In this post, we will look at the steps to install WSUS for SCCM. You can install WSUS for Configuration Manager before you configure the Software Update Point role.
One of the prerequisites while installing SCCM is WSUS role installation. ConfigMgr admins can install and configure WSUS role after installing SCCM and that’s completely supported.
If you are looking to set up Software Update Point role in SCCM, the following step by step will guide you with installing Software Update Role (SUP).
If you are installing Configuration Manager on a new setup, you install WSUS for SCCM after SQL server is installed. During the WSUS role installation, you must specify the SQL server name to create the SUSDB.
If you are installing WSUS to manage updates deployment without SCCM, here is a guide to Install and Configure WSUS on Windows Server 2019.
By definition, WSUS is Microsoft’s separate, stand-alone server-based product for distributing updates to Windows systems. Windows Update service downloads and installs recommended and important updates automatically.
The software update point (SUP) site system role must be installed on a server that has WSUS role installed. For SCCM SUP role, you must use the 64-bit version of WSUS on one of the supported 64-bit editions of Windows Server. For example, Windows Server 2019 or Windows Server 2022.
Install WSUS for SCCM | Configuration Manager
Let’s install WSUS for SCCM on Windows Server.
  • Log on to the server on which you plan to install the WSUS server role. Use an account that is a member of the Local Administrators group.
  • In Server Manager, click Manage, and then click Add Roles and Features.
  • On Server Roles page, select Windows Server Update Services and click Next.
Install WSUS for SCCM Configuration Manager
WSUS only requires the default Web Server role configuration. On the Features page, retain the default selections, and then click Next.
On the Windows Server Update Services page, click Next.
WSUS Role Services
Under Role Services, you must select a database type for WSUS. There are three options for selecting database type for Windows Server Update Services.
  • WID Database
  • WSUS Services
  • Database
Note: You must select one Database type for WSUS. If none of the database options are selected, the WSUS post installation tasks will fail.
When you install WSUS for SCCM, you must always select WSUS Services and Database options. These are the ones that are actually required. Do not select WID Database here. Click Next.
Installing WSUS for Configuration Manager 2012 R2
WSUS Content Location Selection
On the Content location selection page, type a valid location to store the WSUS updates. In this content folder the WSUS downloads and stores license terms for specific software updates in the update content folder.
During the Software Update synchronization process, Configuration Manager looks for applicable license terms in the content folder. If it cannot find the license terms, it will not synchronize the update. Provide a folder path and click Next.
Database Instance for WSUS | SCCM
On the Database Instance Selection page, specify the database server where you want to store the WSUS database. If this WSUS is for a single SCCM primary site, the same SQL server will hold the Configuration Manager Database as well.
Specify the SQL Server FQDN and click on Check connection, and you must see the message Successfully connected to server. Click Next.
Database Instance for WSUS SCCM
On the Confirmation page, click Install.
The WSUS role is now installed and configured for SCCM. In some cases, after installing WSUS for Configuration Manager, you may see a notification that a restart is required. This can vary according to the installed server role. If it requires a restart make sure to restart the server to complete the installation.
Install WSUS for Configuration Manager
Configure WSUS Post Installation Tasks
When you install WSUS for SCCM, you will notice that SUSDB isn’t created on your SQL Server. That’s because you haven’t performed the WSUS post installation tasks.
The WSUS post installation tasks is mandatory. This task creates the database (SUSDB), directories, pool in IIS, imports the publisher info such as Windows, Office, SQL etc.
When you configure the post installation tasks for WSUS, you are preparing the WSUS to be ready for synchronization with Microsoft.
Click on Launch Post-Installation tasks.
The message Windows Server Update Service Configuration successfully completed confirms the WSUS post installation tasks have been completed successfully. Close the Add Roles and Features Wizard.
Check SUSDB in SQL Server
After completing the WSUS post installation tasks, let’s check if the SUSDB is now visible in SQL Server. Launch the SQL Server Management Studio, enter the SQL Server name and connect to Database Engine. Expand Database and here you will find SUSDB.
Do not Configure WSUS Configuration Wizard
This is important, after you install WSUS for SCCM, you should not configure the WSUS configuration wizard. That’s because going forward Configuration Manager should be used to synchronize updates, download updates and deploy updates.
I have seen many IT guys use WSUS console even though most of the updates management can be from Configuration Manager console. It is ok to use WSUS console to review updates or the synchronization status, but you should not perform tasks such as approving or declining updates because it can adversely affect Configuration Manager’s software update management capabilities.
This completes the steps to install WSUS for Configuration Manager.
Still Need Help?
169 Comments
  1. Avatar photo shaik Suhail says:
    Hi Prajwal, while installing WSUS I am facing issue like it saying,one more predeployment task failed. instance Name property doesn’t exist parameter name : configure store.
  2. Avatar photo shaik Suhail says:
    Hi while installing WSUS I am facing issue
  3. Avatar photo Rui Silva says:
    Hi, my clients don´t receive the update packages from SCCM. And another problem is we don´t see the status (required, installed, percent compliant,… ) in All Software Updates List.
    Can someone help with this question?
  4. We already have one SUP role installed(WSUS), SUP database is already created in SQL database. We are trying to create a new WSUS/SUP role and need to use same database, In this case, what we need to fill in “Database Instance Selection”?
  5. Avatar photo Hi Prajwas, my name is Karim says:
    Please advice, I have windows 7 PC wiht 8gb RAM, itb USB drive , how could I create home lab for SCCM?
    Your advice will be highly appreciate.
    Regards
    Karim
  6. Avatar photo Steve Graves says:
    Love your tutorials been following a couple of years, Thank you!
  7. Avatar photo Luis Olias says:
    This is just amazing. So well described and so easy to follow. Much much appreciated.
      1. Hey Prajwal.. how can i contact u hve urgent sccm issue.
  8. hello sir,
    i am trying to complete WSUS post installation tasks but i got error
    “configuration failed”
    1. Do you have domain admin access? Or DB access to create a new database?
  9. I’m install SCCM 2012 R2 in Production environment, I like to ask few question before I go forward.
    1. Should I install SCCM and WDS on same server
    2. Should I install WSUS on separate
    3. Should I install WSUS and WDS on same server
    Do you know any technet Documents forr best practies
    1. Avatar photo Ebrahim Hasan says:
      Installing SCCM, WDS, and WSUS on the same server is recommended.
    2. Avatar photo ebrahim.k.hasan says:
      Installing WSUS, WDS, and SCCM on the same server is recommended.
    3. All should be in same server
  10. Hi!
    When running post-installation scripts, at the end it fails with
    wsus Fatal Error: Filename: \\?\C:\Windows\system32\inetsrv\config\applicationHost.config
    I checked permission\services etc.
    any one have any idea ?
