Microsoft Shares Fix for WSUS Sync Delays and Timeout Issues
Microsoft has confirmed a known issue affecting Windows Server Update Services (WSUS) that causes slow synchronization times and sync timeouts. The problem stems from a buildup of publishing metadata on existing WSUS servers as well as on the service side.
The issue became more noticeable around July 13, 2026, and Microsoft deployed a service-side fix on July 18, 2026, which restored normal sync performance for new or rebuilt WSUS installations. However, existing WSUS servers may still experience delays and require manual cleanup.
Organizations with existing WSUS server installations that are experiencing long sync times should understand that this issue is related to a buildup of publishing metadata, which is present on existing WSUS server installations as well as from the service side.
Errors associated with WSUS Update Scans
On client computers, the buildup can also cause Windows Update scans to fail or time out. Affected clients may log errors such as the following:
ErrorMeaningWhat it indicates
0x80244010WU_E_PT_EXCEEDED_MAX_SERVER_TRIPSThe scan exceeded the maximum number of round trips to WSUS. This is the key symptom.
0x8024400E
0x80244007
WU_E_PT_SOAP_SERVER
WU_E_PT_SOAPCLIENT_SOAPFAULT
The server timed out processing the request, or the client sent an oversized dataset that WSUS rejected.
0x80244022
HTTP 503
Service unavailableThe WSUS application pool (WsusPool) is overloaded.
0x80240439WU_E_PT_INVALID_FORMATOversized client or server datasets producing abnormal IIS errors.
0x80072EE2WININET timeoutThe scan ran too long and timed out.
For existing WSUS server installations, Microsoft outlines a three‑step manual remediation process to fix the sync delays and timeout issues.
1. Back up the SUSDB databases
The first step is to back up each SUSDB database. A full backup is required because the cleanup permanently deletes update metadata. For information about creating the backup, seeĀ Create a full database backup.
BACKUP DATABASE SUSDB
TO DISK = N'<C:\Backup folder>\SUSDB_PreDetectoidCleanup.bak'
WITH INIT, STATS = 5;
2. Run a cleanup SQL query
Microsoft offers a SQL query (listed below) that does the following:
  1. Deletes mis‑published detectoids causing sync issues.
  2. Sets MaxXMLPerRequest = 0 to remove the 5Ā MB limit that can cause client scan failures.
The query should be run on every SUSDB, including replicas.
SET NOCOUNT ON;
UPDATE tbConfigurationC SET MaxXMLPerRequest = 0  --Update the MaxXMLPerRequest to lift the limit
DECLARE @updateID uniqueidentifier;
DECLARE @retcode  int;
DECLARE @deleted  int = 0;
DECLARE @skipped  int = 0;
DECLARE detectoid_cur CURSOR LOCAL FAST_FORWARD FOR
    SELECT u.UpdateID
    FROM dbo.tbUpdate u
    JOIN dbo.tbRevision r ON r.LocalUpdateID = u.LocalUpdateID AND r.IsLatestRevision = 1
    JOIN dbo.tbProperty p ON p.RevisionID = r.RevisionID
    JOIN dbo.tbLocalizedPropertyForRevision tbrp ON tbrp.RevisionID = r.RevisionID
    JOIN dbo.tbLocalizedProperty tlp ON tlp.LocalizedPropertyID = tbrp.LocalizedPropertyID
    WHERE p.UpdateType = 'Detectoid'
      AND tbrp.LanguageID = p.DefaultPropertiesLanguageID
      AND tlp.Title LIKE 'Product Detectoid for ProductName TestProduct%';
OPEN detectoid_cur;
FETCH NEXT FROM detectoid_cur INTO @updateID;
WHILE @@FETCH_STATUS = 0
BEGIN
    BEGIN TRY
        EXEC @retcode = dbo.spDeleteUpdateByUpdateID @updateID;
        IF @retcode = 0 SET @deleted += 1; ELSE SET @skipped += 1;
    END TRY
    BEGIN CATCH
        -- Most common: "still referenced by other update(s)" - safe to skip and continue
        SET @skipped += 1;
        PRINT CONCAT('Skipped ', CONVERT(varchar(40), @updateID), ' : ', ERROR_MESSAGE());
    END CATCH
END
CLOSE detectoid_cur;
DEALLOCATE detectoid_cur;
3. Restore MaxXMLPerRequest to default
Once WSUS is stabilized and clients have scanned successfully, the MaxXMLPerRequest value should be updated to its default setting by running the following query:
UPDATE tbConfigurationC SET MaxXMLPerRequest = 5242880
Microsoft also suggests adjusting IIS concurrent connections to keep CPU usage around 80%, helping clients complete scans. For more information, seeĀ Limits for a Web Site.
