Dell SupportAssist OS Recovery Tool Reset Feature
How To Use Dell SupportAssist OS Recovery Reset Feature
In this article, you will learn about Dell SupportAssist OS Recovery, its features, and how to use the SupportAssist reset feature to reinstall the factory operating system.
Troubleshooting OS booting issues is now easier with Dell’s SupportAssist OS Recovery tool. We will use Dell SupportAssist’s reset feature to reinstall the Dell Recovery Factory Image.
We have another tool called Dell command update to install the latest drivers, BIOS, firmware, and Dell software applications.
When your computer is unable to boot to the operating system even after repeated attempts, it automatically starts SupportAssist OS Recovery. If you do not have the Dell SupportAssist tool installed on your computer, refer to the Dell SupportAssist OS Recovery User’s Guide for information on how to install it.
What is Dell SupportAssist OS Recovery?
The Dell SupportAssist OS Recovery environment enables you to diagnose hardware issues, repair your computer, back up your files, or restore your computer to its factory state.
The Dell SupportAssist OS Recovery is only available on certain Dell laptops that run a Dell factory-installed Microsoft Windows 10 or Windows 11 operating system.
When you purchase a new Dell laptop, check if it has the Dell SupportAssist OS Recovery tool preinstalled along with the operating system.
Dell SupportAssist OS Recovery Features
The Dell SupportAssist OS Recovery includes the following features:
  • Dell System Repair: This feature allows you to roll back your computer to a previous point in time to resolve boot issues or any other performance problems.
  • Scan Hardware: Runs diagnostic tests on your computer to detect any hardware issues.
  • Startup Repair: Use this feature to troubleshoot common issues that may occur before your computer boots to the operating system. This option enables you to avoid the need to reset your computer to its factory state.
  • Back up Files: This feature allows you to back up your personal files on a local hard drive or on an external hard drive. This is useful when are running a factory reset and want to save the files.
  • Reset: Dell SupportAssist reset feature downloads and installs the factory operating system or upgrade to the latest operating system.
Dell Reset Process Steps
The Dell Reset process consists of 4 major step, and they are as follows:
  • Step 1: Boot to SupportAssist OS Recovery
  • Step 2: Repair or Reset System
  • Step 3: Repair Windows
  • Step 4: Finalize Recovery with SupportAssist Recovery Assistant
Now that you are aware of Dell SupportAssist OS Recovery features, let’s go ahead and see how to use Dell SupportAssist reset feature to reset your computer.
When your computer is unable to boot to the operating system, it automatically starts SupportAssist OS Recovery.
However, you can manually start the Dell SupportAssist OS Recovery Tool with following steps:
1. Power on the Dell laptop and press F12 key. This should be done once the Dell logo appears, not after the logo has disappeared.
2. From the list of boot options, select SupportAssist OS Recovery.
Press F12 and Select SupportAssist OS Recovery
3. The main interface of SupportAssist OS Recovery appears on the screen. Wait while the tool loads and provides the recovery options.
Use Dell SupportAssist OS Recovery Tool
4. We now see four SupportAssist OS Recovery options by Dell. All these features are discussed in the above section.
SupportAssist OS Recovery Options
5. From the list of features, we are going to use the Reset feature. The reset feature allows you to download and install the factory operating system.
You can also upgrade to the latest operating system that’s available. This option will be presented along with the default OS upgrade.
To proceed with using the reset option, click Start Reset.
Dell SupportAssist OS Reset
Dell SupportAssist Reset Feature
6. There are two options when you want to reset your operating system to factory defaults
  • Reset to Factory Settings – Selecting this option will reset your device to factory settings and install the operating system that came preinstalled.
  • Reset and Update – This is the recommended option by Dell when you want to make a fresh start. Selecting this option will reset your laptop, install the latest available operating system and installs the updates too.
If you select Reset and Update, and if your laptop is eligible for Windows 11 upgrade, you get that option too. This option also ensures the latest Windows updates are installed after the reset has been done.
The Reset and Update option requires the device to be connected to internet. In the below screenshot, the Reset and Update option is greyed out because the laptop isn’t connected to internet.
7. Once the laptop is connected to the internet (Wireless), the Reset and Update option is available to choose. Click Next.
8. On Transfer Data window, you have two options supplied by Dell SupportAssist OS recovery tool for transferring your settings and data.
  • Yes, give access and transfer my settings and data – Select this option to transfer all your data and settings. You can edit the preferences on the next screen.
  • No, do not transfer my settings and data – The reset will permanently delete all system data and personal files on your hard drive. You won’t be able to retrieve these later. Select this option if you have already backed up your files to cloud storage such as Google Drive, OneDrive etc.
Since I have backed up files to OneDrive, I am going to select No, do not transfer my settings and data. Click Next to continue.
9. On Confirm your reset window, read the details and check the box “I understand that the reset will delete all of my system data and personal files“. Additionally, you have to select a reason for using the Dell SupportAssist reset feature.
Select an appropriate reason and click Next.
10. The Reset and update begins now, depending upon the connection speed, the latest Windows OS image is downloaded and installed.
The following steps are taken during the Dell SupportAssist reset process:
  • Downloading Recovery contents
  • Operating system recovery
  • Cleaning Disk
  • Recovery Operating System
  • Creating Local SupportAssist OS Recovery
Reset and Update in Progress
The Dell support assist reset can take between 1 and 5 hours to complete. The total runtime depends on the speed of your PC and network connection.
When the Dell Support Assist reset process is complete, the following information appears on the screen.
The SupportAssist OS recovery after its completion helps you troubleshoot your system issues. This is optional but I recommend using this wizard.
SupportAssist OS Recovery Troubleshooting
After the Dell reset process is complete, your device will get the latest Windows operating system and Windows Updates. Yes, the drivers are also installed along with the updates.
Install latest Windows Updates
If the Dell SupportAssist OS recovery tools become stuck during installation for an extended period of time, you can contact Dell support and report the issue for assistance.
2 Comments
  1. it is saying wait 48 hours and my internet connecton is not that bad how am i supposed to do that.
    Only if once the internet connection is disturbed it askes us to do it all over again.
  2. Avatar photo Rachel lim says:
    No network how to do a reset. My screen is full black
