Clear Required PXE Deployments in SCCM
How To Clear Required PXE Deployments in SCCM | ConfigMgr
Let’s see how to clear required PXE deployments in SCCM. The “Clear Required PXE Deployments” clears the status of the most recent PXE deployment in Configuration Manager.
There are two ways to clear the required PXE deployments in Configuration Manager: Configuration Manager console and the Clear-CMPxeDeployment PowerShell cmdlet. Both a single device and an entire collection of devices can have their required PXE deployments cleared.
There are a few PowerShell scripts available on GitHub that can help you clear required PXE deployments in SCCM. However, when you can do this job from the SCCM console, you may not require those scripts.
Take a look at some useful guides on PXE deployment issues.
What does clear required PXE deployments do?
The Clear Required PXE Deployments in SCCM is used to redeploy any required PXE deployments for the currently selected collection. When a computer is PXE booted and a mandatory or required task sequence is assigned to it, a flag is set on the client indicating when the computer was PXE booted. This computer will not PXE boot again if that flag is set. The reason is that it might cause the computer to hang up during the installation and restart itself in WinPE.
You can redeploy a required PXE deployment for a collection of devices, which clears the status of the last PXE deployment assigned to that Configuration Manager collection. In other words, Configuration Manager redeploys the most recent required deployments.
To clear required PXE deployments in Configuration Manager.
  • Navigate to Assets and Compliance\Overview\Device Collections.
  • Right-click the device collection and select Clear Required PXE deployments.
A warning box appears which reads “This will clear the required PXE boot deployments of all the members assigned to this site in this collection. The members not assigned to this site in this collection will not be affected. Are you sure you want to clear the required PXE boot deployments of this collection?“
Click Yes to confirm, and this action will clear all the PXE deployments on the devices in the selected device collection.
Clear Required PXE Deployments using PowerShell
The Clear-CMPxeDeployment PowerShell cmdlet clears the status of the most recent Pre-Boot Execution Environment (PXE) deployment in Configuration Manager.
You can run the below command to clear the status of required PXE deployments for a device collection. Ensure you replace the collection ID in the command and run it. Learn how to find collection ID of a device collection in SCCM.
Clear-CMPxeDeployment -DeviceCollectionId "SMS000US"
The below table lists the additional parameters associated with the Clear-CMPxeDeployment PowerShell cmdlet.
Clear-CMPxeDeployment ParameterDescription
-WhatIfShows what would happen if the cmdlet runs.
-ResourceIdSpecifies an array of IDs for resources. The cmdlet clears the status of the PXE deployment for these resources.
-ForceWildcardHandlingThis parameter processes wildcard characters
-DisableWildcardHandlingThis parameter treats wildcard characters as literal character values.
-DeviceNameSpecifies an array of names of devices.
-DeviceCollectionNameSpecifies an array of names of device collections.
-DeviceCollectionIdSpecifies an array of IDs of device collections.
-DeviceCollectionSpecifies a device collection object.
-DeviceThe actual device name.
-ConfirmPrompts you for confirmation before running the cmdlet.
Clear Required PXE Deployments Option missing in SCCM Console
There are cases when your help desk team may report that the clear required PXE deployments option is missing in the SCCM console. This happens when the users don’t have permissions to use the clear required PXE deployments on the device or device collection.
To resolve this issue, ensure the security role (SCCM RBAC) has permissions to Modify Resource access on collection. You can edit the security roles in SCCM, for example, help desk users and edit the role. On the Security Role Properties window, switch to Permissions tab. Expand Collection and ensure the Modify Resource is set to “Yes” for collection.
