Stellar Converter for OST – Comprehensive Tool to Convert OST to PST
In this post I am going to cover about Stellar Converter for OST. This software uses a robust algorithm to convert OST files into Outlook PST files. Let’s see more about the product features and how easy it is to convert your OST files to PST files.
This OST to PST converter tool by Stellar makes very easy for everyone to converts all outlook mailbox components such as email, attachments, contacts, calendars, deleted items and Journals to the Importable PST file. Besides, you can also preview & save the individual mailbox items in MSG, EML, RTF, PDF or HTML formats.
Contents
Stellar Converter for OST Features
So if you intend to buy this product you should know what this product offers. The Stellar OST to PST converter comes bundled with good set of features and here are some of the awesome features.
- This software makes it very simple to convert encrypted OST files into PST files.
- Support & Exchange IMAP OST files.
- Search and Save individual emails as per different criteria like “Date, Size, and Subject, From, To etc.
- Allows converting any size of OST files to PST files.
- In the Demo version, you can convert first 20 emails per folder to check the efficiency of the software.
- Supports all Outlook versions 2019, 2016, 2013, 2010, 2007, 2003, 2002, and 2000
Download Stellar Converter for OST
To download the latest version of Stellar Converter for OST, click this link. A quick note here about the free version of this product. The free download or the demo version enables you to preview the converted file and save 20 items per folder. If you want to convert more than 20 items per folder then, you can buy the full version by clicking this link.
It is essential to know that the software is available in two versions – Corporate & Technician. Now here, take some time about the job you want to perform with this software and what’s the difference and which one should you download?. If you only need to convert OST file into PST file format, then you should go for corporate version. But If you want to convert multiple OST files, compact, split large OST file or Export the OST file data in office 365 & live Exchange, then you should go for Technician version.
System Requirements
- Processor: Pentium Class
- Operating System: Windows 10 / Windows 8 / Windows 7 / Windows Vista
- Memory: At-least 1 GB
- Hard Disk: 100 MB of free space
- MS Outlook: 2019 / 2016 / 2013 / 2010 / 2007
Installing Stellar Converter for OST
To install Stellar OST converter, run the executable file. On the welcome screen, click Next.
Accept the license agreement and click Next.
Note down the installation path. Click Next.
Click Install.
The software installation is complete. Click Finish.
If you have already purchased the Stellar OST Converter, you can activate the product by clicking Activation tab. In the Activation box, enter the product key and click Activate.
Convert OST to PST using Stellar OST Converter
This is an interesting part where we see how this product actually works. When you launch the Stellar OST converter, you see some a box to select OST file for conversion.
Clicking Browse opens explorer and you can manually select the OST file.
In the next step, click Convert. The software now runs and converts your OST file to PST file.
While most users don’t know the OST file location, the Find option comes handy. When you click Find, the software searches OST files for you. Specify the search location as C:\ drive and click Find. In addition to that ensure you enable the Search Subfolders option to search all the sub-folders within C:\ drive. The Stellar OST converter now looks for OST files under C:\ drive.
If there are multiple OST files, you should see all of them in results pane. Select the OST file and click Convert. You can convert multiple OST file in Technician version.
The OST file is successfully converted to PST file. The time it takes to convert the files depends upon the size of OST files. In my case the OST file was 50MB and the Stellar converter completed it’s operation in 5 seconds.
Click OK on conversion completion window.
In the next step, click Save Converted File. Before you do this, remember to close the Outlook. In the save as window, select PST. To chose a different destination path, click Browse.
As of now Stellar OST Converter supports exporting OST file to below formats.
- PST
- MSG
- EML
- RTF
- HTML
In Technician version, there are more saving options like Office 365, Live Exchange etc.
Import PST file in MS Outlook
In the above steps we successfully converted OST file to PST file. Now let us see how to import PST file to Microsoft Outlook 2016 or 2013.
First of all launch Microsoft Outlook. From File Menu, select Open & Export and click Import/Export.
From Import and Export Wizard window, select Import from another program or file, click Next.
Select Outlook Data File (.pst) and click Next.
Click Browse and locate the OST file. Click Next.
You may select specific folder to import to your outlook or complete PST file. Click Finish.
Thank you for sharing the helpful review, After read your depth research on the Stellar, I could make my mind to check the demo version, and then I had purchased the licence to convert my entire mailbox data in the PST format.
