In this blog post, I am going to explain what WSReset.exe is, how it works, and why it’s an essential tool for troubleshooting Microsoft Store-related problems.
Last week, a colleague mentioned wanting to install an app from the Microsoft Store, but the Store kept closing immediately upon being opened. A system restart did not help, and that’s when I recommended running the WSReset command, and it resolved the problem.
If you’ve ever encountered issues with the Microsoft Store, such as apps not downloading, updates failing, or the store itself refusing to open, you’re not alone. These problems can often be caused by a corrupted or overloaded store cache on Windows 10/11 devices.
Fortunately, Microsoft provides a simple command to resolve such issues: WSReset.exe. If you haven’t used it before, don’t worry, I will explain how to use it. I would like to also mention that WSReset command doesn’t delete your installed apps, app data, or any personal files on your Windows PC. It solely focuses on clearing the cache.
What is WSReset.exe?
In simple terms, WSReset is a built-in Windows command that resets the Microsoft Store cache. You should consider running WSReset if:
- The MS store is running slowly or behaving erratically.
- The Microsoft Store isn’t opening or functioning correctly.
- You’re experiencing errors while downloading or updating apps.
How to use WSReset.exe to clear Microsoft Store Cache
To reset the Microsoft Store cache using the WSReset.exe:
- Press Win + R on your keyboard to open the Run dialog box.
- Type WSReset.exe and press Enter or click OK.
- The Microsoft Store will open automatically once the cache has been reset.
You don’t have to restart your computer after performing the above steps. The Store app should work fine now.
Conclusion
WSReset is a powerful yet simple tool for clearing the Microsoft Store cache and resolving common issues. Whether you’re dealing with app download errors, a slow store, or other glitches, this utility can save you time and frustration.
Next time you encounter problems with the Microsoft Store, I recommend giving WSReset a try. It might just be the quick fix you need! If you have any questions, please let me know in the comments below.
