Configuration Manager Firewall Ports
List of all Configuration Manager Firewall Ports
This guide includes a list of all the firewall ports used in Configuration Manager. To make it easier to understand, I have grouped the SCCM firewall ports according to the components, roles, and the direction in which they must be opened.
When you plan to install Configuration Manager, you need to be aware of the network ports that every component and role requires or uses. The roles such as management point, software update points, distribution points require certain pre-defined ports to be allowed on the firewall.
For example, SCCM client push firewall ports are different from the ones required by the Configuration Manager console. Therefore you should only permit specific ports and programs required by these roles on a firewall. Turning off the firewall or disabling it on clients or site servers is not recommended, as opening all ports creates potential entry points for attackers.
Over the years, Microsoft has removed and deprecated features for Configuration Manager. Some of them include site system roles for on-premises MDM and macOS clients, enrollment proxy and enrollment point, asset intelligence, and so on. You don’t have to open the ports for these roles as they are not used anymore.
Configurable vs Non-Configurable ports
Configuration Manager clients and site systems make use of a number of network ports, some of which are configurable while some of them are not configurable. Some connections allow you to specify custom ports but there are very few.
Microsoft advises you to check if these ports can be configured if your organization uses any port filtering technology. Some examples of these port filtering technologies include firewalls, routers, proxy servers, or IPsec.
Ports that you can configurePorts that cannot be configured
Client-to-site systems that run IISSite to site
Client to internet (as proxy server settings)Site server to site system
Software update points to internet and WSUSConfiguration Manager console to SMS Provider
Site server to site database server & WSUS database serverConfiguration Manager console to the internet
Reporting services pointsConnections to cloud services, such as Microsoft Azure
Firewall Ports used by SCCM Clients
The table below lists all the ports used by clients for communicating with other ConfigMgr components, along with the port number, protocol and the direction of the communication.
The direction of communication is represented using an arrow icon:
Indicates one-way communication, which means the communication starts from source and the destination computer responds.
Indicates that communication can start from either source or destination.
SourceDestinationProtocol and Port NumberDescriptionDirection of Communication
ClientClientUDP 25536Wake-up-proxyClient Client
ClientClientUDP 9Wake on LANClient Client
ClientClientUDP 8004Windows PE Peer cache broadcastClient Client
ClientClientTCP 8003Windows PE Peer cache downloadClient Client
ClientCloud Distribution PointTCP 443HTTPSClient Cloud DP
ClientNetwork Device Enrollment ServiceTCP 80
TCP 443
HTTP
HTTPS
Client NDES
ClientCloud Management GatewayTCP 443HTTPSClient CMG
ClientDistribution Point and Pull DPTCP 80
TCP 443
TCP 8005
HTTP
HTTPS
Express Updates
Client DP, Pull DP
ClientDistribution Point with Multicast and Pull DPTCP 445
UDP 63000 – 64000
SMB
Multicast Protocol
Client DP, Pull DP
ClientDistribution Point with PXEUDP 67, 68
UDP 69
UDP 4011
UDP 547
DHCP
TFTP
BINL
DHCPv6
Client DP, Pull DP
ClientFallback Status PointTCP 80HTTPSClient FSP
ClientGlobal Domain ControllerTCP 3268Global catalog LDAPClient DC
ClientManagement PointTCP 10123
TCP 80
TCP 443
Client Notification
HTTP
HTTPS
Client MP
ClientSoftware Update PointTCP 80 or 8530
TCP 443 or 8531
HTTP
HTTPS
Client SUP
ClientState Migration PointTCP 80
TCP 443
TCP 445
HTTP
HTTPS
SMB
Client SMP
SCCM Client Push Firewall Ports
The below table lists all the ports that are used with client push installation.
SCCM ServerClientTCP 445SMBSCCM Server Client
SCCM ServerClientTCP 135
UDP 135
RPC Endpoint MapperSCCM Server Client
SCCM ServerClientTCP DynamicRPC Dynamic PortsSCCM Server Client
ClientManagement PointTCP 80
TCP 443
HTTP
HTTPS
Client Management Point
Firewall Ports used by Site Server
The table below lists all the SCCM firewall ports used by site servers for communicating with other ConfigMgr components, along with the port number, protocol and the direction of the communication.
Site ServerClientUDP 9Wake on LANSite Server Client
Site ServerCloud DPTCP 443HTTPSSite Server Cloud DP
Site ServerDistribution PointTCP 445
TCP, UDP 135
RPC Dynamic
SMB
RPC Endpoint Ephemeral port
Site Server SCCM DP
Site ServerDomain ControllerTCP, UDP 389
TCP, UDP 636
TCP 3268
RPC 135
RPC Dynamic
LDAP
Secure LDAP
GC LDAP
RPC Endpoint
RPC Ephemeral
Site Server DC
Site ServerCMG connection pointTCP 445
TCP, UDP 135
RPC Dynamic
SMB
RPC Endpoint
RPC Ephemeral
Site Server CMG
Site ServerEndpoint Protection PointTCP 445
TCP, UDP 135
RPC Dynamic
SMB
RPC Endpoint
RPC Ephemeral
Site Server EPP
Site ServerFallback Status PointTCP 445
TCP, UDP 135
RPC Dynamic
SMB
RPC Endpoint
RPC Ephemeral
Site Server FSP
Site ServerInternetTCP 80
TCP 443
HTTP
HTTPS
Site Server Internet
Site ServerIssuing CATCP, UDP 135
RPC Dynamic
RPC Endpoint
RPC Ephemeral
Site Server CA
Site ServerContent Library ShareTCP 445SMBSite Server Content Library
Site ServerService Connection PointTCP 445
TCP, UDP 135
RPC Dynamic
SMB
RPC Endpoint
RPC Ephemeral
Site Server SCP
Site ServerReporting Services PointTCP 445
TCP, UDP 135
RPC Dynamic
SMB
RPC Endpoint
RPC Ephemeral
Site Server RSP
Site ServerSite ServerTCP 445SMBSite Server Site Server
Site ServerSQL ServerTCP 1433SQL over TCPSite Server SQL Server
Site ServerSQL Server for WSUSTCP 1433SQL over TCPSite Server SQL WSUS Server
Site ServerSMS ProviderTCP 445
TCP, UDP 135
RPC Dynamic
SMB
RPC Endpoint
RPC Ephemeral
Site Server SMS Provider
Site ServerSoftware Update PointTCP 445
TCP, UDP 135
RPC Dynamic
TCP 80 or 8530
TCP 443 or 8531
SMB
RPC Endpoint
RPC Ephemeral
HTTP
HTTPS
Site Server SUP Server
Site ServerState Migration PointTCP 445
TCP, UDP 135
SMB
RPC Endpoint Mapper
Site Server State Migration Point Server
Management Point Network Ports
Here is a list of network ports that the Management Point server requires for communication with other components. Make sure your firewall allows these ports.
