Fix Skype for Business (Lync) Recording Shows Pending Status
Fix Skype for Business Recording Shows Pending Status
If your Skype for business recording shows pending status, this article will show you how to resolve it. You can resolve the same problem with Lync by following the instructions in this article.
Recently, we discovered that users were unable to export the recorded calls during Skype (Lync) meetings, and the recordings were marked as pending and never completed.
The Skype for Business Recording Manager allows you to play your meeting recordings, browse to the location where you have them saved, or publish them for others to view. The Skype for Business Recording Manager was in a pending state for over an hour and would not create the recorded file to share.
Numerous users experienced this, and no one could figure out why Skype was not recording the meetings. Restarting the computer was also done as a basic troubleshooting step to see if the Skype application was having any problems.
Note that Lync is becoming Skype for Business. Installing KB3115883, which fixes the error “You need to install additional updates” when you launch the Lync 2013 client, is necessary to make sure that does not happen.
Where does Skype save the recordings?
While using Skype for business, you can begin recording your call if the participant’s organization allows it. Your Skype for Business meeting recordings are saved in the Videos > Lync Recordings folder. The recording will be saved as an MP4 file. If you prefer to change the location, click Browse and choose a different folder.
Upon the completion of the Skype meeting, there were no audio or video files populated in the C:\Users\Username\Video\Lync Recordings folder. So either the recording did not happen or the recording wasn’t saved to a file.
It was recommended to wait until the status changed from pending to completed after checking a number of Skype forums; however, in my case, the status remained pending for a considerable amount of time, and the video was never published. The solution to this problem is quite bizarre, and you can see from the comments section that it was successful for an enormous number of people.
If your meeting recording status is pending, hovering your mouse over it displays the message “Pending was paused to save power; plug in to continue.” The solution here is to connect a power supply directly to the laptop battery port. The recordings are exported when the laptop’s power source is connected.
What is the reason behind the successful export of recorded Skype and Lync meetings once the laptop was powered on? The recorded meetings weren’t exported or published because Skype or Lync export the meetings only when the laptop is connected to a power source. The fact that publishing a video uses a lot of CPU power may also be the cause.
So, the next time you are in a meeting, make sure your laptop is connected to a power source so that you can successfully record and export videos.
Lync Recorded session shows pending status
Lync Skype for Business Recording Pending Status
Play and share a recording
Once you have successfully recorded the meeting via Skype or Lync, you can access it to play or send to others. Skype for Business displays a message when the recording is ready. You can click the alert to open Recording Manager, or if you miss that, click Tools on the Skype for Business main window, then Recording Manager.
Use the following steps to share a Skype call recording from the Recording Manager window:
  • Click your recording to highlight it, then click Play on the right side of the window.
  • You can also rename or delete your recording here.
  • To share your recording with others, click Browse to locate it, then copy the file to post on a shared location, such as OneDrive or an internal SharePoint site.
152 Comments
  1. Avatar photo Payal Jawaria says:
    Yes, it definitely works !!
  2. Avatar photo Dujendra Dubey says:
    Thank you so much for this information i got a relief now as i recorded a critical session and i got panicked but thanks to you again
  3. This word!! Thanks so much 🙂
  4. Avatar photo Mahesh Mohangekar says:
    Thank you so much Prajwal !! It worked ….
  5. Avatar photo John Enriquez says:
    Wow. What an informative and simple article you provided. I appreciate it. Before, I tried Acethinker Screen Grabber Pro to record Lync sessions. But I will definitely try the tip you provided. Thank you so much!
  6. Thank you so much for the simple trick to solve the issue …thanks a lot
  7. Lol. Didn’t expect it to be this simple. Thanks a lot Prajwal!
  8. Avatar photo suman pandit says:
    Thanks a lot!! It worked
  9. perfect solution! pending status changed in the moment i connected the AC adaptor.
  10. Avatar photo Jaanis Petke says:
    Thanks for help! Works like a Buick!
  11. thanks a lot for the info!
  12. Thanks for this,..really helpful
  13. Thank you so much..!
  14. Thanks for this really helpful article 🙂
    I also remember that it once didn’t work because of some internet network issues that I used to have.
  15. Avatar photo Priyanka Shanmugam says:
    Oh my god..You saved my work…Thanks Man
  16. Avatar photo Saumya Shrivastava says:
    Thanks for this man!!
  17. Avatar photo Vivek Wadhawan says:
    I have Status Warning in My Skype Recording Manager, what could be the issue ?
    Thanks in Advance
  18. Thank you for sharing your findings!
  19. Avatar photo Shailesh Shetty says:
    Thanks for this!!
  20. Avatar photo Armando S says:
    It really works as crazy as it sounds, Thank you!!!
  21. Thank you Prajwal! I was totally lost on what to do.
  22. Yes plugging AC adopter created file . Thanks for sharing this.
  23. Avatar photo Samarendra says:
    You are right, same thing happened to me as well and using same process I am able to get my recording. Thanks a lot for your blog, it helped me to get of that weird thing.
  24. Worked for me! thanks a lot
  25. Avatar photo Swarnendu says:
    Thank you so much. You are awesome!!!
  26. Thank you so much… you saved my life … I wonder how bad it would have been if i had lost the recording.. Cheers !!!!
  27. Avatar photo Sumy Koshy says:
    Thanks. This really helped me. I was worried that I lost the recording. Glad I found this page.
  28. Avatar photo Victor D'Sa says:
    This was Very Useful. Happened to me and I am glad that I foud this link and it worked as it said. I did not believe at first but Yeah it Worked !!!
