Integrating Dell Management Portal for Intune
Starting October 2024, Microsoft has announced the integration of the Dell Management Portal for Intune, which will provide streamlined access to Dell-specific Windows device management features.
Since few months, Microsoft has been planning to expand their OEM integration by adding Dell Management Portal to the Intune dashboard. With this integration, you can more effectively secure the Dell laptops that Intune is in charge of managing.
The Dell Management Portal will appear in the Partner portals tab in the Devices blade of the Intune admin center. In the same section, you should also find Surface and HP management portals too.
Read more about Microsoft’s announcement that Intune has expanded Dell OEM integration in the partner portal. In this guide, I will explain the features offered by Dell management portal and how to connect integrate it in Intune.
Features offered by Dell Management Portal
When integrated with Intune, the Dell Management Portal will offer the following features:
  1. Safe device administration: Retrieve distinct, device-specific credentials, such as BitLocker recovery keys and past and present BIOS passwords from the Dell laptops.
  2. Fleet management: In addition to per-device assigned-user information, such as name and contact, you may access device hardware, operating system, and storage details.
  3. Device reporting: You can review updates from the managed Dell devices, which are provided every 30 minutes in the admin center.
  4. Accelerate deployments: Speed up how you deploy firmware, software, and application updates to Dell PCs.
  5. Application management: Securely access the latest version of select Dell enterprise applications to upload to Intune for deployment and get update status of those apps.
Dell Enterprise Applications available in Intune
The following are a few of the Dell enterprise apps that are accessible in Intune:
Integrate Dell Management Portal for Intune
Here’s how you can connect to the Dell management portal from Intune. First, sign in to the Intune admin center. Navigate to Devices > Partner Portals. Select Dell Management Portal.
On the Dell Management portal page, click on Connect now button as shown in the below screenshot.
This is an important step. On the Entra login screen, you will have to checkbox the option “Consent on behalf of your organisation” to allow dell app to access the data. Granting those permissions enables the new integrated Dell app deployment, reporting, and more. Review the permissions and click Accept.
Connecting Dell Management Portal with Intune
That’s all. Once connected, IT admins can view the Dashboard for device insights and action, for their Microsoft Intune environment. Here you can find all your Dell devices from your Intune environment and Dell applications. There is an option to quickly search the BIOS password by entering the service tag of your Dell device.
Dell Management Portal for Intune Dashboard by Microsoft
View Intune devices in Dell Management Portal
Next to the dashboard, you will find two tabs: Devices and Apps. The Devices tab lists all your Dell PCs that you manage from Intune. Whereas the Apps tab shows all the Intune apps for Dell. This portal retrieves your latest device data every 30 minutes from Intune.
On the Devices tab, you can view details of the devices retrieved from Intune. The device details include:
  • Device Name
  • User ID
  • Service Tag
  • Model
  • BIOS Password
View Intune devices in Dell management portal
View Intune apps in Management Portal
The Apps section in the management portal displays the following information for available Dell enterprise applications retrieved from Intune:
  • App Name: Shows the title of the application
  • Status: Shows the Dell application status and it has one of the following four states.
    • Critical Update available: Represented in red color indicating an important update is available for the app.
    • Recommended update available: Represented in green color indicating an app requires update.
    • Optional update available: Represented in green color indicating an optional app update.
    • Published (Gray): Displays an app that is published.
