In this article, I’ll show you how to enable LEDBAT for SCCM software update points (SUP) and distribution points (DP). LEDBAT adjusts download speeds during client scans against WSUS to help control network congestion.
To enable Windows Low Extra Delay Background Transport (LEDBAT) on software update points and DPs, you must upgrade to SCCM 2203 or a newer version. The supported Windows Server version is 2016 or later.
If you have a site system installed with both distribution point role and software update point role, you must configure LEDBAT independently for each role. For example, if you only enable LEDBAT on the distribution point role, the software update point role doesn’t inherit the same configuration. You’ll have to enable LEDBAT on SUP separately.
What is LEDBAT in SCCM?
Windows Low Extra Delay Background Transport (LEDBAT) is a network congestion control feature of Windows Server to help manage background network transfers. LEDBAT adjusts download speeds during client scans against WSUS to help control network congestion.
In this guide, I will show you how to enable LEDBAT on SCCM DP and SCCM SUP separately.
Minimum requirements for LEDBAT Support
- Windows Server 2016 or later, is required. Windows Server 2019, 2022, and 2025 versions are also supported for enabling LEDBAT.
- Windows Server 2016 that is installed with the following updates:
- Cumulative update KB4132216, released June 21, 2018, or a later cumulative update.
- Servicing stack update KB4284833, released May 18, 2018, or a later servicing stack update.
Ways to Enable LEDBAT for SCCM SUP
There are two ways to enable the LEDBAT setting for SCCM SUP. You can enable “Adjust the download speed to use the unused network bandwidth (Windows LEDBAT)” setting from one of the following locations:
- From the Software Update Point Installation wizard.
- In the General tab of the software update point properties.
Enable LEDBAT For SCCM Software Update Points
Let’s look at the steps to enable LEDBAT for SCCM Software Update Points:
- Launch the SCCM console.
- Navigate to Administration\Overview\Site Configuration\Servers and Site System Roles.
- From the list of servers, select the server installed with Software Update Point role.
- Right-click the Software Update Point role and select Properties.
On the Software Update Point Properties window, click the General tab. Under WSUS Configuration, enable the setting “Adjust the download speed to use the unused network bandwidth (Windows LEDBAT)“. This enables the LEDBAT on Software Update Point.
Enable LEDBAT during Software Update Point Installation
In this method, you can enable LEDBAT during the SUP role installation. This method is applicable only if you want to enable LEDBAT while installing a new Software Update Point role on Windows Server.
When you add a new site system role in SCCM, on the System Role Selection page, select Software Update Point Role. On the Software Update Point settings page, enable the option “Adjust the download speed to use the unused network bandwidth (Windows LEDBAT)“.
Enable LEDBAT on SCCM DP
On a SCCM distribution point, you can enable LEDBAT using following steps:
- Navigate to Administration\Overview\Distribution Points.
- Right-click SCCM DP and select Properties.
- In the General tab, enable the setting “Adjust the download speed to use the unused network bandwidth (Windows LEDBAT)“.
- Click Apply and OK.
Thank you for this post. How to check if LEDBAT is working or not?
