List of SCCM Versions Build Numbers Site Console Client
This article lists all the SCCM versions, SCCM build numbers, SCCM console version numbers, and SCCM site and client version numbers. The latest SCCM (aka ConfigMgr) build numbers and version numbers are updated with every new release.
There are three SCCM versions released every year. The year and month format is used for the version name of SCCM/Configuration Manager. For instance, ConfigMgr/SCCM 2211 was made available on December 6, 2022.
This article also lists the SCCM console version numbers for every ConfigMgr release and the steps to find the SCCM console version. Microsoft releases three current branch versions every year and around 12–13 technical preview versions. The versions of the current branch are meant to be used in production, while the versions of the technical preview should be set up in a lab.
You can find details of all the SCCM technical preview releases and their build numbers are listed in the following guide – https://www.prajwaldesai.com/sccm-technical-preview-build-version-numbers/.
Every Configuration Manager current branch release has a unique build number, version number, console version number and full version number associated with it. In addition, every major SCCM version also updates the client agent version. The hotfix update, if includes client agent fixes, will also update client agent version number.
Table of Contents
What is SCCM Version Number?
When you install a new SCCM version or update SCCM to the latest build, the version is a number associated with SCCM. For example, if you upgrade from SCCM 2107 to SCCM 2111, the version number of your SCCM is 2111.
Use the following steps to find the SCCM version number:
- Launch the ConfigMgr Console.
- Click About > Configuration Manager.
- On About Microsoft Configuration Manager window, you can find the Version Number.
What is SCCM Full Version Number
The SCCM full version number includes the build number, major version, minor version, and revision number. To explain the SCCM full version number, let’s consider the SCCM 2207 release as an example. You can understand what the full version number means by looking at the table below.
SCCM Full Version Number | Major Version | Minor Version | Build Number | Revision |
SCCM 2207 5.0.9088.1000 | 5 | 00 | 9088 | 1000 |
The SCCM build number is unique for every release and gets updated with every major release. The build number won’t change even though hotfixes are released for a specific ConfigMgr version.
Find SCCM Full Version from Registry
Along with SCCM build numbers, you can find SCCM full version details in the registry. On the SCCM server, open the Registry Editor and browse to the following path: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\SMS\Setup
Look for the value name “Full Version,” and that shows the SCCM full version number. For example, in the below screenshot, the full version of SCCM 2107 is 5.00.9058.1000. Do not modify any of those registry values, as they may interfere with Configuration Manager’s operation.
How to find SCCM Build Number?
There are multiple methods to find the SCCM build number. To find out the build number of SCCM, you can either look at the registry or the properties of the site server. You can quickly get the build number of ConfigMgr by going to the site server’s properties.
Use Registry to Find the Build Number
To find the SCCM build number using the registry, launch the registry editor. Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\SMS\Setup
and look for the UI Version. The “UI Version” registry value represents the build number of the current SCCM version.
Find the SCCM Build Number from Site Server Properties
You can also find the SCCM build number in the site properties. In the Configuration Manager console, go to Administration > Overview > Site Configuration > Sites. Right-click the SCCM site and select Properties. On the General tab, you can find the build number of Configuration Manager.
How to Check SCCM Console Version Number?
Let’s find out the version of the SCCM console by following the below steps:
- Launch the SCCM Console.
- Click on the dropdown arrow near the Home button.
- Select “About Configuration Manager“.
- The popup window shows the SCCM Console version along with the site version.
Read: How to Install SCCM Console on Windows 11
How to find the SCCM Client Version number?
Use the below steps to check the Configuration Manager client version number.
- On the computer, go to Control Panel and find “Configuration Manager” applet.
- Launch the Configuration Manager applet.
- Under Configuration Manager properties, select the General tab.
- In the General Tab, you will find the full SCCM client version number.
