This blog post provides a detailed guide to fixing Microsoft 365 error code 0x80004005. Microsoft 365 is one of the most widely used productivity suites, but like any software, it’s not immune to errors.
One common issue users encounter while using M365 apps is error 0x80004005, which is often described as an “unspecified error.” This error can occur during installation, updates, or while trying to access certain features.
Well, in my case, the Microsoft 365 account issue with error code 0x80004005 appeared for every app that I launched. This was very frustrating because I was unable to edit any Office files. The below screenshot is an example of the account issue that appeared after opening any of the Microsoft 365 apps.
Account Issue: The products we found in your account cannot be used to activate office in shared computer scenarios. Error Code: 0x80004005.
What Causes Error Code 0x80004005?
The error code 0x80004005 is a general error that can be triggered by various issues, such as:
- Corrupted files in the Microsoft 365 installation.
- Permission issues prevent access to certain files or folders.
- Antivirus or firewall interference blocking Microsoft 365 processes.
- Incomplete updates or installation failures.
- Registry errors related to Microsoft 365.
Troubleshoot issues with shared computer activation for Microsoft 365 Apps
The most common issue with Microsoft 365 apps is getting shared computer activation to work when you deploy Microsoft 365 Apps to shared computers in your organization.
Microsoft has published an excellent guide to troubleshoot issues with shared computer activation for Microsoft 365 Apps. You should use this guide to troubleshoot issues with Microsoft 365 apps.
Error: The products we found in your account cannot be used to activate Office in shared computer scenarios?
This error indicates that your Office 365 or Microsoft 365 plan does not include Microsoft 365 Apps with shared computer activation support, preventing you from using shared computer activation. To use shared computer activation, you must have an Office 365 (or Microsoft 365) plan that includes Microsoft 365 Apps and that supports shared computer activation.
Resolving Microsoft 365 Error Code 0x80004005
Microsoft 365 error code 0x80004005 may occur due to an inactive Office/Microsoft 365 subscription, outdated applications, or problems within the Office apps themselves. There could be multiple reasons why you encounter this error. Let’s look at possible solutions to address this issue.
Solution 1 – Check if you have an active Microsoft 365 Subscription
The Microsoft 365 error code 0x80004005 means that you don’t have an Office 365 (or Microsoft 365) plan that includes Microsoft 365 Apps. Or possibly the existing subscription is expired.
The error code 0x80004005 could be associated with a single user where launching every Microsoft 365 app results in an error. You must check that the user is assigned a license for Microsoft 365 Apps. There should be an active Microsoft 365 subscription plan to use any of the office apps.
To check when your Microsoft 365 Family or Microsoft 365 Personal subscription expires:
- Launch the browser and go to Office Services & subscriptions page.
- If prompted, choose Sign in and enter the Microsoft account email and password associated with your Microsoft 365 subscription.
- Review the details under the Services & Subscriptions heading.
- If the subscription is expired, it should be seen here.
Solution 2 – Install Microsoft 365 Updates
The Microsoft 365 error code 0x80004005 often occurs when the apps are not updated to the latest version. To prevent this issue, it is advisable to configure Microsoft 365 for automatic updates. Microsoft recommends ensuring that all Microsoft 365 apps are consistently kept up to date.
To check for Microsoft 365 updates, open an Office app (such as Word), select File, and then select Account. Select Update Options, and then select Update now. You can also use the Update Options button to Disable Updates or to View Updates that were previously installed.
The latest Microsoft 365 updates are downloaded from Microsoft and installed. You may be asked to restart the computer after installing the updates.
Read: How to deploy Microsoft 365 updates using SCCM
Solution 3 – Run the Microsoft SaRA Sign in troubleshooter
One of the best ways to fix Microsoft 365 error code 0x80004005 is to run the Microsoft Support and Recovery Assistant (SaRA) troubleshooter.
You can use Microsoft Support and Recovery Assistant to fix Office, Office 365 and Windows problems. The Support and Recovery Assistant is also known as Microsoft SaRA.
If you encounter error code 0x80004005 while launching Microsoft 365 apps, run the SaRA troubleshooter to resolve the Microsoft 365 app issues. Here is the guide on how to download and run the Microsoft Support and Recovery Assistant (SaRA) Sign in troubleshooter.
Solution 4 – Repair Microsoft 365 Installation
Microsoft 365 includes a repair option to fix corrupted files. To repair your installation:
- Open Control Panel and go to Programs > Programs and Features.
- Find Microsoft 365 in the list and click Change.
- Select Repair and follow the on-screen instructions.
Select Quick Repair here as it works in most of the cases.
Wait for the Microsoft 365 installation repair process to complete and restart your computer. Log in back and now launch any Microsoft 365 App and you shouldn’t see the error code 0x80004005.
Solution 5 – Re-Install Microsoft 365
If the above steps don’t work, reinstalling Microsoft 365 may resolve the issue:
- Uninstall Microsoft 365 via Control Panel > Programs > Programs and Features.
- Restart your computer.
- Download and reinstall Microsoft 365 from the official website.
Conclusion
Error code 0x80004005 can be frustrating, but with the right troubleshooting steps, you can resolve it and get back to using Microsoft 365 without interruptions. Start with the simpler solutions, like restarting your computer and checking for updates, before moving on to more advanced methods like registry edits or reinstalling the software.
If the issue persists, consider reaching out to Microsoft Support for further assistance. Have you encountered this error before? Share your experience and solutions in the comments below!
