SCCM | ConfigMgr | Intune | Windows 11 | Azure
  • Home
  • Cloud
    • Autopilot
    • Azure
    • Endpoint Analytics
    • Intune
    • PowerShell
    • Teams
    • Windows 365
  • Microsoft
    • Active Directory
    • Group Policy
    • SCCM
    • SCOM
    • Windows 10
    • Windows 11
    • Windows Server
    • WSUS
  • Software
  • Forums
  • Newsletter
  • Contact
Notification Show More
Latest News
Fix Windows Autopilot Reset Error 0x80070032
Autopilot Intune
Windows activation error 0xc004c020
Fix: Windows Activation Error 0xC004C020 with 2 Easy Methods
Windows 11 Windows 10
Find the Package ID of SCCM Application
3 Best Ways to Find the Package ID of SCCM Application
SCCM
SCCM Updates Install Error 0x800b0109 0x8024b303
Fix: SCCM Updates Install Error 0x800b0109 | 0x8024b303
SCCM
Disable Windows Hello for Business using Intune ftimg
Disable Windows Hello for Business using Intune – Comprehensive Guide
Intune Autopilot
Aa
Aa
Search
  • Home
  • Cloud
    • Autopilot
    • Azure
    • Intune
    • PowerShell
    • Teams
    • Windows 365
  • Microsoft
    • Active Directory
    • Group Policy
    • SCCM
    • SCOM
    • Windows 10
    • Windows 11
    • Windows Server
    • WSUS
  • Software
  • Forums
  • Newsletter
  • Contact
Follow US
Home » SCCM » SCCM Task Sequence Failed with Error Code 0x800702C2
SCCM
By Prajwal Desai 1 View September 26, 2021 4 Min Read
Recently one of the my forum user posted a SCCM OSD issue. The error was SCCM Task Sequence failed error code 0x800702C2. Let’s understand why the sequence fails and the solution.
Your task sequence may fail very rarely with this error code. You encounter error 0x800702C2 while performing an in-place upgrade using a SCCM task sequence.
According to the user, he created a task sequence and deployed to a device collection. The in-place upgrade task sequence was made available in software center. When the user clicked and installed from software center, the SCCM Task Sequence failed error code 0x800702C2.
The task sequence was an in-place upgrade to windows 10. However upon checking the smsts.log file, it revealed the actual error and the reason why the task sequence failed.
- Advertisement -
Ad image
When your SCCM task sequence fails with error code 0x800702C2, your smsts.log contains similar lines and errors.
Validating package for OS upgrade architecture.
Architecture of OS upgrade package is x64. Architecture of current OS is x86
The Architecture of current OS does not match architecture of new OS upgrade package. Cannot continue OSDUpgradeWindows
ValidateOSArchitectureForUpgrade(wNewOsArch, sSystemFile)HRESULT=800702c2 (e:\nts_sccm_release\sms\client\osdeployment\upgradewindows\upgradewindows.cpp,1122)
Failed to verify that architecture of current operating system matches the architecture of source OS upgrade package
Failed to run Windows Setup.
{Machine Type Mismatch}
The image file is valid, but is for a machine type other than the current machine. Select OK to continue, or CANCEL to fail the DLL load. (Error: 800702C2; Source: Windows) OSDUpgradeWindows
RunWindowsSetupForUpgrade(ulExitCode), HRESULT=800702c2
Failed to run windows setup for upgrade OSDUpgradeWindows
Resolution
If you look at the above lines, you can make out that the error is not with task sequence.
  • Architecture of the OS upgrade package is x64 and current OS is x86.
  • Architecture of the current OS does not match architecture of new OS upgrade package.
The SCCM Task Sequence failed with error code 0x800702C2 because the user is trying to upgrade an 32 bit OS with 64 bit OS. If your PC is running Windows 32 bit OS, you cannot use the Windows 64-bit disc to upgrade a 32-bit version of Windows.
This holds true for any operating system that you upgrade. So if you are running 32-bit windows 7 on a PC and if you upgrade with Windows 10, you will end up having 32 bit Windows 10.
Most of all if your processor can handle 64 bit OS then you should do a clean installation of 64 bit OS. 32-bit OS are rarely used because the newer laptops work perfectly with Windows x64 operating systems. The x86 OS upgrade package should be deployed to perform in-place upgrade of x86 windows 7 OS and x64 package for 64 bit computers.
Sign Up For Weekly Newsletter
Get the most recent information on Configuration Manager, Intune, Windows 11, Windows 365, Autopilot, Azure, Software Reviews, and much more by subscribing to the newsletter.
By signing up, you agree and acknowledge the data practices in our Privacy Policy. You may unsubscribe at any time.
Share this Article
Facebook Twitter Copy Link Print
Avatar photo
By Prajwal Desai
Follow:
Prajwal Desai is a Microsoft MVP in Enterprise Mobility. He writes articles on SCCM, Intune, Configuration Manager, Microsoft Intune, Azure, Windows Server, Windows 11, WordPress and other topics, with the goal of providing people with useful information.
Previous Article ice Mountain How to Update Configuration Manager Cmdlet Library
Next Article code lines vintage List SCCM Application Deployments Using PowerShell Script
Recast Sponsored AD
Ad image
Patch My PC Sponsored AD
Ad image
Latest Articles
Autopilot Intune
SCCM
SCCM
Subscribe to Our Newsletter
Subscribe to our newsletter to get our newest articles instantly!
You Might Also Like
SCCM
By Prajwal Desai
SCCM
By Prajwal Desai
ConfigMgr Technical Preview 2302 New Features
SCCM
ConfigMgr Technical Preview 2302 New Features | Baseline Version
By Prajwal Desai
Removed from reading list
Undo
Welcome Back!
Sign in to your account
Lost your password?