List of SCCM Versions and SCCM Build Numbers
The following table lists the following details about the latest ConfigMgr current branch release:
- SCCM Versions
- SCCM full version numbers
- SCCM build numbers
- SCCM client version numbers
- SCCM console version numbers
- SCCM baseline version
SCCM Version | SCCM Full Version Numbers | SCCM Build Numbers | SCCM Client Version Numbers | SCCM Console Version Numbers | SCCM Baseline Version |
SCCM 2303 | YES | ||||
SCCM 2211 Hotfix KB16643863 | 5.0.9096.1000 | 9096 | 5.00.9096.1024 | 5.2211.1061.1300 | NO |
SCCM 2211 | 5.0.9096.1000 | 9096 | 5.0.9096.1000 | 5.2211.1061.1000 | NO |
SCCM 2207 hotfix KB15152495 | 5.0.9088.1025 | 9088 | 5.0.9088.1025 | 5.2207.1048.2600 | NO |
ConfigMgr 2207 Hotfix KB15599094 | 5.0.9088.1013 | 9088 | 5.00.9088.1007 | 5.2207.1048.1700 | NO |
SCCM 2207 Hotfix KB15498768 | 5.0.9088.1012 | 9088 | 5.00.9088.1007 | 5.2207.1048.1700 | NO |
SCCM 2207 Hotfix KB14978429 | 5.0.9088.1000 | 9088 | 5.00.9088.1007 | 5.2207.1048.1700 | NO |
SCCM 2207 Hotfix KB14959905 | 5.0.9088.1010 | 9088 | 5.0.9088.1010 | 5.2207.1048.1700 | NO |
SCCM 2207 | 5.0.9088.1000 | 9088 | 5.00.9088.1007 | 5.2207.1048.1700 | NO |
SCCM 2203 Hotfix KB14244456 | 5.00.9078.1025 | 9078 | 5.00.9078.1025 | 5.2203.1063.2400 | NO |
SCCM 2203 Hotfix KB14480034 | 5.00.9078.1007 | 9078 | 5.00.9078.1006 | 5.2203.1063.1500 | NO |
SCCM 2203 Hotfix KB13953025 | 5.00.9078.1007 | 9078 | 5.00.9078.1006 | 5.2203.1063.1500 | NO |
SCCM 2203 | 5.00.9078.1000 | 9078 | 5.00.9078.1006 | 5.2203.1063.1400 | YES |
SCCM 2111 Hotfix KB12896009 | 5.00.9068.1000 | 9068 | 5.00.9068.1026 | 5.2111.1052.2500 | NO |
SCCM 2111 Hotfix KB12959506 | 5.00.9068.1000 | 9068 | 5.00.9068.1012 | 5.2111.1052.1700 | NO |
SCCM 2111 Hotfix KB12709700 | 5.00.9068.1000 | 9068 | 5.00.9068.1008 | 5.2111.1052.1700 | NO |
SCCM 2111 | 5.00.9068.1000 | 9068 | 5.00.9068.1005 | 5.2111.1052.1700 | NO |
SCCM 2107 | 5.00.9058.1000 | 9058 | 5.00.9058.1012 | 5.2107.1059.2000 | NO |
SCCM 2103 | 5.00.9049.1000 | 9049 | 5.00.9049.1008 | 5.2103.1059.1700 | YES |
SCCM 2010 | 5.00.9040.1000 | 9040 | 5.00.9040.1010 | 5.2010.1093.1800 | NO |
SCCM 2006 | 5.00.9012.1000 | 9012 | 5.00.9012.1015 | 5.2006.1026.1800 | NO |
SCCM 2002 | 5.00.8968.1000 | 8968 | 5.00.8968.1021 | 5.2002.1083.1700 | YES |
SCCM 1910 | 5.00.8913.1000 | 8913 | 5.00.8913.1000 | 5.1910.1067.2100 | NO |
SCCM 1906 | 5.00.8853.1000 | 8853 | 5.00.8853.1006 | 5.1906.1096.1500 | NO |
SCCM 1902 | 5.00.8790.1000 | 8790 | 5.00.8790.1005 | 5.1902.1085.1500 | YES |
SCCM 1810 | 5.00.8740.1000 | 8740 | 5.00.8740.1003 | 5.1810.1075.1300 | NO |
SCCM 1806 | 5.00.8692.1000 | 8692 | 5.00.8692.1003 | 5.1806.1074.1200 | NO |
SCCM 1802 | 5.00.8634.1000 | 8634 | YES | ||
SCCM 1710 | 5.00.8577.1000 | 8577 | NO | ||
SCCM 1706 | 5.00.8540.1000 | 8540 | NO | ||
SCCM 1702 | 5.00.8498.1000 | 8498 | YES | ||
SCCM 1610 | 5.00.8458.1000 | 8498 | NO | ||
SCCM 1606 | 5.00.8412.1000 | 8412 | YES | ||
SCCM 1602 | 5.00.8355.1000 | 8355 | NO | ||
SCCM 1511 | 5.00.8325.1000 | 8325 | YES |
Is it correct that the SCCM 2207 has exactly the same build as the SCCM 2207 Hotfix KB14978429?