    1. Solved it:
      1. In section, found added in “autoStart=”true”.
      2. In section removed the following line:
      have fun Interweb Users
  11. Avatar photo Andrew Mkpanam says:
    I already have WSUS running in a production environment, but i just introduced Configuration manager. How do i get software update point to sync with the existing WSUS installation
  12. Hi Prajwal,
    Do I need to set permissions for the wsus content folder?
    Thanks,
  13. Hi Prajwal, I installed WSUS on my windows 2016 server and it was installed successfully. I didnt configure it as you mentioned. but i cant see SUSDB created under Databases? am i missing something?
    I havent installed SCCM yet.
      1. hello sir,
  14. Avatar photo SRAVANTHI says:
    can we configure single sccm for all wsus servers.Please suggest.
  15. Hi prajwal ,
    i am facing issue in wsus installation
    Error:Configuration failed : log file C:\users\administrator\Appdata\local\Temp\tmp89
    can you help this issue
      1. yes I shared that error above you can see that configuration failed for windows server update services
      2. yes that error i shared above you can see that my configuration failed.
        I am using sql server 2012
        so this issue will come due to sql server 2012 or i will upgrade to sql server 2014
  16. Avatar photo SRAVANTHI says:
    Great Article.
    I have 4 wsus servers in lab. Can i install one SCCM and can manage all 4 wsus servers. Basically i require reporting for patches for all servers. Please suggest.
    Thank you
  17. how to check my clinet pc win10 getting update from wsus server2012 (Use the update using unassigned computers)
    Note: installed /not applicable percentage showing 96 % ??
  18. Avatar photo Lex van der Horst says:
    You helped me out with this great article. Many Thanks !
  19. Hi Prajwal, if I try to open WSUS on Server 2012 R2 it wants to finish the installation. Should I do this?
  20. Avatar photo Abuchi A Abuchi says:
    Hello Prajwal.
    I have SCCM 2012r2, with WSUS, but my client are not getting the update rollout.
  21. What steps (if any ) need to take place if you accidently click on “Launch Post installation tasks” after WSUS installation. I didn’t click next on the wizard, but hit cancel, This notice was showing as flagged in server manager tasks and I ran the task from server manager. Not sure if it was the same thing. I now see a ID:13051 Warning for WSUS. Please advise.
      1. Thanks for getting back to me… Yes SUSDB is in SQL now.
          1. Thank you! Your posts and instructions are great!
  22. Hi Prajwal,
    Thank you for your great post on installing SCCM. I’m running into an issue with WSUS service. My environment is Windows Server 2012R2, SQL 2014. SQL, WSUS Service, and SCCM are in the same Windows Server 2012R2. After I installed WSUS Service successful, then close the Windows. When I open the WSUS Console, it forced me to configure: Complete WSUS Installation (Sorry, I can’t insert the screenshot in the post). When I clicked Run, and I got error as follow below. I have also tried to uninstalled both WSUS Service and IIS, and re-installed both of them. I also configured IIS binding on Default Web Site for both http ports 80 & 8530. Now, I configured IIS binding only port 8530, but still got the same error. I’m at the dead end and need your help. Thank you very much.
    The.TMP error file content:
    2016-09-06 12:07:58 Postinstall started
    2016-09-06 12:07:58 Detected role services: Api, Database, UI, Services
    2016-09-06 12:07:58 Start: LoadSettingsFromParameters
    2016-09-06 12:07:58 Content local is: True
    2016-09-06 12:07:58 Content directory is: C:SourceUpdates
    2016-09-06 12:07:58 SQL instname is: NCC-SCCM-2012R2.NCC.GOV
    2016-09-06 12:07:58 End: LoadSettingsFromParameters
    2016-09-06 12:07:58 Start: Run
    2016-09-06 12:07:58 Fetching WsusAdministratorsSid from registry store
    2016-09-06 12:07:58 Value is S-1-5-21-3298164499-4248302938-774495382-1005
    2016-09-06 12:07:58 Fetching WsusReportersSid from registry store
    2016-09-06 12:07:58 Value is S-1-5-21-3298164499-4248302938-774495382-1006
    2016-09-06 12:07:58 Configuring content directory…
    2016-09-06 12:07:58 Configuring groups…
    2016-09-06 12:07:58 Starting group configuration for WSUS Administrators…
    2016-09-06 12:07:58 Found group in regsitry, attempting to use it…
    2016-09-06 12:08:01 Writing group to registry…
    2016-09-06 12:08:01 Finished group creation
    2016-09-06 12:08:01 Starting group configuration for WSUS Reporters…
    2016-09-06 12:08:01 Found group in regsitry, attempting to use it…
    2016-09-06 12:08:01 Configuring permissions…
    2016-09-06 12:08:01 Fetching content directory…
    2016-09-06 12:08:01 Fetching ContentDir from registry store
    2016-09-06 12:08:01 Value is C:SourceUpdates
    2016-09-06 12:08:01 Fetching group SIDs…
    2016-09-06 12:08:01 Fetching WsusAdministratorsSid from registry store
    2016-09-06 12:08:01 Value is S-1-5-21-3298164499-4248302938-774495382-1005
    2016-09-06 12:08:01 Fetching WsusReportersSid from registry store
    2016-09-06 12:08:01 Value is S-1-5-21-3298164499-4248302938-774495382-1006
    2016-09-06 12:08:01 Creating group principals…
    2016-09-06 12:08:01 Granting directory permissions…
    2016-09-06 12:08:01 Granting permissions on content directory…
    2016-09-06 12:08:01 Granting registry permissions…
    2016-09-06 12:08:01 Configuring shares…
    2016-09-06 12:08:01 Configuring network shares…
    2016-09-06 12:08:01 Fetching WSUS admin SID…
    2016-09-06 12:08:01 Content directory is local, creating content shares…
    2016-09-06 12:08:01 Creating share “UpdateServicesPackages” with path “C:SourceUpdatesUpdateServicesPackages” and description “A network share to be used by client systems for collecting all software packages (usually applications) published on this WSUS system.”
    2016-09-06 12:08:01 Deleting existing share…
    2016-09-06 12:08:01 Creating share…
    2016-09-06 12:08:01 Share successfully created
    2016-09-06 12:08:01 Creating share “WsusContent” with path “C:SourceUpdatesWsusContent” and description “A network share to be used by Local Publishing to place published content on this WSUS system.”
    2016-09-06 12:08:01 Creating share “WSUSTemp” with path “C:Program FilesUpdate ServicesLogFilesWSUSTemp” and description “A network share used by Local Publishing from a Remote WSUS Console Instance.”
