Disable Microsoft Entra Authentication in SCCM
Disable Microsoft Entra Authentication for Tenant in SCCM
Starting with version 2010, you can disable Microsoft Entra authentication in SCCM for tenants that are not associated with users or devices. If you aren’t using Microsoft Entra ID for co-management, you can disable it in SCCM.
Microsoft Entra ID allows you to link your users, devices, and applications across both cloud and on-premises environments. When you connect Configuration Manager to Microsoft Entra ID, the site and clients can use modern authentication.
By default, Microsoft Entra device authentication is enabled for all onboarded tenants, regardless of whether they have devices. If there aren’t any SCCM users or devices associated with the tenant, you can disable Microsoft Entra authentication.
Disable Microsoft Entra Authentication in SCCM for Tenant
Launch the Configuration Manager console. Go to Administration > Cloud Services and select the Azure Services node. Select the target connection of type Cloud Management. In the ribbon, select Properties.
On the Cloud Management Properties window, switch to the Applications tab. Select the option “Disable Microsoft Entra authentication for this tenant.” Click Apply and OK to save and close the connection properties.
After disabling the MS Entra authentication in Configuration Manager, it can take up to 25 hours for this change to take effect on clients. It is therefore recommended to make this change during the weekends to ensure it doesn’t affect clients during business hours.
To speed up this change in behavior, use the following steps:
One Comment
  1. Hi
    I have the exact environment described in the article, but when I implement the action described, even I reconfigure the CMG or even stop the application and start again, the action stop the CMG of working.
    Do you had some problems with this kind of implementation?
