This comprehensive SCCM 2503 upgrade guide provides detailed instructions for updating your existing servers to version 2503, along with steps for upgrading the console and client components.
Configuration Manager 2503 is the first current branch release of the year 2025. As per the release cadence, Microsoft is committed to releasing two current branch versions every year. The next version of SCCM will be 2509, which will be released in October 2025 (tentative).
The version 2503 update is only applicable to sites running version 2309 or later. If you’re running version 2409 in your setup, you can directly upgrade to version 2503 without any issues.
SCCM 2503 Release Date
Talking about the general availability of this release, as of April 23, 2025, version 2503 is globally available for all customers to install. The support for SCCM 2503 ends on September 30, 2026.
The 2503 version of SCCM is NOT a baseline version. When installing a new site, you can download and use the 2403 baseline media.
New Features in SCCM 2503 Release
As part of Microsoft’s Secure Future Initiative (SFI) the 2503 version of Configuration Manager focuses only on security and quality updates. Over 230+ reported bugs are resolved in the SCCM 2503 update. However, take a look at the KB31909343 that lists the summary of changes in Configuration Manager current branch, version 2503.
Pre-Upgrade Checklist
Before you upgrade to ConfigMgr 2503, review the below pre-upgrade checklists:
- Begin installing the update 2503 from the top-level site of your hierarchy. Start the installation from your central administration site (CAS) or from your stand-alone primary site.
- Configuration Manager now requires Microsoft .NET Framework version 4.6.2 for site servers, specific site systems, clients, and the console.
- Install Windows Updates on your site server before upgrading. Install any critical OS updates for each applicable site system. If there is a pending reboot, the upgrade will fail.
- The site servers and site system roles must have the Microsoft ODBC Driver for SQL Server 18.1.0 or later installed.
- Make sure there are no database replication issues before the upgrade.
- Temporarily stop any antivirus software, as it may block the upgrade.
- Create a backup of the site database before the upgrade. A successful backup will aid in disaster recovery.
- If you or a third-party product customizes any Configuration Manager configuration files, save a copy of your customizations.
- Review hardware inventory customizations.
- Ensure that no content distributions are made to branch distribution points during the upgrade.
Before Upgrading
If you are upgrading to version 2503, you can skip the hotfixes that were released for 2409 and upgrade directly to the 2503 version. Microsoft supports a direct upgrade from SCCM 2409 to 2503, even without any installed hotfixes.
ADK Support for SCCM 2503
SCCM 2503 supports both the latest versions of the Windows 10 ADK and the Windows 11 ADK.
- For Windows 10, you can install the Windows ADK for Windows 10 version 2004.
- For Windows 11, you can install the Windows ADK for Windows 11 version 24H2.
If you have installed an older version of ADK on your SCCM server and are upgrading your Windows 10/11 to newer versions, you must upgrade your ADK to the latest version available. Use the following guide to update ADK version on SCCM server.
Update Microsoft ODBC Driver for SQL Server
Configuration Manager current branch versions 2503, 2403, and 2309 contain a prerequisite rule that checks for Microsoft ODBC Driver 18 for SQL setup. Before performing the upgrade on any site system servers, it needs to be manually installed. The installation of Microsoft ODBC Driver 18 does not require a restart.
As per Configuration Manager 2503 release notes, the Microsoft ODBC redistributable component is updated to version 18.4.1.1. The Visual C++ redistributable is updated to version 14.40.33816.
Browse to the following download link to get the most recent version of the ODBC driver for SQL Server. Also download the latest Microsoft Visual C++ Redistributable version and install it before you install the new SCCM update.
Refer to the following guide to install or upgrade the ODBC driver on SCCM Server.
Configuration Manager 2503 Prerequisite Check
To check if your ConfigMgr site is ready to upgrade to 2503, you must first run a prerequisite check. Launch the Configuration Manager console. Navigate to Administration > Overview > Updates and Servicing. Select the Configuration Manager 2503 update and in the top ribbon, select Run Prerequisite Check.
Depending on your configuration, the prerequisite check could take a long time to complete. You can monitor all the prerequisite checks in the monitoring node of the console. In addition, you can also review the ConfigMgrPreReq.log to know the status of the prerequisite check.
Once the prerequisite check is complete, if you don’t see any warnings or errors, proceed to the upgrade step.
Upgrading SCCM to version 2503
Perform the following steps to upgrade your SCCM server to version 2503.
Step 1: Launch the Configuration Manager console. Navigate to Administration > Overview > Updates and Servicing Node. Select the Configuration Manager 2503 update and click ‘Install Update Pack.’
Step 2: The following components have been updated in Configuration Manager version 2503:
- Configuration Manager site-server updates
- Fixes for known issues
- New Features
Since we have already performed the prerequisite check, you can enable the checkbox to ignore the prerequisite check warnings. Click Next.
Step 3: On the Features tab, check the boxes for the new 2503 features you want to enable during the upgrade. You can enable these new features after installing the update from Administration > Updates and Servicing > Features. Click on Next to continue.
Step 4: For Client Update Options, select the desired option for updating the clients in your hierarchy. There are two client update options available while installing the update.
- Validate in pre-production collection: With this option, you can validate the client update on members of the pre-production collection while keeping your production client package intact.
- Upgrade without validating: This option allows updating only client members of a specific collection.
Please refer to the SCCM client upgrade options to understand the options available for upgrading the client agents automatically to the latest version. Select the desired client agent update option and click Next to continue.
Step 5: On the License Terms tab, accept the license terms that are mandatory to install the update and click Next.