    2016-09-06 12:08:01 Finished creating content shares
    2016-09-06 12:08:01 Stopping service WSUSService
    2016-09-06 12:08:01 Stopping service W3SVC
    2016-09-06 12:08:04 Configuring database…
    2016-09-06 12:08:04 Configuring the database…
    2016-09-06 12:08:04 Establishing DB connection…
    2016-09-06 12:08:04 Checking to see if database exists…
    2016-09-06 12:08:04 Database exists
    2016-09-06 12:08:04 Switching database to single user mode…
    2016-09-06 12:08:07 Loading install type query…
    2016-09-06 12:08:07 DECLARE @currentDBVersion int
    DECLARE @scriptMajorVersion int = (9600)
    DECLARE @scriptMinorVersion int = (18324)
    DECLARE @databaseMajorVersion int
    DECLARE @databaseMinorVersion int
    DECLARE @databaseBuildNumber nvarchar(10)
    IF NOT EXISTS(SELECT * FROM sys.databases WHERE name=’SUSDB’)
    BEGIN
    SELECT 1
    END
    ELSE
    BEGIN
    SET @currentDBVersion = (SELECT SchemaVersion FROM SUSDB.dbo.tbSchemaVersion WHERE ComponentName = ‘CoreDB’)
    SET @databaseBuildNumber = (SELECT BuildNumber FROM SUSDB.dbo.tbSchemaVersion WHERE ComponentName = ‘CoreDB’)
    DECLARE @delimiterPosition INT = CHARINDEX(‘.’, @databaseBuildNumber)
    IF (@delimiterPosition = 0)
    BEGIN
    RAISERROR(‘Invalid schema version number’, 16, 1) with nowait
    return
    END
    SET @databaseMajorVersion = SUBSTRING(@databaseBuildNumber, 1, @delimiterPosition – 1)
    SET @databaseMinorVersion = SUBSTRING(@databaseBuildNumber, (@delimiterPosition + 1), (10 – @delimiterPosition))
    IF @currentDBVersion @databaseMajorVersion OR
    (@scriptMajorVersion = @databaseMajorVersion AND @scriptMinorVersion > @databaseMinorVersion))
    BEGIN
    SELECT 2
    END
    ELSE IF (@scriptMajorVersion = @databaseMajorVersion AND
    @scriptMinorVersion = @databaseMinorVersion)
    BEGIN
    SELECT 0
    END
    ELSE
    BEGIN
    SELECT 4
    END
    END
    END
    2016-09-06 12:08:07 Install type is: Reinstall
    2016-09-06 12:08:07 Creating logins…
    2016-09-06 12:08:07 Fetching account info for S-1-5-20
    2016-09-06 12:08:07 Found principal
    2016-09-06 12:08:07 Found account
    2016-09-06 12:08:07 Got binary SID
    2016-09-06 12:08:07 Fetching WsusAdministratorsSid from registry store
    2016-09-06 12:08:07 Value is S-1-5-21-3298164499-4248302938-774495382-1005
    2016-09-06 12:08:07 Fetching account info for S-1-5-21-3298164499-4248302938-774495382-1005
    2016-09-06 12:08:07 Setting content location…
    2016-09-06 12:08:07 Fetching ContentDir from registry store
    2016-09-06 12:08:07 Value is C:SourceUpdates
    2016-09-06 12:08:07 Swtching DB to multi-user mode……
    2016-09-06 12:08:07 Finished setting multi-user mode
    2016-09-06 12:08:07 Writing DB settings to registry…
    2016-09-06 12:08:07 Marking PostInstall done for UpdateServices-Database in the registry…
    2016-09-06 12:08:07 Starting service W3SVC
    2016-09-06 12:08:07 Configuring IIS…
    2016-09-06 12:08:07 Start: ConfigureWebsite
    2016-09-06 12:08:08 Configuring website on port 8530
    2016-09-06 12:08:09 System.ComponentModel.Win32Exception (0x80004005): The system cannot find the file specified
    at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
    at System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
    at Microsoft.UpdateServices.Administration.UseCustomWebSite.ExecuteIisCustomAction(String arguments)
    at Microsoft.UpdateServices.Administration.UseCustomWebSite.InstallAndConfigure(IisConfiguration& iisConfiguration, Int32 newPortNumber)
    at Microsoft.UpdateServices.Administration.UseCustomWebSite.CreateWebsite(Int32 newPortNumber)
    at Microsoft.UpdateServices.Administration.PostInstall.ConfigureWebsite(Int32 portNumber)
    at Microsoft.UpdateServices.Administration.PostInstall.Run()
    at Microsoft.UpdateServices.Administration.PostInstall.Execute(String[] arguments)
    1. Desai,
      Unfortunately, for me, and actually broke my server. I got a black screen with a CDM window only. I’m rebuilding my server 🙁
      1. //
        // Issue
        – The post-install’s final task command-line arguments had a few typos (eg. “C:Program FilesUpdate ServicesWebServicesRoot “)
        // [String][] $tldr = ‘SysInternals’ Process Monitor trumps Microsoft’s Quality Assurance, yet again…’ | Out-File “C:tempsadPanda.txt”;
        – The task immediately halted when attempting to re-create the (previously deleted) “WSUS Administration” IIS Site
        2017-06-08 20:56:25 Swtching DB to multi-user mode……
        2017-06-08 20:56:25 Finished setting multi-user mode
        2017-06-08 20:56:25 Writing DB settings to registry…
        2017-06-08 20:56:25 Marking PostInstall done for UpdateServices-Database in the registry…
        2017-06-08 20:56:25 Starting service W3SVC
        2017-06-08 20:56:25 Configuring IIS…
        2017-06-08 20:56:25 Start: ConfigureWebsite
        2017-06-08 20:56:25 Configuring website on port 8530
        2017-06-08 20:56:26 System.ComponentModel.Win32Exception (0x80004005): The system cannot find the file specified
        // Resolution
        – Created a batch file, fixed the filepath typos, (you’ll most likely have to replace arguments/filepaths as needed), ran the batch file as an Administrator
        – Double-check your ACLs for the “C:Program FilesUpdate Services” directory + sub-directories for the user running the batch file…you may need ownership privileges, temporarily (and explicitly) to finish this (infernal!) post-install task
        C:temppleaseWorkWSUS.bat = “C:Program FilesUpdate ServicesSetupIISCustomAction.exe” /Install C:tempWsusUtilUseCustomWebSite.log 6.3.9600.18325 “C:Program FilesUpdate ServicesSetupIISConfig.xml” “WSUS Administration” “:8530:” “C:Program FilesUpdate ServicesWebServicesRoot” “C:Program FilesUpdate Services” “K:SourceUpdates”
        // Info
        1. Filepath for the “IISCustomAction.exe” executable (default)
        – “C:Program FilesUpdate ServicesSetupIISCustomAction.exe”
        2. Switch to start the install execution (default)
        – /Install
        3. Filepath for execution logging dump (change as needed)
        – C:tempWsusUtilUseCustomWebSite.log
        4. Your WSUS Server’s Version (change as needed)
        – 6.3.9600.18325
        5. Filepath for WSUS’s IIS AutoSetup Config (default)
        – “C:Program FilesUpdate ServicesSetupIISConfig.xml”
        6. Custom IIS Website Name (default)
        – “WSUS Administration”
        7. Custom IIS Website Binding/Port (default)
        – “:8530:”
        8. Virtual Directory for the WebServices application/pool/service (default)
        – “C:Program FilesUpdate ServicesWebServicesRoot”
        9. Top-Level filepath for the WSUS installation binaries (default)
        – “C:Program FilesUpdate Services”
        10. Filepath for the synchronized updates stored on your WSUS server,
        “WsusContent” and “UpdateServicesPackages” (change as needed)
        – “K:SourceUpdates”
        Good luck!