Management PointDomain ControllerTCP, UDP 389
TCP, UDP 636
TCP 3268
TCP 135
LDAP
Secure LDAP
GC LDAP
RPC Endpoint Mapper
Management Point Domain Controller
Management PointSite ServerTCP 135
TCP 445
RPC
RPC Endpoint
SMB
Dynamic
Management Point Site Server
Management PointSQL ServerTCP 1433SQL over TCPManagement Point SQL Server
Software Update Point Firewall Ports
The table below lists all the SCCM firewall ports used by the software update point role.
Software Update PointInternetTCP 80HTTPSUP Internet
Software Update PointWSUS ServerTCP 80 or 8530
TCP 443 or 8531
HTTP
HTTPS
SUP WSUS
Ports used by Configuration Manager console
The table below lists all the firewall ports used by the Configuration Manager console for communicating with other components, along with the port number, protocol and the direction of the communication.
ConfigMgr ConsoleClientTCP 2701
TCP 3389
Remote Control
Remote Assistance
Console Client
SCCM ConsoleInternetTCP 80 or 8530
TCP 443 or 8531
HTTP
HTTPS
Console Internet
SCCM ConsoleReporting Services PointTCP 80
TCP 443
HTTP
HTTPS
Console RSP
ConfigMgr ConsoleSite ServerTCP 135RPCConsole Site Server
ConfigMgr ConsoleSMS ProviderTCP, UDP 135
RPC Dynamic
TCP 443
RPC EP Mapper
RPC
HTTPS
Console SMS Provider
Ports used by Service Connection Point
The table below lists all the firewall ports used by the Service Connection Point for communicating with other components.
Service Connection PointAzure CMGTCP 443HTTPSService Connection Point CMG
Service Connection PointAzure Logic AppTCP 443HTTPSService Connection Point Azure Logic App
Service Connection PointSQL ServerTCP 1433SQL over TCPService Connection Point SQL Server
CMG Connection Point Ports
The table below lists all the firewall ports used by the CMG Connection Point in Configuration Manager.
CMG Connection PointCMG virtual machine scale setTCP 443
TCP 10124-10139
HTTPS (1 VM)
HTTPS (2+ VMs)
CMG Connection Point CMG virtual machine scale set
CMG Connection PointCMG classic cloud serviceTCP 10140-10155
TCP 443
TCP 10124-10139
TCP-TLS
HTTPS fallback (1 VM)
HTTPS fallback (more than 1 VM)
CMG Connection Point CMG classic cloud service
CMG Connection PointManagement pointTCP 80
TCP 443
HTTP
HTTPS
CMG Connection Point Management point
CMG Connection PointSoftware update pointTCP 80/8530
TCP 443/8531
HTTP
HTTPS
CMG Connection Point SUP
SCCM Distribution Point Firewall Ports
A distribution point requires the following network ports to be opened in the firewall.
Distribution PointManagement PointTCP 80
TCP 443
HTTP
HTTPS
Distribution Point Management Point
Pull DPSource DPTCP 80
TCP 443
HTTP
HTTPS
Pull DP Source DP
Endpoint Protection Role Ports
If you have set up the Endpoint Protection role in SCCM, this role uses the following firewall ports.
Endpoint Protection RoleInternetTCP 80HTTPEndpoint Protection Role Internet
Endpoint Protection RoleSQL ServerTCP 1433SQL over TCPEndpoint Protection Role SQL Server
SQL Server Firewall Ports
The SQL server for Configuration Manager does require a few network ports to operate. For example, the Intersite database replication requires the SQL Server at one site to communicate directly with the SQL Server at its parent or child site.
SQL ServerSQL ServerTCP 1433SQL Server ServiceSQL Server SQL Server
SQL ServerSQL ServerTCP 4022SQL Service BrokerSQL Server SQL Server
Reporting Services PointSQL ServerTCP 1433SQL over TCPReporting Service Point SQL Server
SMS ProviderSQL ServerTCP 1433SQL over TCPSMS Provider SQL Server
State Migration PointSQL ServerTCP 1433SQL over TCPState Migration Point SQL Server
Ports used by Discovery Methods in SCCM
The following Configuration Manager firewall ports are used for the discovery and publishing of site information:
Protocol NamePort Number
Lightweight Directory Access Protocol (LDAP)389
Global Catalog LDAP3268
Secure LDAP636
RPC Endpoint Mapper135
RPC Dynamic Ports1024:5000 and 49152: 65535
