In this article, I will show you how to download ConfigMgr 2203 baseline media from different locations. You can download SCCM 2203 installation media from Evaluation center, MSDN and VLSC.
A few days ago the Microsoft Evaluation Center portal was down due to maintenance, and now it’s online, and you can download ConfigMgr 2203 baseline installation media.
Microsoft has revamped the design of Microsoft Evaluation Center portal. Along with ConfigMgr 2203, other downloads are also available.
Apart from Microsoft Evaluation Center, you can download the baseline version for ConfigMgr 2203 from MSDN (Visual Studio Subscriptions) and Microsoft VLSC (Volume Licensing Service Center).
Configuration Manager 2203 update is now generally available, and you don’t have to use a PowerShell script to upgrade to SCCM 2203.
ConfigMgr 2203 is a major release of the ConfigMgr product. It comes with many new features and improvements which makes it worth to upgrade. Check out the top 5 new features of Configuration Manager 2203 release.
There are 3 locations from where you can download the baseline media for Configuration Manager 2203:
- Download 2203 from Microsoft Evaluation Portal
- Access the ConfigMgr 2203 baseline media from VLSC
- Download SCCM 2203 install media from Visual Studio Subscriptions (MSDN)
Download ConfigMgr 2203 Baseline Media from Microsoft Evaluation Center
You can download the SCCM 2203 baseline media from Microsoft Evaluation center portal. Using the ConfigMgr baseline media version 2203, you can install a new site in a new hierarchy.
To download ConfigMgr 2203 baseline media, visit Microsoft Evaluation Center. You can directly access the Configuration Manager current branch download section to get ConfigMgr downloads.
The latest version of ConfigMgr baseline installation media available for download is version 2203. Click on Download Version 2203 and save the MEM_Configmgr_2203.exe file on your computer. The file size is approx. 1.9 GB before you exact it.
Once the download is complete, you can either double-click this file or manually extract it to a folder using WinRAR or 7zip. You can then use the setup file to begin the Configuration Manager 2203 installation.
Check out the step-by-step SCCM current branch baseline installation guides.
Download SCCM 2203 Baseline Media from VLSC
Most organizations have access to a Volume Licensing Service Center from where the install media are downloaded. The Volume Licensing Service Center (VLSC) gives you easy access to Volume Licensing benefits.
By logging in VLSC portal, you can download products and keys, manage your Volume Licenses, grant permissions, view account details etc.
To download the Configuration Manager baseline media 2203 from VLSC, login to the VLSC portal. Next, click Downloads and Keys tab. Since there are several products listed, use the search box to find your product.
Use the search box to find the ConfigMgr version 2203 product. Click Download and from the list of products, select the ConfigMgr baseline media version.
Note: Don’t panic if you don’t see the latest SCCM baseline media in downloads section. Microsoft will upload the media soon after they release the update for everyone.
Download SCCM 2203 Installation Media from Visual Studio Subscriptions (MSDN)
You can download the version 2203 baseline installation media from Visual Studio Subscriptions (formerly known as MSDN Subscriptions).
You need to subscribe to take advantage of all the tools, cloud services, software access, training and partner benefits. If you have a Visual Studio subscription, login to https://visualstudio.microsoft.com/subscriptions/.
Click Downloads tab and in the search box type “Configuration Manager 2203” and click Search. Select Microsoft Endpoint Configuration Manager, version 2203 and click Download.
To get the Configuration Manager 2203 product key, click Get Key and use this key to license the product.