  29. It worked!! Thanks a lot, i was freaking out with that “pending” status. The moment i plugged in, it started saving the file. Thanks again!
  30. Avatar photo shanthibhushan says:
    lol..it worked..its so crazy to think so..
  31. Lol..It worked. Thank you so much.
  32. i plugged in and it started to save the recordings lol! thanks a lot!
  33. 😀 😀 😀 LOL , plugged in the power cord and it started the encoding….. damn, that’s awkward
  34. Thank you, saved me an hour or two!
  35. Avatar photo firstname lastname says:
    thanks, this helped.
  36. boss you rocked
    thanks it worked
  37. Avatar photo Venkateswarlu Konjeti says:
    Thank you very much. Worked as expected after connecting to power.
  38. I would never think such a thing, thanks!!
  39. Avatar photo Anthony Ramos says:
    Very helpful indeed. Thanks for this.
  40. Eternal thanks for this!
  41. Thanks a lot, Helped & worked immediately.
  42. This is really helpful, helped solve my issue immediately. Thanks
  43. Avatar photo Kather Rafi says:
    Thanks prajwaldesai, its a good info, atleast microsoft must include this in the skype recording manager.
  44. Thanks for this piece. I was going nuts with the recording status at Pending for a really long time. The minute i plugged my charger in, it starting moving. Thanks a ton!
  45. Avatar photo Prannoy Kumar K says:
    Thanks a lot I almost thought I had lost the recording of one of my most important meetings. Poor from Microsoft though.
  46. Thanks alot!! it worked.
  47. Avatar photo supriti sawant says:
    thanks for this great tip and it saved my day 🙂 appreciate your help.
  48. Great Tip, I was worried for a minute before finding this
      1. Avatar photo Hemal Patel says:
        I got same issue even battery is full charged. But I am able to publish file by closing the cheating box
  49. Oh Thank you for letting me know! Once I plugged in my computer – the video is publishing like a dream.
  50. You make the world a better place to live! Thanks Hero!
  51. You just literally saved my life!
    Thanks for this article, I’ve been sitting and waiting for recording to change status for loooong time 😀
  52. Avatar photo Ashwinee Tijare says:
    I delivered an important session in skype big event. There were 390+ participants. We had a very good interactive session. And as summary mail i was about to give link to download recording of the session when I encountered the same issue; Status as “Pending”.
    I got this fix on a very first link on Google It worked immediately. Thanks a lot!!
    It was great catch..
  53. Avatar photo Ramprasad says:
    Hi Prajwal, the recording status bar is not showing any status and it is a blank. Please advise me on the fix
  54. Good catch!
    Looks like I’m not the only one!
  55. Avatar photo OfficeSkyper says:
    Exactly what I wanted. This is the top result in Google for a reason.
  56. Avatar photo standa zapata says:
    brilliant /s
    it works, thanks
  57. Thank you! I can’t say that enough! I save the file and you save me!
  58. Oh man, you just SAVED MY ASS or at least reputation. I thought I lost my 1,5 hour meeting record where I promised to distribute it to all participants (93!!!). Whew, once again THANK YOU!!!
  59. yes.. thank you.. 🙂
  60. Thank You! You saved me a minor heart attack 🙂
  61. 1000 Likes…what a solution.
      1. Something similar , google sent me directly to your page 🙂 , Cheers for good work.
  62. Thanks a ton , Prajwal. It worked .I faced this weird issue. As soon as the AC adapter was connected, the publishing of video started immediately. Was just not able to figure out.
  63. Thanks for solution it’s worked for me 🙂
  64. Prajwal ur awesome !!
  65. Thank you Prajwal.. Its actually crazy.. But was really helpful..
  66. Its insane that you dont get any further info about this directly in skype. Thanks for posting this. Like many other i too got a real sacare but it was resolved after plugging in the charger.
  67. Unbelievable! it actually works!
  68. Pending was paused to save power, plug in to continue … good eye..:)
  69. Avatar photo Genevieve says:
    Thank you – worked for me too!
  70. Vow , crazy but works. Thanks a ton
  71. Vow , crazy but works
  72. Avatar photo Alexandra Hatfield says:
    Worked for me. Thank you!
  73. Thank you Prajwal, would have been difficult figuring this on out on my own
  74. It was really helpful. Thanks!
  75. You diserve the nobel price, my friend, thank you
  76. THANK YOU SOOO MUCH!!! THAT SAVED MY PROJECT TODAY!!!!
  77. Most useful solution ever read/ heard. Thanks a lot.
  78. Avatar photo Ganapathy KR says:
    You are a legend. Thanks for the resolution.
  79. Like you said solution given for this one is Crazy, but it’s true man… Cheers..
  80. awesome.. frightened that i might have lost the important recording
  81. Wow u just saved our day. What a helpful reply.
  82. Thanks so much. It helped me , otherwise I had no clue.
  83. Avatar photo Polly Joseph says:
    Thanks man, you da best! You saved my skin! If I may, in your description of yourself, you have a small typo: ” and I have been working in the IT for over 8 years” I think that “the” between “in” and “IT” is redundant. y
  84. This is a life saver, thanks!
  85. THANKS! Even when my computer was almost full charged, as soon as I plugged in the power cord the status changed and the process was finished! It’s something that never cross my mind during troubleshooting. Thanks for the tip!
  86. Very helpful, thanks, I thought I wasn’t gonna be able to get my recording back, you saved my life!!
  87. Thanks for this! The same thing happened to one of my recordings!
  88. Avatar photo Deepak Patni says:
    Very helpful ..Thanks