  23. Avatar photo AaronSmith86 says:
    is it required to have WSUS local to the SCSM Primary site? We already have a WSUS server, so I’ve pointed the SUP to that URL to synchronize. However, I’m not seeing updates coming in to the console.
    1. Seems like issues in Synchronization of updates. Have you checked any wsus log files ?.
  24. Hi
    I have a WSUS server and a SCCM server.
    For SCCM do i Add site system role or create site system server for wsus?
    Thnaks
  25. Hi Prajwal,
    I’m running into the following issue:
    For performance reasons I want to move WSUS/SUP to a seperate server, within the primary SCCM site. On that server I installed IIS, WSUS (with necessary hotfixes), SQL2012 express and finally a software update point through the SCCM console. (so SUP is the only additional role for the new server and the existing SUP on the primary site server)
    Installations all went fine, but when firing it up, the WCM log on the primary reports both SUPS but can’t connect to the new SUP ; The request failed with HTTP status 503: Service Unavailable.
    (servers are running Server 2008R2, SCCM 2012 SP1)
    Trigger event array index 0 ended.
    SCF change notification triggered.
    Populating config from SCF
    Setting new configuration state to 1 (WSUS_CONFIG_PENDING)
    Changes in active SUP list detected. New active SUP List is:
    SUP0: first-sup-fqdn group = primary, nlb =
    SUP1: new-sup-fqdn, group = , nlb =
    Updating active SUP groups…
    Checking for supported version of WSUS (min WSUS 3.0 SP2 + KB2720211 + KB2734608)
    Checking runtime v2.0.50727…
    Found supported assembly Microsoft.UpdateServices.Administration version 3.1.6001.1, file version 3.1.7600.274
    Found supported assembly Microsoft.UpdateServices.BaseApi version 3.1.6001.1, file version 3.1.7600.274
    Supported WSUS version found
    Attempting connection to WSUS server: first-sup-fqdn port: 8530, useSSL: False
    Successfully connected to server: first-sup-fqdn port: 8530, useSSL: False
    Verify Upstream Server settings on the Active WSUS Server
    No changes – WSUS Server settings are correctly configured and Upstream Server is set to Microsoft Update
    Attempting connection to WSUS server: new-sup-fqdn, port: 8530, useSSL: False
    System.Net.WebException: The request failed with HTTP status 503: Service Unavailable.~~ at Microsoft.UpdateServices.Administration.AdminProxy.CreateUpdateServer(Object[] args)~~ at Microsoft.SystemsManagementServer.WSUS.WSUSServer.ConnectToWSUSServer(String ServerName, Boolean UseSSL, Int32 PortNumber)
    Configuration successful. Will wait for 1 minute for any subscription or proxy changes
    Setting new configuration state to 2 (WSUS_CONFIG_SUCCESS)
    Waiting for changes for 28 minutes
    I hope you can shed some light on this.
    Cheers,
    Joe.
  26. Prajwal,
    I’ve been through “Installing WSUS for Configuration Manager 2012 R2” a few times now (Lot’s of do overs) . . .
    When I reach “How To Deploy Software Updates Using SCCM 2012 R2” I’m noticing that WSUS and SCCM are not syncing . . .
    I have and have not run “Post Deployment Configuration”, but when I try to run WSUS to check on synchronization I’m stopped by a “Complete WSUS Installation” window
    Wondering what to do at this point (I’ve clicked “Run” and moved on, and I’ve clicked “Close” and moved on . . . And weather or not it is truly having an impact on the sync issue.
    Any advice would be appreciated.
  27. Avatar photo Gareth Wynne says:
    Just a quick question with sccm the SQL licence is free for use with SCCM install. If you use apply the wsus element to the db does this then become a chargeable entity?
    Kind Regards
  28. Can wsus 4 works with sccm 2012 r2?
    1. I am not sure about this. You may check the R2 documentation and see if WSUS 4 is compatible with R2.
      1. Hi,
        i have a wsus server and a sccm server.
        for the SUP,should i add a software update server to the DP or create a new software update point?
  29. Hi Prajwal Desai,
    I have a question. I was searching the system requirements for installing WSUS 3.0 SP2 on Windows Server 2012 R2. The only thing I can find is documents about system requirements for installing WSUS 3.0 SP2 on Windows Server 2008 and Windows Server 2008 R2. Does this automatically mean that it also works on Windows Server 2012 R2? Should I just follow the guide and install WSUS via console manager or install WSUS 3.0 SP2 via the link you provided?
    Thanks a lot.
  30. I am having an error connectiong with WSUS. Where should start looking at fixing the issue? I followed all of your steps in installing SCCM and the issue that I am having is syncing
    Thank you
      1. I did something that I should have not done. I removed the WSUS role and when I restarted I try to login, I only get the cmd prompt. I’ve tried your steps Switching from Windows Server 2012 Core to GUI, but for some reason I cannot use powershell so I am not able to do the last part. Any ideas if it is fixable?
        Thanks,
  31. Avatar photo Jeff Scharfenberg says:
    I have an issue connecting my SCCM 2012 vm (existing) to my WSUS (existing) server. We don’t wish to do any client updates, as the WSUS server works just fine for that. I only want to update the .wim images monthly so when we push out to new computers we don’t have to run updates and have it go through 100+ updates. Could you assist in any way? I’ve gone over so many configurations and would prefer to not move my WSUS and merge it on the SCCM 2012 vm.
        But since i thought you can merge WSUS with SCCM 2012 you don’t use DISM anymore. that is more for sccm 207. What I am willing to do is make a seperate WSUS on the SCCM 2012 vm and use it only for .wim updates. What are your thoughts on that?
  32. Avatar photo Mallikarjun Rao says:
    we have sccm2012 r2 infrastructure, was planning to do a wsus clean up we do have 3 wsus server one upstream and one downstream is workign fine but another downstream wsus15 fails to connect it says please make sure post-installatio taks is completed successfully in that server and event: The WSUS content directory is not accessible.with error ID 12072, 7000
    need your suggestion on this
  33. Hi Prajwal,
    I forgot to install WSUS before I installed SCCM 2012 R2 SP1. I have install SQL 2014 and SCCM 2012 R2 SP1 on my Virtual Windows Server 2012 R2. When I install SCCM, I named the database name is CM_XYZ. Now I just installed WSUS on the same server (Server 2012R2). It automatically generated database SUSDB in SQL Database. How do I change the database name in SCCM so that I can use SCCM to deploy Windows Updates. I ran synchronization in WSUS and see all the Windows Updates; however, I don’t see anything in SCCM Manager Console. Thank you for your help!
