Skip to content
  • Home
  • Blog
  • Cloud
    • Autopilot
    • Azure
    • Endpoint Analytics
    • Intune
    • PowerShell
    • Teams
    • Windows 365
  • Microsoft
    • Active Directory
    • Group Policy
    • SCCM
    • SCOM
    • Windows 10
    • Windows 11
    • Windows Server
    • WSUS
  • Software
  • Forums
  • Contact
  • Home
  • Blog
  • Cloud
    • Autopilot
    • Azure
    • Intune
    • PowerShell
    • Teams
    • Windows 365
  • Microsoft
    • Active Directory
    • Group Policy
    • SCCM
    • SCOM
    • Windows 10
    • Windows 11
    • Windows Server
    • WSUS
  • Software
  • Forums
  • Contact
Group Policy
Group Policy is a feature of Windows that facilitates a wide variety of advanced settings that network administrators can use to control the working environment of users and computer accounts in Active Directory. It essentially provides a centralized place for administrators to manage and configure operating systems, applications and users’ settings.
How To Enable Remote Desktop Using Group Policy (GPO)
Published on: March 10, 2022 by Prajwal Desai
In this article, you’ll learn how to enable Remote Desktop using Group policy. On Active Directory domain joined computers, you can enable Remote Desktop using GPO. Remote desktop is an operating system feature that allows …
Continue Reading
6 Best Ways to Disable Cortana in Windows 11
Last Updated on: March 14, 2022 by Prajwal Desai
This article explains how you can disable Cortana in Windows 11 using different methods. You can disable the Cortana in Windows 11 or even uninstall it if you don’t use it. Cortana in a cloud-based …
Continue Reading
Turn Off Windows Mobility Center using Intune or GPO
Last Updated on: February 18, 2022 by Prajwal Desai
In this post, I will show you how you can turn off Windows Mobility center using Intune or GPO. You can use any of these methods to disable the Windows Mobility Center on your computers. …
Continue Reading
Disable Check for Updates using Group Policy (GPO)
Published on: December 6, 2021 by Prajwal Desai
This article explains how you can disable Check for Updates using Group Policy. To prevent users from manually downloading updates from Microsoft, you can disable the check for updates button. Most organizations today use Configuration …
Continue Reading
Best Way to Disable Advertising ID using GPO
Last Updated on: January 24, 2022 by Prajwal Desai
Turn Off or Disable Advertising ID
In this guide, I will walk you through the steps to disable advertising ID using GPO (Group Policy). There are multiple ways with which you can stop targeted ads on your Windows 11 computer. We …
Continue Reading
4 Unique Ways to Disable Windows Spotlight
Published on: September 21, 2021 by Prajwal Desai
You can disable Windows Spotlight using 4 ways – locally, registry, group policy and Intune (MEM). We will look at multiple methods to turn off or disable the Windows Spotlight features. First, we will understand …
Continue Reading
Configure PUA Protection using Group Policy
Published on: August 25, 2021 by Prajwal Desai
In this article, I will show you the steps to configure PUA protection using group policy. We will enable the policy Configure detection for potentially unwanted applications. You can enable or disable detection for potentially …
Continue Reading
4 Unique Methods to Disable Microsoft Store
Published on: July 14, 2021 by Prajwal Desai
Disable Microsoft Store Application
You can disable Microsoft store using multiple methods. In this post, I will show you how to turn off Microsoft Store application using Registry, PowerShell, Locally and Group Policy. What is Microsoft store? The Microsoft …
Continue Reading
Post navigation
Older posts
Page1 Page2 … Page6 Next →
Sponsored AD
Pulseway Banner
© Copyright 2022 All Rights Reserved | Prajwal Desai | Privacy Policy
Next Page »
