM Technical Preview 3 | 5.0.8287.1000 | Link | 2015-08-19 |
| SCCM Technical Preview 2 | 5.0.8271.1000 | Link | 2015-06-09 |
| SCCM Technical Preview | 5.0.8239.1000 | Link | 2015-05-04 |
How do we know which is the base version and which is the update of the base version?
If I am not wrong in understanding, is 1902 the base version and 1902.2 the update of the base version, please confirm.
Really Good Link About all Versions Features..
Thank you.