  34. Hi, thank you for the posts. I forgot to install WSUS before install SCCM R2. I have installed SQL 2014, SCCM R2 SP1 on my Windows Server 2012 R2. When I installed SCCM 2012 R2 SP1, the database name CM_XYZ. Now I just installed WSUS, and it automatically generated SUSDB database on my SQL database. How do I change the database in SCCM R2 Manager Console to SUSDB so that I can use SCCM for Windows updates? Thank you for your help!
  35. Avatar photo Aibin T Paskal says:
    Dear Prajwal Desai, i just configured SCCM 2012R2 in my office by following your steps. At the time, when i installed wsus i accidentally configured the wsus configuration wizard. I successfully installed the SCCM but at the time when im trying to deploy updates to systems, it doesn’t install. what can i do next to install updates through wsus? please help me.
  36. Avatar photo qhdevon43 says:
    well once again you’ve helped me connect WSUS to SCCM. It works flawlessly, howevever I did spend about 1 week trying to get it configured properly. Might I suggest that after the very last step where you say to click cancel, thats perfect and all but a very important and crucial step is to open Windows server update services and click on okay, after doing this it syncs up with the SQL server and then after that open up the CMtrace tool and review the wsyncmgr.log and wcm.log to make sure its syncing correctly. Hopes this helps anyone else having the same issue I did.
    1. so if you miss this step how can you get it working? if I open WSUS app and try to ‘connect’ to the server it says that it’s not connected to an SQL database :/ not sure if this is the reason why I cannot get sccm12 r2 to sync with the windows update server (online) at ALL I keep getting errors and it won’t download any updates or anything.
  37. What if I’m installing WSUS on its own server? I imagine you would need the Windows Internal Database since you won’t be using SCCM’s database?
  38. is there a certain reason why i use this backup method instead of windows backup feature ?!
      1. i am referring to windows server backup tools feature that let me backup the whole OS and files if u used it to backup my server do i need to back up SCCM separately ? or if i backup using windows sever backup tools i am set?
        btw i have 1 extra question i am having problem with wsus post configuration 1st of all after i installed it and choose db option instead of wid db i got error in post installation wen trying to connect to it befor showing the wizard i checked the log and the main problem was some thing about index boundary error i think its problem with sql i am not sure tho. after i tired to reinstall 4 times with same error i tried deleting iis site as recommended by some 1 same issue i reinstalled to WID db worked just fine
        so i am not sure how to fix this issue if you have any recommendation i would appreciate it .
        also i had 1 more question if there is anyway to delete the WSUS configuration bec. after i installed WID DB it doesnt show the wizard for configuration it just gets me right into the wsus utility .
        thanks in advance
  39. Avatar photo Flustivus says:
    Are you aware that this page is hosting a malware pest phishing as a “required” “Flash HD Player”? I’ve provided a screen capture for ya.
  40. hi Prajwal cn you tell me sizing for around 300 client running win 7 and 8
  41. Avatar photo Jeremy Densmore says:
    Perfect thank you!
  42. Avatar photo Jeremy Densmore says:
    So following this procedure in step 4, (See Picture) Where does Approval occur now? Or is the need eliminated in sccm 2012 R2 Thanks in advance for any help!
  43. Avatar photo manish nair says:
    installing AD on main server , creating a domain , adding client pcs to this domain
    Isnt the above steps imp b4 setting up a SCCM env ??
    SCCM can work across diff domains , agreed but pls take the simple scenario first !!!!
    2 pcs , one win server and another win 7
    I want sccm server on one and another as sccm client..!!! shudnt both the pcs be connected over n/w , and then shudnt i be creating a domain and addin win7 pc as the client to the domain and then do all the SCCM setting up..!!!!!!
    1. Yes Manish those steps that you mentioned are really important, one cannot proceed without that. The reason why that was not covered is its too basic for a IT person who is deploying SCCM. If you are deploying SCCM then its assumed that you have initial setup ready, if you want me to document and post even that I will do that .. that should not take much time..
      1. Avatar photo manish nair says:
        Not at all!!! i aint questioning you..!!! I just wanted to be very clear abt the n/w part..!!! I have asked these questions in AD grps too but noone seem to hav an exact answer..!!!! tht whether 2 pcs shud b in same nw before joinin them into a common domain !!!i undrstnd it sounds inane..!!! but at d same time, i have got replies like SCCM can handle clients in other domains( trusted relation) , and also can handle clients which r not even connected to any nw or any domain i.e a workgrp pc !!!! thx fr d reply..!!!
  44. Avatar photo manish nair says:
    The blog is quite good…!!! and the pre-req part is similar to other sites but its not clearly mentioned anywhere in any site or blog, why we need to create a SCCM container, why right has to be given ? why wsus is needed? if sccm will handle updates then for wht purpose wsus is needed!!!! Things like whether a domain has to be created b4 all this ?
  45. Avatar photo manish nair says:
    hi bro,
    i added wsus and it was successful. But i cannot see susdb under database in sql 2012 sp1. Is internet needed before adding wsus ? Pls help.
    1. Nope, internet connectivity is not required. Tell me what version of WSUS have you installed ? Is the SQL server installed on same server as SCCM or its a remote server.
        thx for replyin.
        Its server 2012 standard edition. I have only one build. And i am using the trial versions of everythin. Server 2012, sql 2012 sp1 and sccm 2012 r2. Everything is on same machine. I followed all ur links and did d same and everythin was fine till the susdb appearance in sql. My pc name is SCCMServer and domain is lab.com. Hence the window where u entered sccm.prajwal.local, I entered SCCMServer.lab.com. I guess its correct. I am not able to figure out d issue. Is it may be bec sql is in its trial mode!!!! these trial mode apps never work perfectly wid all their features i guess.
            Prajwal, I have taken snapshots in the build after the SQL install stage. I have revereted back to that snapshot few times now and tried installing wsus but to no use. Have tried it many
            times now. What u advice ? Is wsus that an imp thing ? Its just to push the updates , right ? Can i skip it ?
            1. Avatar photo remotefix says:
              There is a bug installing WSUS through server manager. Use poweshell
                1. Avatar photo Jerome Lemaire says:
                  I had the same WSUS issue and I’ve found this tool which automates SCCM Installation.
                2. Hi Prajal,
                  Curretly we are using SCCM 2012 R2 and deploying updates. Now we would like to windows updates in my remote site locations also please suggest what is the procedure and what need to be done. From current place if I deploy updates the internet bandwidth is a probelm. Please suggest ASAP.