Step 6: If you have already enabled SCCM Cloud Attach (Tenant Attach) with Intune, you will see an option to upload the Microsoft Defender for Endpoint Data for reporting on devices uploaded to Intune. If your SCCM setup does not include tenant attach, you can skip this step and proceed to the next step.
Step 7: In the Summary window, you see a summary of the settings that you have configured for installing the SCCM 2503 update. Review them and click Next.
Step 8: On the Completion window, click Close.
Monitoring the ConfigMgr 2503 Upgrade
A Configuration Manager administrator can monitor the upgrade process using the following steps:
- In the Configuration Manager Console, go to the Monitoring workspace.
- Select Overview > Updates and Servicing Status.
- Right-click the Configuration Manager 2503 update and select Show Status.
- You can also review the CMUpdate.log file located on the site server to see how the update is progressing.
Upgrading the Console
After installing the SCCM 2503 update, you’ll be prompted to upgrade your console. The old console version will be uninstalled, and a newer console version will be installed. You should not skip the console upgrade process because you will be unable to use an older version of the console.
To upgrade the Configuration Manager console to the latest version, you can either refresh the console once or close and launch the console. For some of you, a yellow notification bar appears just below the top ribbon.
Click Install the new console version to begin the console upgrade. After upgrading to version 2503, the final console version is 5.2503.1083.1000.
If the console upgrade fails, restart the server and try again. During the console upgrade, if you encounter any issues, you can always review the ConfigMgr Console log files.
Verify Upgrade
Once you’ve upgraded the console, launch it. Click on File and from the drop-down, select About Microsoft Configuration Manager.
The following details confirm that your site has been upgraded to version 2503.
- Microsoft Configuration Manager Version: 2503
- Console Version: 5.2503.1083.1000
- Site Version: 5.0.9135.1000
You can manually verify the site build number and version with the following steps:
- In the ConfigMgr console, navigate to Administration > Site Configuration > Sites.
- Right-click your site and select Properties.
- The site version is 5.00.9135.1000 and the build number is 9135.
Update Boot Images
After upgrading to version 2503, the default boot images (x64 and x86) will automatically update on all the distribution points. If it’s not updated, you can manually update the boot images using the following procedure for Boot Image (x64) and Boot Image (x86):
- Go to the Software Library > Operating Systems > Boot Images.
- Right-click the boot image and select Update Distribution Points.
SCCM 2503 Client Upgrade
The production client version of SCCM 2503 is 5.00.9135.1001. The recommended method to upgrade the clients is by using the Automatic Client Upgrade feature.
Using the automatic client upgrade, you can upgrade the clients to the 2503 version.
- In the SCCM console, go to Administration > Site Configuration > Sites.
- Click Hierarchy Settings in the top ribbon and select the Client Upgrade tab.
- Tick the checkbox “Upgrade all clients in the hierarchy using production client“.
- Set the required number of days for an automatic client upgrade to occur. Click Apply and OK.
To group all the clients who have not updated to the latest version for the 2503 build, use the query below to create a device collection. The query will list all the computers that don’t have the latest client agent version, 5.00.9135.1001.
select SMS_R_SYSTEM.ResourceID,SMS_R_SYSTEM.ResourceType,SMS_R_SYSTEM.Name,SMS_R_SYSTEM.SMSUniqueIdentifier,SMS_R_SYSTEM.ResourceDomainORWorkgroup,SMS_R_SYSTEM.Client from SMS_R_System where SMS_R_System.ClientVersion != '5.00.9135.1001'SCCM 2503 Post-Upgrade Checklist
After installing SCCM 2503 update, Microsoft suggests the following post-update checklists:
- Confirm SCCM version and restart the server (if necessary)
- Confirm site-to-site replication is active
- Update Configuration Manager consoles to the latest version
- Reconfigure database replicas for management points
- Reconfigure availability groups and any disabled maintenance tasks
- Restore hardware inventory customizations
- Restore user state from active deployments
- Update Client Agents
- Check for expired third-party extensions
- Enable any custom solutions
- Update boot images and media
- Update PowerShell to help content
Troubleshooting 2503 Update Download Issues
On several setups, the SCCM 2503 update may get stuck in the downloading state. I have published a dedicated article listing out all the common errors and warnings that appear during prerequisite check: https://www.prajwaldesai.com/fix-sccm-update-stuck-downloading-state/.
Here are common causes for upgrade prerequisite check failures, along with their corresponding solutions to address errors and warnings.
- The site database has a backlog of SQL change tracking data: Solution
- Configuration Manager Pending System Restart: Solution
- SQL Server Native Client Version: Solution
- SCCM Update Stuck at Downloading State: Solution
- Enable site system roles for HTTPS or SCCM Enhanced HTTP: Solution
- Recommended version of the Microsoft .NET Framework. Warning: The Configuration Manager 2503 update requires at least DotNet version 4.6.2 but recommends the latest version 4.8: Solution
- ConfigMgr Database Upgrade Error 0x87d20b15: Solution
- Co-Mgmt slider is not pointed to Intune: Solution
- SQL client prerequisites are missing for Config Manager setup: Solution
Hotfixes for Configuration Manager 2503
- KB33177653: Azure for US Government update for Configuration Manager
- KB32480179: Fix PXE clients remain stuck in the “Waiting for Approval”
Known Issues
Version 2503 has only one known issue where it requires you to upgrade SQL 2012 or 2014 Express, Standard, Enterprise edition to SQL 2016 or latest version. Also the VC++ Redistributable Version needs to be upgraded to latest version on Secondary sites.
