Configuration Manager 2002 Hotfix Rollup KB4560496
Configuration Manager 2002 Hotfix Rollup KB4560496 is out. This hotfix rollup update includes close to 30 fixes and replaces previously released updates.
The Configuration Manager 2002 Hotfix Rollup KB4560496 update should be available in the Updates and Servicing node of the Configuration Manager console.
If you don’t see the hotfix, in the SCCM 2002 console, go to Updates and Servicing node and click Check for Updates.
About SCCM 2002 Hotfix Rollup KB4560496
The Configuration Manager 2002 Hotfix Rollup KB4560496 update includes.
  • Customers who opted in through a PowerShell script to the early update ring deployment.
  • Customers who installed the globally available release.
The KB4560496 update replaces the following previously release updates.
  • KB4553501 – Update for Microsoft Endpoint Configuration Manager version 2002, early update ring
  • KB4563473 – Update rollup for Configuration Manager version 2002 tenant attach issues
  • KB4567007 – PXE Boot failures or task sequence delays after updating to Configuration Manager current branch, version 2002
This update applies to new installations of SCCM 2002 from baseline media, as well as installations from packages that have the following package GUIDs :-
  • AA9975F2-160A-4910-A698-B7A4AF35D727
  • B39BBA45-E1F0-4233-971E-BB66EB25359D
  • 382F6B53-9217-47CB-9852-7A53232EC80D
  • 0808D0BA-B36F-4719-BD10-08585C1B8B3E
  • AA09154F-56FB-449D-8009-5BBB7C23CB4F
  • C427C4F5-6967-4B64-86BC-DEC9E0F201CC
  • 06F89B19-5A8B-460E-A7F4-6CC0E86A1FC6
  • A680BEFC-783A-49FC-8FAF-1AADB2A7EE84
Issues Fixed in SCCM 2002 Hotfix Rollup KB4560496
Some of the issues fixed in SCCM 2002 Hotfix Rollup KB4560496 update includes –
  • The option to schedule updates is unavailable during offline servicing for Windows Server, version 2004.
  • When talking to SCCM Cloud Management Gateway, Hybrid Azure Active Directory domain joined clients are detected as Intranet clients.
  • Users are unable to submit feedback from the Configuration Manager console when using a Japanese version of the operating system.
  • After changing Enable third party software updates to “Yes” in client settings, clients perform an extra group policy update on startup resulting in increased load on domain controllers.
  • The SetupComplete.cmd window is now hidden during Windows 10 upgrade task sequences.
  • Co-management node setting deletion in SCCM console makes the console unexpectedly grayed out and unavailable.
  • Content download for updates may fail when Allow clients to download delta content when available is enabled in client software update settings.
  • The co-management pilot process generates extraneous policy updates on Configuration Manager clients.
  • Fixes an issue where clearing Use a boot image option from the properties of a task sequence didn’t work as expected.
  • Change in local time zone setting leads to SMS Agent Host service (ccmexec.exe) high CPU utilization on client computers.
  • Configuration Manager console hangs when you open automatic deployment rules (ADR) with multiple languages selected.
  • After updating to Configuration Manager current branch, version 2002, client policy data may fail to apply.
  • An operating system upgrade task sequence does not resume after the target computer restarts. This occurs when the task sequence incorrectly tries to take the client out of provisioning mode. Errors resembling the following are recorded in the TSAgent.log file.
Could not execute WMI method SMS_Client.SetClientProvisioningMode
Failed to put client out of provisioning mode (0x800706BE)
For complete list of fixes included with Hotfix Rollup KB4560496, refer the following post – https://support.microsoft.com/en-in/help/4560496/update-rollup-for-microsoft-endpoint-configuration-manager-version-200.
ConfigMgr 2002 Hotfix KB4560496 Prerequisite Check
It is a good practice to run a prerequisite check before installing the hotfix KB4560496 on your SCCM server running in production.
Right click Configuration Manager 2002 hotfix rollup KB4560496 and click Run Prerequisite check.
SCCM 2002 Hotfix KB4560496 prerequisite check
All you need to do is go to Monitoring workspace and monitor the update pack installation status. I got one warning Site Database has a backlog of SQL Change Tracking Data. This can be ignored because it’s not going to interrupt the update install.
Install Configuration Manager 2002 Hotfix Rollup KB4560496
To install Microsoft Endpoint Configuration Manager 2002 Hotfix KB4560496.
  • Go to Administration\Overview\Updates and Servicing node.
  • Right-click Configuration Manager 2002 Hotfix Rollup KB4560496 and click Install Update Pack.
Install Configuration Manager 2002 Hotfix KB4560496
The SCCM 2002 hotfix KB4560496 contains :-
  • Configuration Manager site server updates.
  • Configuration Manager console and site updates.
Finally on the Completion page, click Close.
Completion Step
Completion Step
Monitor the SCCM 2002 update KB4560496 installation in Monitoring workspace.
Monitor Hotfix update rollup KB4560496
Click OK to upgrade the Configuration Manager 2002 console. The old console version (5.2002.1083.2000) will be replaced with new version of console (5.2002.1083.2900).
ConfigMgr 2002 Hotfix KB4560496 console upgrade
You must upgrade the client agents to latest version (5.00.8968.1042). Use the client upgrade option under site hierarchy settings.
After you install this Configuration Manager 2002 Hotfix Rollup KB4560496 on a primary site, pre-existing secondary sites must be manually updated. To update a secondary site, click Administration > Site Configuration > Sites > Recover Secondary Site > select the secondary site.
9 Comments
  1. I noticed that after the update installed successfully on the primary site, the build numbers of the primary site did not change (the console version did). Under Sites all the sites show the same version as they did before I installed this hotfix, is that normal? Is it just major updates like going from 2002 to 2006 that would show a difference in site version?
  2. Avatar photo Alejandra Reyna says:
    Hello, can you help me? I upgraded sccm to 2002, after upgrade finished console does not show device collections, “No items found”. I don’t see default collections. “All Systems”, “All Desktop and Servers Clients”, etc.
  3. Can anyone help me how to install the KB updates through SCCM, it doesn’t come up in the Software Updates although.Do we need send the entire application everytime with the installer or just .msu can be send? Any help would be much appreciated. Thanks.
  4. After upgrade to System Center 2002 all Windows 10 and all Windows 2019 servers are not able to get updates. All other versions get updates properly.
    I get in sccm:
    Failed to download update(s),0X80D02002,Delivery Optimization: Download of a file saw no progress within the defined period
    From client:
    0x80D02002(-2133843966)
    Any ideas?
    1. I have the same issue , any suggestion ?
  5. Avatar photo jitu patro says:
    is KB4567007 required to be install before installing KB4560496 i can see both available and ready to install on mine
    1. Install KB4560496 update as it replaces the following previously release updates.
