Microsoft has released SCCM 1906 hotfix KB4527297 that addresses an issue where data sync between the Microsoft Store for Business and a SCCM site server will fail when a proxy server configured on the site.
Anyone who is experiencing this issue would find the below errors in WsfbSyncWorker.log on the site server.
Error getting application token, converting to WsfbAuthenticationException. Original exception:
System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: The remote name could not be resolved: 'login.microsoftonline.com'
at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult)
at System.Net.Http.HttpClientHandler.GetResponseCallback(IAsyncResult ar)About KB 4527297
The hotfix KB4527297 applies to SCCM version 1906 and is an out-of-band release. This means you have to first download the hotfix and use the update registration tool to manually import the update to the SCCM console. The tool extracts the update package to the site server and the update can be installed from SCCM console.
You don’t have to restart the computer after you apply this hotfix. This hotfix does not replace any previously released hotfix. If you are currently running Configuration Manager 1906 and if you aren’t experiencing the above issue, you may skip installing this hotfix.
Download hotfix KB4527297
Download the hotfix KB4527297 from Microsoft Download Center. The browser downloads the CM1906-KB4527297.ConfigMgr.Update.exe file to your computer. Proceed to the next step to import this file into Configuration Manager.
Import Hotfix KB4527297 using Update Registration Tool
Perform the following steps to import hotfix (KB4527297) using the update registration tool in SCCM console.
- Firstly, login to the computer that hosts the service connection point role.
- Launch the command prompt as administrator. Change the path to the folder that contains the hotfix.
- Run the command CM1906-KB4527297.ConfigMgr.Update.exe to start the update registration tool.
- The update registration tool extracts the update package to the site server.
- Wait for the update or hotfix to appear on the SCCM console.
Close the update registration wizard.
Install SCCM 1906 Hotfix KB4527297
Use the below steps to install Configuration Manager 1906 hotfix KB4527297
- Launch the SCCM console.
- Go to Updates and Servicing node and look for the hotfix KB4527297.
- Right click Configuration Manager 1906 hotfix KB4527297 and click Install Update Pack.
Note that this hotfix includes updates for the site server and console. Click Next.
To monitor the hotfix installation, go to Monitoring > Updates and Servicing Status. Right-click the hotfix and click Show Status.
Since the hotfix also updates the console, you must upgrade the console to complete the installation. The new version of the console will be 5.1906.1096.2200. Take a look at the list of hotfixes and rollups released for all versions of Configuration Manager.
First of all, thanks for your great pages related to CM.
I’m having a similar error with data sync with the Microsoft Store, but I have CM 2006 with the latest hotfix KB4575790 (using proxy server). Is it safe to install the hoyfix KB4527297 suggested in this page or you have other advice?
After running update registration tool, I can see update in SCCM console but state is Available to download. It’s been few hrs I have checked updates and hit refresh multiple time but state won’t change.
I have the same issue. Says available to download but even when i try and download it it does nothing.
