Turn off or Disable Advertising ID | GPO | Intune
In this guide, we’ll walk you through the steps to turn off or disable the advertising ID using multiple methods. There are multiple ways with which you can stop targeted ads on your Windows 11 computer.
We will first understand what Advertising ID is and what happens when you turn off the advertising ID on your computer.
If you want to manually turn off or disable advertising ID using settings, it is feasible when you have a handful of computers. If you have got many computers in your estate, you can use methods like Group Policy, MDM solution like Intune to turn off advertising ID.
If you are managing your Windows devices using Intune, you can create a configuration profile and define the settings to turn off Advertising ID. You can target the policy to multiple computers or groups.
What is Advertising ID?
On your Windows computer, Windows generates a unique advertising ID for each user on a device. This advertising ID is used by app developers and advertising networks to target relevant advertising in apps.
Based on your app usage and types of app you use, the app developers and ad networks can target similar ads which might be useful.
When the advertising ID is enabled, app developers can associate personal data they collect about you with your advertising ID and use that personal data to provide more relevant advertising and other personalized experiences across their apps.
Microsoft delivers other forms of interest-based ads in certain Microsoft products, both directly and by partnering with third-party ad providers The advertising ID setting applies to Windows apps using the Windows advertising identifier. Learn more about Advertising ID from Microsoft documentation.
What happens when you turn off or disable Advertising ID?
Microsoft allows you to turn off or disable advertising ID on your computer to prevent apps from showing relevant ads. Turning the advertising ID off will not reduce the number of ads you see. It won’t block ads in apps, but future advertisements you see won’t be personalized. It may mean that ads are less interesting and relevant to you. Turning it back on will reset the advertising ID.
Method 1 – Manually Turn off Advertising ID on Windows computer
On your Windows 10 computer, you can use the following steps to turn off the advertising ID.
  • Go to Start > Settings > Privacy > General.
  • Turn off the setting Let apps use advertising ID to make ads more interesting to you based on your app activity.
Turn Off or Disable Advertising ID in Windows 10
Similarly, you can turn off Advertising ID on Windows 11 computer with these steps.
  • Turn off the setting Let apps show me personalized ads by using my advertising ID.
Turn Off or Disable Advertising ID in Windows 11
Method 2 – How to Turn Off Advertising ID using GPO
If you want to disable tailored advertising on multiple computers in your domain, you can use a group policy method.
The group policy method requires you to create a new GPO and configure the setting Turn Off Advertising ID. This policy setting turns off the advertising ID, preventing apps from using the ID for experiences across apps.
You can create a new GPO and apply it to a OU rather than applying it to the entire domain. Ultimately, the choice is yours.
Launch the Group Policy Management console and create a new GPO. You specify the GPO name as Disable Advertising ID and click OK.
Turn Off or Disable Advertising ID using GPO
Edit the GPO and navigate to Computer Configuration\Administrative Templates\System\User Profiles. Right click Turn off the advertising ID policy and select Edit.
By default, the Turn off the advertising ID is set to Not Configured. You must select Enabled and click Apply and OK.
Once you have applied the GPO, you must wait until your computers get this policy. By default, the GP refresh interval is 90 minutes. Learn how to modify the GPO refresh interval.
Method 3 – Turn Off or Disable Advertising ID using Intune
To turn off Advertising ID using Intune, you can follow the below steps.
On Create a profile screen, select the Platform as Windows 10 and later. Select Profile Type as Settings Catalog. Click Create.
Turn Off Advertising ID using Intune
On the Basics tab, enter the name of the Intune Configuration Profile as “Disable Advertising ID” and add a suitable description. Click Next.
Create Intune Configuration Profile - Disable Advertising ID
Create Intune Configuration Profile – Disable Advertising ID
On the Settings Picker window, type Advertising ID in the search box and click Search. From the search results, select Privacy and under Setting name, select Disable Advertising ID.
Settings Picker - Disable Advertising ID
Settings Picker – Disable Advertising ID
On the Configuring Settings tab, set the Disable Advertising ID to Enabled. This will turn off the advertising ID that is used by app developers and advertising networks to target relevant advertising in apps.
Click Next to continue.
On the Assignments tab, include the groups to which you want to target the advertising ID settings. Click Next.
Intune Configuration Profile - Assignments
Intune Configuration Profile – Assignments
You may select scope tags, but this is completely optional. Click Next to continue.
Intune Configuration Profile - Scope Tags
Intune Configuration Profile – Scope Tags
On the Review+Create tab, review the policy settings and click Create.
Intune Configuration Profile - Review and Create
Intune Configuration Profile – Review and Create
If you take a look at notifications, you should see a new notification confirming the policy creation. We have successfully created and deployed the policy to turn off or disable Advertising ID using Intune.
Hi, I am Prajwal Desai. For last few years, I have been working on multiple technologies such as SCCM / Configuration Manager, Intune, Windows 11, Azure, Security etc. I created this site so that I can share valuable information with everyone.
Leave a Comment
