Configuration Manager Maintenance Tasks
49 Super Useful Configuration Manager Maintenance Tasks
This post lists all the Configuration Manager maintenance tasks and details of each task. At each site, we have predefined set of SCCM maintenance tasks available and we will explore these in detail.
Configuration Manager comes with set of 49 predefined maintenance tasks. We do see new maintenance tasks added by Microsoft in current branch updates. For example with Configuration Manager 2010, a new maintenance task was added called Delete Aged Collected Diagnostic Files. This task lets you clean up collected diagnostic files.
There are approximately . 49 Configuration Manager maintenance tasks and each of them serves a purpose. In coming years, we may see more tasks added. When you install Configuration Manager, some of these tasks are by default enabled. While the other maintenance tasks needs to be enabled by admins if required. Please read the maintenance task description and then enable the task.
What are Configuration Manager Maintenance Tasks
Configuration Manager Maintenance Tasks are the tasks designed to keep your Configuration Manager site healthy. Once you install Configuration Manager, regular maintenance is important in order to keep site operations running correctly. You don’t have worry because when you install Configuration Manager, it comes installed with built-in Maintenance tasks.
You can enable, disable or edit a maintenance task. Although you may disable the maintenance task, they are super useful and very important for maintaining the overall health of Configuration Manager.
Types of Configuration Manager Maintenance Tasks
Configuration Manager Maintenance tasks can be classified into three categories based on how often you run these tasks. Some tasks require to be run on daily basis while the others can be scheduled to run on specific day and time.
There are three types of Configuration Manager Maintenance tasks and I am quoting as per the information from Microsoft documentation.
  • Daily Maintenance Tasks
  • Weekly Maintenance Tasks
  • Periodic Maintenance Tasks
Daily Configuration Manager Maintenance tasks are some of the common tasks that you should consider to run on a day to day basis. Some of the common daily maintenance tasks include Configuration Manager alerts, checking the Configuration Manager database status etc. Most of these tasks are enabled when you install Configuration Manager.
Weekly Configuration Manager Maintenance tasks are supposed to run on a weekly schedule. Examples include check available disk space on all site systems, check the site database size, delete unnecessary files from site systems.
Periodic Configuration Manager Maintenance tasks are important when it comes to ensuring the good overall site health. These tasks are not required to run on daily or weekly basis. Rather these tasks are related to overall site.
Where can I Find the SCCM Maintenance Tasks
To locate or find the SCCM maintenance tasks :-
  • Launch the SCCM console.
  • Go to Administration\Overview\Site Configuration\Sites.
  • Select your site and click the Maintenance Tasks tab in the bottom pane.
  • This should list all the maintenance tasks that comes predefined with SCCM.
Locate or Find the SCCM Maintenance Tasks
List Configuration Manager Maintenance tasks with SQLTaskStatus Query
You can list all the Configuration Manager Maintenance tasks with a SQL query. The SQLTaskStatus table in SCCM holds the information about maintenance tasks. This method involves running a simple query against the Configuration Manager database.
Login to the SQL Server that holds your Configuration Manager database. Right the SCCM database and run the below query to list all Configuration Manager maintenance tasks.
Select * from SQLTaskStatus
List Maintenance Tasks with SQLTaskStatus Query
Along with the maintenance tasks, we also get to know the last start time, last completion time and completion status of each maintenance task.
How to Setup Configuration Manager Maintenance Tasks
You can setup (Enable/Disable/Edit) Configuration Manager Maintenance tasks with following steps.
  • In the Configuration Manager console, go to Administration > Site Configuration >Sites.
  • Select a site from your list, then click on the Maintenance Tasks tab in the detail panel.
  • Right-click one of the Configuration Manager Maintenance tasks and choose one of the following options:
  • Enable – Turn on the task.
  • Disable – Turn off the task.
  • Edit – Edit the task schedule or its properties.
CAS Configuration Manager Maintenance Tasks
Following are the Configuration Manager Maintenance tasks that are available on a Central Administration Site.
CAS Maintenance Tasks NameMaintenance Tasks DescriptionMaintenance Task Enabled
Rebuild IndexesRebuilds the Configuration Manager database indexes.No
Backup Site ServerCreates a backup of your critical information to restore a site and the Configuration Manager database.Yes
Check Application Title with Inventory InformationUse this task to maintain consistency of software titles between software inventory and the Asset Intelligence catalog.Yes
Delete Aged Application RevisionsDeletes application revisions that are no longer referenced.Yes
Delete Aged Client OperationsDelete from the site database all aged data for client operations.Yes
Delete Aged Client Presence HistoryDelete historical data about the download source used by clients.Yes
Delete Aged Cloud Management Gateway Traffic DataDelete Aged data about CMG TrafficYes
Delete Aged Console Connection DataThis task deletes data from the site database about console connections to the site.Yes
Delete Aged Delete Detection DataUse this task to delete aged data from the database that has been created by extraction views.Yes
Delete Aged Distribution Point Usage StatsUse this task to delete from the database aged data for distribution points that has been stored longer than a specified time.Yes
Delete Aged Log DataUse this task to delete from the database aged log data used for troubleshooting.Yes
Delete Aged Notification Server HistoryThis configuration manager maintenance task deletes aged client presence history.Yes
Delete Aged Passcode RecordsUse this task at the top-level site of your hierarchy to delete aged Passcode Reset data for Windows Phone devices.Yes
Delete Aged Replication DataThis task deletes aged data about database replication between Configuration Manager sites.Yes
Delete Aged Replication Summary DataUse this task to delete from the site database aged replication summary data when it hasn’t been updated for a specified time.Yes
Delete Aged Status MessagesUse this task to delete from the database aged status message data as configured in status filter rules.Yes
Delete Duplicate System Discovery DataThis task deletes the duplicate system discovery data.Yes
Delete Expired MDM Bulk Enroll Package RecordsUse this task to delete old Bulk Enrollment certificates and corresponding profiles after the enrollment certificate has expired.Yes
Delete Obsolete AlertsDeletes the obsolete alerts from the CM DB.Yes
Delete Obsolete Forest Discovery Sites and SubnetsUse this task to delete data about Active Directory sites, subnets, and domains. It removes data that the site hasn’t discovered by the Active Directory Forest Discovery method in the last 30 days.Yes
Monitor KeysThis task monitors the integrity of the Configuration Manager database primary keys.Yes
Primary Site Configuration Manager Maintenance Tasks
If you have a single primary site, you have around 46 predefined Configuration Manager maintenance tasks.
