SCCM | ConfigMgr | Intune | Windows 11 | Azure
  • Home
  • Cloud
    • Autopilot
    • Azure
    • Endpoint Analytics
    • Intune
    • PowerShell
    • Teams
    • Windows 365
  • Microsoft
    • Active Directory
    • Group Policy
    • SCCM
    • SCOM
    • Windows 10
    • Windows 11
    • Windows Server
    • WSUS
  • Software
  • Forums
  • Newsletter
  • Contact
Notification Show More
Latest News
Fix Windows Autopilot Reset Error 0x80070032
Autopilot Intune
Windows activation error 0xc004c020
Fix: Windows Activation Error 0xC004C020 with 2 Easy Methods
Windows 11 Windows 10
Find the Package ID of SCCM Application
3 Best Ways to Find the Package ID of SCCM Application
SCCM
SCCM Updates Install Error 0x800b0109 0x8024b303
Fix: SCCM Updates Install Error 0x800b0109 | 0x8024b303
SCCM
Disable Windows Hello for Business using Intune ftimg
Disable Windows Hello for Business using Intune – Comprehensive Guide
Intune Autopilot
Aa
Aa
Search
  • Home
  • Cloud
    • Autopilot
    • Azure
    • Intune
    • PowerShell
    • Teams
    • Windows 365
  • Microsoft
    • Active Directory
    • Group Policy
    • SCCM
    • SCOM
    • Windows 10
    • Windows 11
    • Windows Server
    • WSUS
  • Software
  • Forums
  • Newsletter
  • Contact
Follow US
Home » SCCM » Create Deploy Microsoft Edge Using SCCM – SCCM TP 1910
SCCM
By Prajwal Desai 1 View 12 comments October 22, 2019 3 Min Read
In SCCM technical preview 1910, you can create and deploy Microsoft Edge application. As per Microsoft you can deploy Microsoft Edge version 77 and later to your users. By the way the Configuration Manager Technical preview 1910 is released and take a look at new features here.
When I got to know that we can deploy Edge application using SCCM, I was excited to test the feature because prior to this I was unable to deploy Edge application using SCCM.
While creating the Edge application, the admins can pick either the Beta or Dev channel, along with a version of the Microsoft Edge client to deploy. To know more about Microsoft Edge insider channels, read this post.
Note – The Create Microsoft Edge application is a new feature introduced with SCCM technical preview 1910 . This feature is not available in current branch version yet. But I would love to see this feature in the upcoming SCCM 1910 release.
- Advertisement -
Ad image
Create and Deploy Microsoft Edge Using SCCM
Use the following steps to create and deploy Microsoft Edge application in SCCM.
  • In the SCCM Console, go to Software Library > Overview > Microsoft Edge Management.
  • Right click Microsoft Edge Management and click Create Microsoft Edge Application.
  • Follow the installation wizard to deploy Microsoft Edge application.
Under Application Settings, specify the application name, description and content location. Click Next.
Under Microsoft Edge client settings, select the Channel (Beta or Dev). Next, select the Microsoft Edge version to deploy. You can select the latest version or click Specific Version and manually select the version.
Select the build and version
Choose if you want to deploy application now or later. Click Next.
deploy the edge application
To target the application, click Browse and select a device collection. Click Next.
Select Device Collection
Add your distribution points or distribution point groups to distribute the content. Click Next.
Select Distribution Point
Deployment Settings – Choose the deployment action and purpose. Click Next.
Deploy the application as Available
Finally on the completion page, click Close.
Completion
On the client computer, launch Software Center. Click Applications and select Microsoft Edge application. To install the Edge app, click Install.
Install Microsoft Edge
The Edge application installation is successful.
If the Edge application install fails or if you need to monitor the application installation, open AppEnforce.log file on the client computer.
appenforce log file
Troubleshooting Tip – While deploying the Edge application in SCCM, I noticed Unmatched exit code (1) is considered an execution failure in AppEnforce.log file. This happens if the Powershell Execution Policy is set to Restricted. The product team is aware of this issue.
Sign Up For Weekly Newsletter
Get the most recent information on Configuration Manager, Intune, Windows 11, Windows 365, Autopilot, Azure, Software Reviews, and much more by subscribing to the newsletter.
By signing up, you agree and acknowledge the data practices in our Privacy Policy. You may unsubscribe at any time.
Share this Article
Facebook Twitter Copy Link Print
Avatar photo
By Prajwal Desai
Follow:
Prajwal Desai is a Microsoft MVP in Enterprise Mobility. He writes articles on SCCM, Intune, Configuration Manager, Microsoft Intune, Azure, Windows Server, Windows 11, WordPress and other topics, with the goal of providing people with useful information.
