Windows 11 ADK Versions and Downloads
This article includes a history of Windows 11 ADK versions as well as links to download them. Microsoft has released the latest Windows ADK 10.1.28000.1 (November 2025) and the Windows PE add-on for Windows 11 26H1 Arm64.
You can download ADK for Windows 11 from the Windows ADK downloads page. On the same page, you can also download the ADK for Windows Server 2022 and Windows 10.
What is Windows Assessment and Deployment Kit (ADK)?
Windows ADK contains deployment tools such as WinPE, sysprep, and other tools that you can use to customize and deploy Windows 11 images. Not only that, but you can use the tools to evaluate the quality and performance of your system and the applications that run on it.
Every new release of Windows ADK contains new features and enhancements.
Download Windows ADK for Windows 11
Like Windows 10 ADK, you have two separate installers for Windows 11 ADK that you can download.
  • Download the Windows ADK
  • Download the WinPE add-on for the Windows ADK
Download ADK for Windows 11
Download Windows ADK Patches
The latest ADK patches now allow users running ADK versions Windows ADK 10.1.26100.2454 (December 2024) and newer to update their ADK installations without having to uninstall and reinstall the entire kit.
The table below includes all the Windows 11 ADK versions, version numbers, and download links. The table will be updated when the newer versions of the Windows 11 ADK are released.
Windows 11 VersionADK versionRelease MonthDownload
Windows ADK for Windows 11 version 26H1 Arm6410.1.28000.1November 2025Download the ADK 10.1.28000.1 (November 2025)
Download the Windows PE add-on for the ADK 10.1.28000.1 (November 2025)
Windows ADK for Windows 11 version 25H2, 24H210.1.26100.2454December 2024Windows 11 24H2 ADK Download
WinPE Addon Download for Windows 11 24H2
Windows ADK for Windows 11 version 23H210.1.25398.1January 2025Windows 11 23H2 ADK Download
WinPE Addon Download for Windows 11 23H2
Windows ADK for Windows 11 version 22H210.1.22621.1May 2025Windows 11 22H2 ADK Download
WinPE Addon Download for Windows 11 22H2
Before you install the ADK for Windows 11, ensure you uninstall the old version of the ADK first. The installation of Windows 11 ADK is simple. If you are installing Windows 11 ADK for SCCM, you must first install ADK and then install the WinPE add-on.
Download ADK for Windows Insider Preview
Windows Insiders can download preview versions of the ADK from the following link.
Supported Windows 11 ADK Versions for SCCM
When you deploy operating systems with Configuration Manager, the Windows Assessment and Deployment Kit (ADK) is a required external dependency. The table below outlines the supported Windows 11 ADK versions across various Configuration Manager versions.
Windows ADK versionConfigMgr 2409ConfigMgr 2503ConfigMgr 2509
ADK 10.1.28000.1 (Updated Nov 2025)
(10.1.28000.1)
Not SupportedNot SupportedNot Supported
ADK 10.1.26100.2454 (Updated Dec 2024)SupportedSupportedSupported
ADK10.1.26100.1 (Updated May 2024)SupportedSupportedSupported
ADK 10.1.25398.1 (updated September 2023)Not SupportedNot SupportedNot Supported
ADK for Windows 11, version 22H2
(10.1.22621.1)
ADK for Windows 11, version 21H1
(10.1.22000)
(10.1.20348)
ADK for Windows 10, version 2004
(10.1.19041)
How to Find ADK version on Windows 11
To find the ADK version number on Windows 11, go to Control Panel > Programs > Programs and Features. Look for Windows Assessment and Deployment Kit (Windows ADK) and look for the Version column. For example, in the screenshot below, the installed Windows 11 ADK build number is 10.1.22000.1.
Windows 11 ADK Version Number
16 Comments
  1. So here is a problem with the latest ADK (Nov 2025). The new Secure Boot certificates, require the Nov 2025 ADK and yet the Nov 2025 ADK is not compatible with the latest SCCM version 2509. 2609 doesn’t come out until Sept of this year which is 3 months after the June 2026 cutoff for the old secure boot certificates to go away. Figure that one out.
  2. Avatar photo Jason Ritchie says:
    I get an error when using ADK for 11 version 10.1.22000 when attempting to update the Deployment share by Optimizing the boot image updating process in MDT DeploymentWorkbench. “Unable to open the specified WIM file.”
    I’ve also tried newer versions of the ADK with no luck. I do have the WindowsPE add-on installed as well. Same version.
    Is there a fix for this? Thanks in advance.
    === Processing LiteTouchPE (x86) boot image ===
    Building requested boot image profile.
    System.Management.Automation.CmdletInvocationException: Unable to open the specified WIM file. —> System.Exception: Unable to open the specified WIM file. —> System.ComponentModel.Win32Exception: The system cannot find the path specified
  3. Avatar photo Mark Morrow says:
    Interestingly enough I have installed ADK and ADKWINPE. When I image I get an error message after the OS has been installed on the reboot.
    Deployment Failure 5627
  4. I installed Windows ADK for Windows 11 Version 22H2 v10.1.22621.1 on a few Windows 10 computers, and it works fine. I’ve already made some Windows PE (WinPE) bootable media. Don’t forget to install the Windows PE add-on.
    The only thing you have to consider is that it doesn’t support 32-bit systems, although I haven’t used 32-bit Windows in many years.
  5. 22h2 version of the ADK isn’t supported by MDT. x86 boot images are no longer included in 22h2 ADK PE. MDT hasn’t changed since 2020 and still needs x86 boot images otherwise you are getting a lot of crappy errors. Also when starting the WinPE from WDS you get a script execution error. So use 21h2, that should work.
    1. You are correct. W11 22H2 ADK fails to even update the default x86 boot image much less allow us to image.
  6. Yes, you can use Win 11 ADK to install Win 10.
  7. I have tried to use the adksetup.exe to download the ADK but keep getting the “setup cannot locate Toolkit Documentation-x86_en-us.msi” error message.
    Internet connection is working.
    Any advice?
    1. Had this issue when I tried downloading the files to a directory the installer did not have access to. Try setting your download directory to your local my documents folder or something.
  8. Is there an ADK for 21H2 on Windows 10?
  9. Do you know if they released a fixed version for the TPM pre-provisioning issue? I just installed it a couple of days ago and the version number is still 10.1.22000.1 so I assume not.
  10. I’m assuming that we can also deploy windows 10 using the latest litetouch win 11 adk boot image?
    1. Hey Aaron, did you ever get an answer to this? Trying to find out as well
    2. I’m wondering the same…
      1. Yep still working, tested it.