                I tried in server 2008 and it was fine..!!! In server 2012, after enabling wsus, there is a reboot and after that, i clicked the wsus notification and went ahead.. and then wsus appeared in sql (altho i kno we shud not configure wsus)…
          2. Avatar photo manish nair says:
            1. WSUS is required if you want SCCM to deploy updates. You can skip it and plan to install it later.
    2. Avatar photo Binarylab says:
      Actually you should run postinstallation but cancel configuration wizard. Databse will not be created if you dont run post installation.
  46. can you change primary site to stand alone primary site
      1. Avatar photo gokul raj says:
        Hi prajwal ,
        I am facing issue when i try to install WSUS
        Error:configuration failed for windows server update services
        My log file:getting this one
        conifguration failed log file was created in C:\user\Administrator\Appdata\Local\Temp\tmp89.
        can you help this one
  47. the Database is SQL 2012 SP1
  48. Hi,
    could you please clarify me.
    * is mandatory to install wsus in Lab environment(Practice)
    Thanks,
    Mohammed
  49. yes one more thing you can open WSUS console but not through SCCM
  50. first of all thanks for your great post I am not sure what is wrong but SCCM 2012 R2 is working fine which installed in windows 2012 R2 and the latest WSUS server version 4 is installed it is synchrization with server is working fine (according to the log ) no error in either WCM log or WSUSCrtl log when you add the update software point the settings button is never appears in the property button only generals and proxy settings appears with common message “for configuration manager to use a software update point that is not installed on the site server on the site server you must install WSUS administration console in the site server”
    the above message in several post it is mention two updates ( KB2720211 & KB2734608) needs to be installed but that for WSUS 3 with SP2 not for WSUS 4 did you have any idea what could be the slotion
    1. Where are you installing SUP role ? Is it on the same server where SCCM and WSUS is installed?
  51. Im using Port 80 and Port 443
    When i checked wht wsyncmgr.log file it states that the
    Found 1 SUPs
    Found active SUP (servername) from SCF file
    DB Server not detected for SUP (servername) from SCF file.skiipping
    Sync failed. WSUS update source not found on site XYZ
  52. I have reviewed the WCM.log and it says” The request failed with HTTP Status 404: Not Found~~at Microsoft.UpdateServices.Administration.AdminProxy. CreateUpdateServer”
    “Remote configuration failed on WSUS Server
    The funny thing is I can successfully open WSUS admin console and see all updates.
    1. What WSUS ports are you using ? Can you also check wsyncmgr.log file for sync errors ?
  53. Wsyncmgr.log file states:
    “Sync failed WSUS update source not found on site XYZ. Please refer to WCM.log for configuration error details. Source: getSiteUpdateSource
    STATMSG:ID=6703
    Sync failed. Will retry in 60 minutes
    1. Have you reviewed WCM.log? When you installed WSUS, did you also create the DB?
      Can you open the WSUS admin console successfully and does it successfully connect to the WSUS DB?
  54. Hi Prajwal,
    I installed successfully installed WSUS and the SUP on my SCCM 2012 R2 server (OS Windows 2012 R2 Datacenter). However, does the SUP role on SCCM 2012 R2 have to be installed on the same server that house the WSUS database(SUSDB installed on remote db server)? I’m asking because Im not able to synchronize software updates from SCCM. Also primary site and database are on separate servers.
    Thanks,
    Paul
    1. hi paul can you post wsyncmgr.log file ? Log file will tell us where the issue is..
  55. Prajwal,
    I removed WSUS, deleted the database, rebooted. installed WSUS and ran the post install configuration. Now WSUS opens normally. How do I now create the WSUS website?
    Tom
  56. Prajwal – First off – great guides. Thanks for posting them. I have a question concerning the WSUS install. In your guide here you advise to cancel the WSUS install before configuring the task. But in your guide on deploying Software Updates, you advise to Create a Windows Server Update Services 3.0 Web site . Can you explain? I didn’t create the Website during the WSUS install, and now the Post Install Task runs in order to open WSUS, but it fails. Here is the error:
    Log file is located at C:\Users\ap-svc-sccm2\AppData\Local\Temp\tmp4F6B.tmp
    Post install is starting
    Fatal Error: The schema version of the database is from a newer version of WSUS
    than currently installed. You must either patch your WSUS server to at least
    that version or drop the database.
    Any thoughts.
    1. what is the server edition that you are using and what version of WSUS have you installed ?
  57. Hi Prajwal,
    I have decided to retire my existing WSUS server go with the SCCM for updates. I’m followed your guide til the end but don’t see SUSDB in my SQL Management Studio after installing WSUS on the same server as SCCM after multiple reboots. Am I missing something? I know I’m not supposed to run the post install configuration, but when I do, I get an error message saying that access to the remote directory is denied. What account should I be granting to the share for WSUS content?
  58. Avatar photo Fahd Mannaa says:
    what about if i have already WSUS in the network ? still i should i add the WSUS server ?
  59. Synchronization failure alert for software update point: sccm.TEST.SCCM.COM (P01)
  60. Avatar photo Arshad Hussain says:
    its ok My windows server 2012 Standard version having 2 L/C Key .That means 4 vm. i remember after i post the comment.
    Best Regards,
    Arshad
  61. Avatar photo Arshad Hussain says:
    Sure. Then i will do best way is Snapshot (no issue data storage we can expand) of each server & try the same .As i done for SCCM 2012 sp1 later deleted the old snapshot of SCCM 2012 SP1.
    one more thing if i am not wrong as i we done before one client site IBM SERVER 360 Series with dual processore ( Raid 5 Config) & loaded os server 2012 Standard Version. Installed 4 VM with one physical host (Servers role: File server, AD 2012, TMG & Symantec Server).
    But i seen one forum of your installtion of windows 2012 standard version supprt only two vm….? kindly let me know where i am wrong…
    Best Regards,
    Arshad
  62. Avatar photo Arshad Hussain says:
    Thank you very Much for your support & Guide Line for the Installtion of wsus, sup Role etc.
    Now My SCCM 2012 sp1 working fine & Push all the 30 servers (out of 55 servers ) Security updates as well as 300 (out of 423)workstation updates.
    i would like to know My SCCM 2012 SP1, SCOM SP1 , SQL DATABASE 2008 R2 (All three servers with windows 2008 R2), kindly let me know if i need to push any recommended windows updates or security patches for all three server. If any mention to me or give the Link.
    Also My all error is vanish form Event Log except Exchange connector (Event id 1020). Now i Escalate to My Exchange admin to veriify or allow proper connector permission to My sccmadmin Account for configure the connector. If Anything othr than this kindly let me know.
    Thanking you in Advance.
    Best Regards,
    Arshad
    1. It is always recommended to install the windows updates on the servers. Since these all are critical servers, you must first create a similar test environment and deploy windows updates on to lab machine /test machine and if the updates do not cause any issues then you can deploy the same updates on the production machines. In some companies the updates are deployed in the second week of every month, before the updates are deployed a full backup of the machine is taken first.