Previous Article sccm tp 1910 ftimg SCCM Technical Preview 1910 New Features
Next Article Deploy Microsoft Edge using SCCM How to Deploy Microsoft Edge using SCCM | ConfigMgr
12 Comments 12 Comments
  • Avatar photo Justin watson says:
    January 30, 2020 at 6:35 am
    So my issue is I work in an environment where execution policy is enforced to Allsigned. I had hoped by signing the PS script with our signing certificate, it would have worked, but it doesn’t. I don’t think execution policy bypass will work in this instance either, but I’ll try it now. I guess alternative is to deploy the MSI and use GPOs to do what the script does?
    Reply
    • Avatar photo Prajwal Desai says:
      January 30, 2020 at 12:38 pm
      That’s right, when you create the Edge application in the console, it deploys a PowerShell script and it doesn’t install if the execution policy is restricted or All signed. What you can do is use the MSI installer and push it to your enterprise machines.
      Reply
  • Avatar photo Mike Fredette says:
    January 29, 2020 at 6:21 am
    Is there a way to have this remove the old HTML5 Edge as well? I wind up with two versions of Edge on my computer using the MSI, where the exe removes the old one.
    Maybe I’m missing something?
    Reply
  • Avatar photo Bob Wilkerson says:
    January 18, 2020 at 12:28 am
    So how do we deploy this if the execution policy is restricted? Can we just add -Execuationpolicy Bypass to the installation script in the deployment?
    Reply
      January 18, 2020 at 12:12 pm
      That’s correct. For now you can add the -executionpolicy bypass. I have reported this to Microsoft team and they will be fixing this soon.
      Reply
  • Avatar photo brachus says:
    January 17, 2020 at 12:12 am
    Can you deploy this to a USER collection? Or just DEVICE collections?
    Reply
  • Avatar photo Rick Warner says:
    January 16, 2020 at 5:06 pm
    If you want to install without allowing Powershell free reign on your network you can go to the Deployment Type -> Programs and change the installation program to :
    powershell -ExecutionPolicy Bypass -Command “&'”.\Install-Edge.ps1″‘” -MSIName “MicrosoftEdgeDevEnterpriseX64.msi” -ChannelID “{xxxx-xxxx-xxxx-xxxx-xxxx}”
    ( I blanked out the Channel ID as I’m not sure whether it’s version or site specific ).
    Reply
    • Avatar photo Ken Korczynski says:
      January 23, 2020 at 6:42 am
      This command doesn’t seem to work. I get a “Invalid command line, quotes not properly closed in the command line” error.
      Reply
        January 23, 2020 at 8:12 am
        I found that this works. powershell -executionpolicy bypass -File “.\Install-Edge.ps1” -MSIName “MicrosoftEdgeEnterpriseX64.msi” -ChannelID “{56eb18f8-b008-4cbd-b6d2-8c97fe7e9062}”
        Reply
          January 25, 2020 at 2:19 am
          Yes the execution policy has to be Bypass to install edge.
          Reply
  • Avatar photo Raul Sejas says:
    January 10, 2020 at 8:41 pm
    In my lab collection, when i try to install i receive the following message “Unmatched exit code (1) is considered an execution failure.”, if i run the Set-ExecutionPolicy -executionpolicy unrestricted, then the installation is succesfully, if i try to modify the PS script, the signature was fail, how can i install the EDGE browser using SCCM then?
    Reply
  • Avatar photo Zach Litton says:
    October 24, 2019 at 7:30 am
    Why? Why would you want to do this? So many improvements could be made to SCCM like updating drivers and firmware. Create driver packs for specific models have the SCCM check the manufacturer for updates to those drivers. You can select which ones to update and then immediately deploy to existing equipment. Why not integrate Office Telemetry with SCCM? But now they are pushing everything to Azure account. Deploy a browser that is preinstalled on the OS.
    Reply
Leave a Reply Cancel reply
Recast Sponsored AD
Ad image
Patch My PC Sponsored AD
Ad image
Latest Articles
Autopilot Intune
SCCM
SCCM
Subscribe to Our Newsletter
Subscribe to our newsletter to get our newest articles instantly!
You Might Also Like
SCCM
By Prajwal Desai
SCCM
By Prajwal Desai
Deploy WinSCP using Intune
Intune
Step-by-Step Guide to Deploy WinSCP using Intune (Win32 App)
By Prajwal Desai
Removed from reading list
Undo
Welcome Back!
Sign in to your account
Lost your password?
