Supported Windows Client OS Versions for SCCM
This guide lists all the supported Windows client OS versions for SCCM. This information will assist you in determining the supported Windows 10/11 client version for installing the client agent.
Configuration Manager supports installing client software on Windows 10 and Windows 11 operating systems. Older operating systems such as Windows XP, 7, 8 are no more supported as clients for SCCM. To obtain the newest updates, Microsoft advises you to update your client operating system to the most recent version that is supported.
Starting with Configuration Manager version 2107, Windows 11 is officially supported as a client. However, version 2107 is outdated, so ensure you upgrade your SCCM to the latest available current branch version.
You can no more install clients on macOS and Linux endpoints, as they are not supported by Configuration Manager. Coming to support for Windows Server, check the guide on supported Windows Server OS for SCCM to get more details.
Supported Windows 11 Client OS versions for SCCM
The following table lists the versions of Windows 11 that you can use as a client with different versions of Configuration Manager.
Windows 11 versionConfigMgr 2309ConfigMgr 2403ConfigMgr 2409ConfigMgr 2503ConfigMgr 2509
25H2
(10.0.26200)
Not SupportedNot SupportedNot SupportedNot SupportedSupported
24H2
(10.0.26100)
Not SupportedNot SupportedSupportedSupportedSupported
23H2
(10.0.22631)
SupportedSupportedSupportedSupportedSupported
22H2
(10.0.22621)
21H2
(10.0.22000)
Supported Windows 10 Client OS versions for SCCM
The following table lists the versions of Windows 10 that you can use as a client with different versions of Configuration Manager.
Windows 10 versionConfigMgr 2309ConfigMgr 2403Configmgr 2409Configmgr 2503
22H2
(10.0.19045)
21H2
(10.0.19044)
Enterprise LTSC 2021
(10.0.19044)
Note: Windows 10 support ends on 2025-10-14. You must upgrade all your existing computers to Windows 11 to get the latest security and critical updates.
Further Reading
Check out some useful guides on supported configurations for SCCM.