      I would suggest you to have a test environment similar to prod one, test the updates there and then deploy it to prod machines.
  63. Avatar photo arshad hussain says:
    I opened your second link regards to SUP, I DONE ALMOST OPTION for Synchronization sup & wsus…. But still if any tips to my above Mail
    Wsyncmgr.log & WCM.log, & wususctrl. log files for Pre & Post Installtion.
    Best Regards,
    Arshad
  64. Avatar photo Arshad Hussain says:
    Thanks for your link i will check it out.
    My earlier task on sccm 2012 sp1 wsus role installtion done.
    After i taken Two differnet snapshot Beofre &After installtion of wsus.30 with sp1 & two PACTHES.
    NOW WSUS 3.0 WORKING FINE & WINDOWS UPDATE , Synchronization fine
    But thirdy party told me to uinstall sup role as well as wsus 3.0 7 & reinstall it same time
    . after installtion of wsus only i am able to unstall & install the role of SUP for some reason.
    i would like to know , no iusse if i done above steps. or i need to uinstall & install both role same time. .(just installtion not update),
    WSUS take 24 hours to synchrnization with SUP….?
    Install wsus without doing update & install SUP ROLE as well…? then i need to do Later wusu update (synchronization)
    please guide me how to check or update on the configration Console of SCCM 2012 SP1 that SUP synchronizing with WSUS
    otherwise i will try to install again both role same time.
    Best Regards,
    Arshad
  65. Avatar photo Arshad Hussain says:
    If Available ,can you provide me link for sup (Software update point) Remove /add site role steps on SCCM 2012 SP1 (OS WINDOWS 2008 R2).
    Regards,
    Arshad
  66. Hi,
    Thanks for your replay!
    sorry to bother you again. could you please tell me we have already running SCCM 2007 R3 sp2 in our environment, I couldn’t deploy the FEP 2010 in windows 8.1 through SCCM, bcz win8.1 already have a defender on it. even can’t do it with out SCCM. So is that possible with sccm 2012R2.
    I am installing 2012r2 in test environment before deploy it in our network to make sure that everything goes smoothly. I there any thing I need to concentrate before deploy it.
    I am planing to uninstall 2007 completely later and install the new one after testing.
    1. As per Microsoft “We are adding support for Windows Server 2012 R2 and Windows 8.1 in both System Center 2012 Endpoint Protection (includes Service Pack 1 and R2) and Forefront Endpoint Protection (FEP) 2010 with Update Rollup 1 applied. This support and any required updates will be available in the same timeframe as System Center 2012 R2 general availability.”
  67. Hi Prajwal,
    These notes are really helpful, thanks for all you support. would you mind telling me, do I really need to extend schema, the reason I am asking is we don’t hold schema, It managed by our head office IT team, can I able to install and set-up sccm 2012R2 without that?
    Please let me know.
    Kind Regards
    Muzammil
    1. Thank you Muzammil..Extending the active directory schema is optional. Microsoft recommends to extend the schema because it allows clients to retrieve many types of information related to Configuration Manager from a trusted source. If you don’t extend the schema then you might have to work more on managing the clients in your organization such as collection or listing users, computers in your organization. For example when you push the clients using SCCM the clients can locate the management point using active directory domain services and if you don’t extend the schema then you have configure the server locator point.
  68. Avatar photo Arshad Hussain says:
    Prajwal,
    well, even if you use scomadmin account need permissions of the connector or any account connector permission (Privilege) fine. As earlier also I went to that link & details regarding connector permission etc. even I added my exchange server (dns), but my account might not not having that permission .
    But when you try to add exchange server above error The SMS Provider reported an error & with all details description .., then it will go to add menu .. what is the reason for ? we need to correct issue before adding this exchange DNS , not because of my wsus update & synchronization issue..?
    Regards,
    Arshad
  69. Avatar photo Arshad Hussain says:
    ok fine. Our Exchange is 2010 with SP1 , if any let me know
    Regards,
    Arshad
  70. Avatar photo Arshad Hussain says:
    . As we Cross check our configuration in domain part firewall exceptions and open the ports required as you told me, no issue both ports are open. Also our wsus last update was 25/11/20013 . But now just waiting for top management to approve for go head with wsus installation & patches ,once job done I will update you exactly what.
    Mean time I would like to know as I am new to SCCM server from couple of weeks I am trying to configure exchange connector same server but some reason it also come up with below error, is it related above issue only…?can you guide me what to do…
    The SMS Provider reported an error.
    with more Below details
    onfigMgr Error Object:
    instance of SMS_ExtendedStatus
    Description = “ERROR ON Property Convert”;
    ErrorCode = 0;
    File = “e:\\nts_sccm_release\\sms\\siteserver\\sdk_provider\\smsprov\\sspsitesettingitem.cpp”;
    Line = 1028;
    Operation = “ExecQuery”;
    ParameterInfo = “SELECT * FROM SMS_SCI_SCPropertyList WHERE ItemType = ‘SMS_EXCHANGE_CONNECTOR’ AND PropertyListName like ‘ConnectorConfig_%'”;
    ProviderName = “WinMgmt”;
    StatusCode = 2147749917;
    Microsoft.ConfigurationManagement.ManagementProvider.WqlQueryEngine.WqlQueryException
    Stack Trace:
    at Microsoft.ConfigurationManagement.ManagementProvider.WqlQueryEngine.WqlQueryResultsObject.d__0.MoveNext()
    at Microsoft.ConfigurationManagement.AdminConsole.ExchangeConnector.ConnectionPageControl.GetExistingExchanges()
    at Microsoft.ConfigurationManagement.AdminConsole.ExchangeConnector.ConnectionPageControl.InitializePageControl()
    at Microsoft.ConfigurationManagement.AdminConsole.SmsWizardPage.Initialize()
    System.Management.ManagementException
    Unexpected error
    Stack Trace:
    Regards,
    Arshad
    1. Arshad, what version of exchange server (& service pack ) are you using ?
      You need to check the permissions of the connector account and this account must be enabled for remote shell
  71. Avatar photo arsahad hussain says:
    ok fine. I will get back to you
    Regards
    Arshad
    1. Avatar photo Rob GaatJeNixAn says:
      I have a problem: installed WSUS role and Update Point on the SCCM 2012R2 server, not liked it and removed it. Clients now not reporting to WSUS. Uninstalled the WSUS role, installed the WSUS role on another server. Clients still not reporting to WSUS (not even trying according to the windowsupdate.log).
      Found the solution 9for SCCM2007/WSUS3)
      BUT how does this work for me? However the Update Point is uninstalled fromm SCCM I can still configure it (also th ereporting settings). But will this have any effect to the clients?? How ‘reads’ the client this setting?