Primary Site Configuration Manager Maintenance Tasks NameMaintenance Tasks DescriptionMaintenance Task Enabled
Backup SMS Site ServerCreates a backup of your critical information to restore a site and the Configuration Manager database.No
Clear Undiscovered ClientsUse this task to remove the installed flag for clients that don’t submit a Heartbeat Discovery record during the Client Rediscovery period.No
Delete Aged Application Request DataDeletes aged application requests from the database.Yes
Delete Aged Client Download HistoryDelete historical data about the download source used by clients.Yes
Delete Aged CMPivot ResultsThis task deletes aged information from clients in CMPivot queriesYes
Delete Aged Collected Diagnostic FilesUse this task to delete collected diagnostic files.Yes
Delete Aged Collected FilesUse this task to delete from the database aged information about collected files.Yes
Delete Aged Computer Association DataUse this task to delete from the database aged OS deployment computer association data.Yes
Delete Aged Device Wipe RecordDeletes data about mobile device wipe actions from ther DB.Yes
Delete Aged Discovery DataDelete aged discovery data from the database such as Heartbeat discovery, Network discovery and Active Directory discovery methods.Yes
Delete Aged Enrolled DevicesDeletes aged mobile device info from the DB.No
Delete Aged EP Health Status History DataThis tasks deletes EP health status history data from DB.Yes
Delete Aged Exchange PartnershipUse this task to delete aged data about mobile devices managed by the Exchange Server connector.Yes
Delete Aged Inventory HistoryUse this task to delete from the database inventory data that has been stored longer than a specified time.Yes
Delete Aged Metering DataUse this task to delete from the database aged data for software metering that has been stored longer than a specified time.Yes
Delete Aged Metering Summary DataRun this task to delete from the database aged summary data for software metering that’s been stored longer than a specified time.Yes
Delete Aged Notification Task HistoryDeletes client notification tasks from the site database.Yes
Delete Aged Scenario Health HistoryThis tasks deletes aged scenario health history from the DB.Yes
Delete Aged Threat DataUse this task to delete from the database aged Endpoint Protection threat data that’s been stored longer than a specified time.Yes
Delete Aged Unknown ComputersUse this task to delete information about unknown computers from the site database when it hasn’t been updated for a specified time.Yes
Delete Aged User Device Affinity DataDeletes the aged affinity data associated with user device from SCCM DB.Yes
Delete Inactive Client Discovery DataUse this task to delete from the database discovery data for inactive clients.No
Delete Obsolete AlertsUse this task to delete from the database expired alerts that have been stored longer than a specified time.Yes
Delete Obsolete Client Discovery DataThis maintenance task deletes obsolete client records from the database.No
Delete Obsolete Forest Discovery Sites And SubnetsUse this task to delete data about Active Directory sites, subnets, and domains. It removes data that the site hasn’t discovered by the Active Directory Forest Discovery method in the last 30 days.Yes
Delete Orphaned Client Deployment State RecordsUse this task to periodically purge the table that contains client deployment state information.Yes
Rebuild IndexesThis task rebuilds the SCCM database indexes.No
Summarize File Usage Metering DataUse this task to summarize the data from multiple records for software metering file usage into one general record.Yes
Summarize Installed Software DataUse this task to summarize the data from collected asset intelligence software information through the hardware inventory to merge multiple records into one general record.Yes
Summarize Monthly Usage Metering DataUse this task to summarize the data from multiple records for software metering monthly usage into one general record.Yes
Update Application Available TargetingUse this task to have Configuration Manager recalculate the mapping of policy and application deployments to resources in collections.Yes
Update Application Catalog TablesUse this task to synchronize the Application Catalog website database cache with the latest application information.Yes
Secondary Site SCCM Maintenance Tasks
Listed below are some of the Configuration Manager Maintenance tasks available when you install SCCM secondary site.
Secondary Site SCCM Maintenance Tasks NameMaintenance Tasks DescriptionTask Enabled
Delete Aged Log DataThis task deletes aged log dataYes
Deleted Aged Replication Summary DataUse this task to delete from the site database aged replication summary data when it hasn’t been updated for a specified time.Yes
Deleted Aged Replication Tracking DataUse this task to delete from the site database aged replication tracking data when it hasn’t been updated for a specified time.Yes