The patch between has a different build SCCM 2207 Hotfix KB14959905.
So the patch level goes up and then again down.
I can’t validate it but is seems wrong to me.
Best Regards,
Alex
Hi Prajwal, Which version of SCCM is compatible with Intune for a hybrid environment?
Hi Prajwal, thank you so much for your guides.
The SCCM client 5.00.9088.1007 works with Windows 7?
Thank you
Please Share step by step upgrade Version from 2010 to Latest Version without any issue or Impacts current setup.
We must be about due a 2102 release. Anyone know when it’s due? Just thinking ahead to ensure support of 21H1 once that’s released.
The ConfigMgr 2103 is the next release and it will be released soon. I mean very soon.
Thanks Prajwal!
My organisation are currently using console version 1802 and we are planning to upgrade it to higher version (stable one) . What is the version we should upgrade to ?
Please give your expert advise.
It will be a two step upgrade. You can install SCCM 1906 update on sites that run version SCCM 1802, SCCM 1806, SCCM 1810, or SCCM 1902. You can begin upgrading to Configuration Manager 2010 on sites that run version SCCM 1906, SCCM 1910, SCCM 2002 or ConfigMgr 2006.
1. Upgrade your Configuration Manager version 1810 to version 1906 first – https://www.prajwaldesai.com/sccm-1906-step-by-step-upgrade-guide/
2. Upgrade SCCM 1906 to SCCM 2010 – https://www.prajwaldesai.com/sccm-2010-upgrade-guide/
For my organization that runs on 1902, would the process be the same?
Hi Prajwal, Thanks for all the work that you do!
What is the best way to know when a new Config Manager version is released? My boss is adamant that we have the latest version as soon as it is available. Is there any kind of email or notification service I can sign up for that you know of?
Thanks!!
Andy
Microsoft publishes the information about the new update as when it gets released. Over Twitter you get some news about upcoming update. Apart from that I try my best to publish the new update information on my blog. You should also get a console notification about the new update available.
Thank you, Sir!
Hey Prajwal,
Awesome content!
Hi there,
Please help me, I want to upgrade SCCM Current Branch 1902 to the latest.
How can I help you ?.
After a much heated discussion, I believe my organization is moving towards SCCM. My questions are as follows:
-SCCM 2012 is being taught yet the exam has been retired-what version should I train for?
-Microsoft has integrated SCCM into Endpoint Configuration manager-what version should we be looking at for installation on Windows server 2008 R2 or Server 2012 R2?..or are we purchasing MS Endpoint Configuration Manager 2019?
Thank you for your responses.
SCCM 2012 is an expired product and you won’t be getting any updates for it. You should go with Configuration Manager current branch (latest version) if you decide to implement it across the estate. I will find out more info about exam and will update the answer.
The windows server should be atleast Windows 2012 R2 and above. I always prefer to use the latest and stable version Of Windows server. You can also check the system OS requirements for specific version of Current Branch and go with that info.
Thanks for the info. I wonder is there any absolute dates for (production versions)
I mean, there is tech preview versions 1908, 1909,1910 etc. But is it clear for new production version will be (lets say) 1911.
Is there any standard ?
There are no absolute dates for production versions. Usually they are released for fast ring customers first and then made globally available.
I am having issues with updating to 1802. Its been about a month and my SCCM server is still downloading 1802. Plz help.
Don’t forget the 1802 Hotfix (KB4132447) version too?
5.00.8634.1011
Yes that is updated now.