      Rob Mulder
        Do this on the database:
        UPDATE dbo.tbConfiguration SET Value=’2′ where Name=’ClientReportingLevel’
  72. Avatar photo arshad hussain says:
    ok fine . As I already downloaded WSUS 3.0 SP2 64 BIT FROM MS link ( 84, 737kb) , once I setup wsus 3.0 sp2 then again I need to add the two patches
    Update for Windows Server Update Services 3.0 SP2 (KB2720211)
    Update for Windows Server Update Services 3.0 SP2 (KB2734608
    Please Confirm , Because I added this patches earlier.
    (2) As per your first link I need do all GP Steps. (inbound , file sharing etc.) or WSUS setup do By default.
    Regards,
    Arshad
    1. Yes Arshad once you install WSUS 3.0 SP2, you will have to install those 2 updates as they are prerequisite for installing SCCM 2012 SP1.
      Update for Windows Server Update Services 3.0 SP2 (KB2734608)
      My suggestion is remove the patches and WSUS 3.0 SP2 cleanly. Restart the server, install WSUS 3.0 SP2, install the updates and restart the server once.
      2) Rather than turning off the firewall it is recommended to configure the firewall exceptions and open the ports required for sccm 2012 sp1 client push. Configure the group policies first and then start the WSUS installation.
  73. Avatar photo arshad hussain says:
    My windows server os 2008 R2 with SCCM 2012 SP1,
    then WSUS 3.0 WITH SP2 CORRECT..? as I seen on My program list
    after I taken snapshot of server, I am able to uninstall wsus from remove role, As I told to you earlier that I am unable install from add role it shows some network connectivity issue for update. now I decided to install WSUS Manually & try to update . Please let me know if any…
    Regards,
    Arshad
  74. Avatar photo arshad hussain says:
    Yes I will do that. Do you want me to remove this update Patches also…? along with WSUS
    I would like to know what is main reason of “The SMS Provider reported an error” when we try to create the application. for deploying
    But when I update the patches kb/2734608 & kb/2720211, this SMS Provider error disappear. Earlier also same error then i expand my hard disk space then this error gone.
    I hope after installation of WSUS 3.0 sp2 , I am able to see console, able to create software group, & windows update , synchronization issue & SMS provider error also vanish. Please if any configuration or update need let me know.
    Regards
    Arshad
    1. May I know what server OS are you installing SCCM 2012 R2 ? 2008 R2 or Server 2012 ?
  75. Avatar photo Arshad Hussain says:
    After open wsus service… below display….
    MMC could not create the snap-in. The snap-in might not have been installed
    correctly.
    CLSID: FX:{8b6499ed-0241-e032-6508-da4b1c879d7e}
  76. Avatar photo Arshad Hussain says:
    But when i open WSUS , this error will display
    MMC has detected an error in a snap & will unload it.
    (1)Report this error to Microosft & then shutdown MMC
    (2)UNLOAD THE SNAP-IN & Contniue Running.
    Regards,
    Arshad
  77. Avatar photo Arshad Hussain says:
    Hi Parjwal,
    As My SCCM 2012 SP1 (Server windows 2008 R2), But WSUS Ver 3.0 & also I am not able go to console tree pane
    My server not able synchronize for windows update.(always failed) event id 6703.
    Event ID: 6703 Source: SMS_WSUS_SYNC_MANAGER
    Type: Error
    Description:
    Microsoft.SystemsManagementServer.SoftwareUpdatesManagement.WsusSyncAction.WSyncAction.SyncUpdates
    Failed to sync some of the updates
    4 7:32:48 AM, component SMS_WSUS_SYNC_MANAGER on computer XXXXXXXXXD reported:
    The operating system reported error 2148734208
    then, after taken snapshot , then remove the role of WSUS & Try to add it again, but while try connect for update display with network error, My all ports all open as open & no proxy as well , My browser is working fine. Please guide me why my windows update not working …
    Regards,
    Arshad
    1. Hi Arshad, when you install WSUS for SCCM 2012 you should not use WSUS console because SCCM will manage the deployment of software updates. Check the port settings configured for the active software update point and make sure they are the same as the port settings configured for the Web site used by WSUS running on the active software update point.
  78. Avatar photo Reza Prawirasatya says:
    Per Prajwal:
    WSUS 3.0 Service Pack 2 is required for System Center 2012 R2 Configuration Manager
    FYI, someone responding to me directly from other source: *** This is where people get confused! ***
    * If you are installing using Windows Server 2012 then no because WSUS is version 4 in Server 2012.
    * If installing on Server 2008(R2) then yes, but you should always look to update everything to latest versions anyway.
  79. Avatar photo Reza Prawirasatya says:
    Finally, I got it working.
  80. Avatar photo Reza Prawirasatya says:
    Sorry I forgot to mention, all my test servers are using Windows Server 2012 R2 Standard.
  81. Avatar photo Reza Prawirasatya says:
    Prajwal, Thanks for your great SCCM 2012 R2 blogs! How did you get pass through the error that myself and others experiencing?
    Thanks,
    Reza
    1. Alright, my only question is from where are you installing WSUS ? From Add Roles and Features wizard or by downloading WSUS setup file from Microsoft ? Please note that in the post I am using server 2012 R2 and I have installed WSUS from Add Roles and Features.
  82. Avatar photo steven.parein@gmail.com says:
    You cannot see SUSDB prior to installation of SCCM because you did not configure it and your guide says Once the installation is complete DO NOT click on Launch Post-Installation tasks.
    The screenshot you are showing shows the situation after SCCM has been installed because I can see your CM_IND database.
    Correct me if I’m wrong.
    1. Hi Steven, you are right, the CM_ Database cannot be seen unless you have installed SCCM 2012. I had actually taken the screenshot after installing the Configuration Manager. Thanks for mentioning that, I will update it with appropriate screenshot.. 🙂
  83. I am using SCCM 2012 R2.
  84. Before installing WSUS role – do i need to install WSUS SP2 update on CM2012 server?
    My lab setup
    DC1 – Server 2012 R2
    CM1 – Server 2012 R2 + SQL 2012 SP1 (Planning to install WSUS role as well) after getting your reply to above Q
    Thanks – Excellent material.
    1. You can install WSUS from roles and services in Server 2012 R2, I believe no updates are required. Are you using SCCM 2012 R2 or SCCM 2012 SP1 ?
  85. Avatar photo Kym Busby says:
    Thanks so much for these fantastic guides. I’m following these as I set up a new environment, and they are very helpful.
  86. Hi there,
    With the WSUS server, what server does it need to be installed on? I’m currently running up a lab with seperate Management Point, Distribution Point and SQL Database.
    Thanks in advance.
    1. You can install WSUS on a separate Server or you can install WSUS and SCCM on the same server. In my post I have installed both WSUS & SCCM on same server – windows server 2012 R2 Datacenter edition.
