SCCM Client Install Error Codes and Solutions
The goal of this post is to provide a comprehensive list of SCCM client install error codes along with their descriptions and solutions to assist you in resolving client installation issues on Windows devices.
As a Configuration Manager administrator, I often encounter client installation failures, and identifying the error code is essential for diagnosing the root cause. I have seen most users in the SCCM community forum report about ccmsetup errors, so this guide is designed to provide quick solutions for anyone facing client installation issues.
Many ccmsetup error codes can be confusing as they neither provide clear resolutions nor explain the root cause of the issue. However, through personal troubleshooting experience and insights from other SCCM MVPs, most solutions have been identified and resolved.
From what I know, the SCCM client error codes are classified into types: HRESULT error codes and non-HRESULT error codes. The HRESULT codes are hexadecimal error codes that provide more detailed information about what went wrong during the installation process. Whereas non-HRESULT codes are simplified error codes that typically appear in CCMSetup with numerical values.
Converting CCMsetup error codes to descriptions
SCCM Log files are crucial in finding out the actual error codes for client installation failures, especially the ccmsetup.log. In addition to that, I would also recommend reading the guide on how to translate SCCM error codes to descriptions.
The table below references a Microsoft article that outlines all error codes along with their corresponding meanings and solutions. It includes HRESULT, non-HRESULT, and common ccmsetup error codes.
Error CodeDescriptionSolutions
2The system cannot find the file specifiedThis issue arises from missing files or the failure to locate essential files required for client installation.
5Access deniedThis occurs because the ccmsetup process does not have the required administrative permissions to complete its actions.
7Reboot RequiredThe ccmsetup needs a reboot to complete the installation.
8Setup Already RunningThis error is seen when another instance of ccmsetup is already running on a device.
9Prerequisite evaluation failureEnsure all prerequisites for SCCM client installation are properly configured.
10Setup manifest hash validation failureThe ccmsetup files appear to be corrupted. Please retrieve fresh client installation files from the site server.
52You were not connected because a duplicate name exists on the network.The issue is likely related to DNS, as the client has duplicate entries in the DNS records.
53Unable to locate or cannot connect to admin$ or Computer Browser not started.To fix this issue, enable File and Print Sharing in the Firewall’s Exceptions list and ensure File and Print Sharing is activated within the firewall settings.
58The specified server cannot perform the requested operation.The required network share is inaccessible during client deployment, often due to a lack of administrative privileges or network connectivity issues.
64The specified network name is no longer available.This suggests an issue with network connectivity or access to a shared resource, potentially occurring during the installation of the Configuration Manager client.
67Network name cannot be foundThis issue usually arises from DNS or name resolution problems, disabled network services such as Remote Registry, or the absence of File and Printer Sharing for Microsoft Networks on the client machine.
86Network configuration problemEither the network password is incorrect, or SCCM is unable to resolve the client name.
112Not enough disk spaceThe SCCM client requires about 100 MB to 500 MB of disk space for the core installation and associated components.
1003Cannot complete this functionThis error occurs due to a misconfigured management point, a corrupted WMI repository, or improper boundary group settings.
1053The service did not respond to the start or control request in a timely fashionA Windows service did not start within the expected timeframe, potentially caused by service dependencies, inadequate permissions, or incorrect registry configurations.
1068The dependency service or group failed to startA service essential for the CCMSETUP process failed to start, likely due to a dependent service being stopped or incorrectly configured.
1130Not enough server storage is available to process this command.Ensure the target client machine has enough free disk space, especially in the temp directory.
1203The network path was either typed incorrectly, does not exist, or the network provider is not currently available. Please try retyping the path or contact your network administrator.Either the network path doesn’t exist, or the network provider is unavailable.
1208An extended error has occurredThis error may occur due to network connectivity issues, insufficient permissions, corrupted files, insufficient disk space, or issues with the WMI.
1396Logon Failure: The target account name is incorrect.The issue is likely related to DNS, as the client has duplicate entries in the DNS records.
1450Insufficient system resources exist to complete the requested service.A generic error that mostly indicates the disk space issues or less memory on the client computer. Review the ccmsetup requirements.
1603CCMExec could not be stoppedThe ccmsetup installer is being interrupted by another component. Exit code 1603 is resolved here.
0000052eNetUseAdd failed: 1326: dwParamError = 0Solution to ccmsetup error 0000052e.
00000005Trying each entry in the SMS Client Remote Installation account listRefer to the guide on resolving ccmsetup error code 00000005.
800706BAUnable to connect to WMI on remote machineRead the guide to fix SCCM Client Push Error 0x800706ba.
80200010A recoverable error has occurred. A retry attempt will be made.Refer to the guide on ccmsetup error 80200010.
80200014BITS job creation failed with 80200014.This operating system does not contain the correct version of BITS. BITS 2.5 or later is required. Read this Solution.
80041001Setup was unable to create the WMI namespace CCM.Repair WMI on the problematic client computer.
80041002Setup was unable to register the CCM_Service_HostingConfiguration endpoint.Read the solution to ccmsetup error code 80041002.
8004100eFailed to revoke client upgrade local policy.Solution
8004103BUnable to create the WMI NamespaceOccurs when the workstation is low on disk space. Clear the temp files and reboot the computer to continue with installation.
80041010Failed to revoke client upgrade local policy.Fix for ccmsetup error 80041010.
80070070Setup failed due to unexpected circumstances.Occurs due to disk space issues. Solution.
80070005Unable to connect to WMI on remote machine “Computer”, error = 0x80070005.Ensure that SCCM has administrative access to each workstation where the client installation is required.
80080005Server execution failedSolution
80004004Operation abortedRestart the computer and try the ccmsetup installation.
87D0029ECCMSetup FailedSolution
87d00227Failed to get assigned site from AD. No valid source or MP locations.Solution
2147023174The RPC server is unavailableEnsure the firewall or antivirus isn’t blocking the client installation.
2147024891Access is deniedMake sure SCCM has admin account on every workstation where it wants to install client.
2147749889Generic WMI failure (Broken WMI)Repairing the WMI resolves this issue.
2147749890Not found – Source: Windows Management (WMI)Repairing the WMI resolves this issue.
2147749904Invalid class – Source: Windows Management (WMI)Repairing the WMI resolves this issue.
2147749908Initialization failure – Source: Windows Management (WMI)Repairing the WMI resolves this issue.
2147942405Access is DeniedCreate a new firewall rule allowing the client installation. Ensure McAfee-HIPS is configured to allow ccmsetup installation.
2147944122The RPC server is unavailableThis error arises due to incorrect security configuration in DCOM.
2148007941Server Execution FailedThis suggests a potential component-related problem on the SCCM site server or a network connectivity issue.
Note: If the table above does not include a specific ccmsetup error code or client installation error code, feel free to mention it in the comments section. I will update the table accordingly, which will also assist other readers.
