In this guide, I am going to cover about Stellar Converter for OST. The Stellar OST to PST converter is the best tool to convert OST to PST.
This software uses a robust algorithm to convert OST files into Outlook PST files. In this guide we will take a look at the new product features and how easy it is to convert your OST files to PST files.
This Stellar OST to PST converter tool makes it effortless for everyone to converts all outlook mailbox components such as email, attachments, contacts, calendars, deleted items and Journals to the Importable PST file. Besides, you can also preview and save the individual mailbox items in MSG, EML, RTF, PDF or HTML formats.
Table of Contents
Stellar Converter for OST Features
So if you intend to buy “Stellar Converter for OST” tool, you should know what this product offers. The Stellar OST to PST converter comes bundled with good set of features and here are some of the fantastic features.
- This software makes it very simple to convert encrypted OST files into PST files.
- Support & Exchange IMAP OST files.
- Search and Save individual emails as per different criteria like “Date, Size, and Subject, From, To etc.
- Allows converting any size of OST files to PST files.
- In the Demo version, you can convert first 20 emails per folder to check the efficiency of the software.
- Supports all Outlook versions 2019, 2016, 2013, 2010, 2007, 2003, 2002, and 2000
Download Stellar OST to PST Converter Tool
To download the latest version of Stellar Converter for OST, visit the Stellar homepage. It is recommended to download the latest of this application to get all the new features.
A quick note here about the free version of this product. The free download or the demo version enables you to preview the converted file and save 20 items per folder. If you want to convert more than 20 items per folder, then, you can buy the full version of this software.
It is essential to know that the Stellar Converter for OST software is available in two versions – Corporate & Technician. If you only need to convert OST file into PST file format, then you should go for corporate version. But If you want to convert multiple OST files, compact, split large OST file or Export the OST file data in Microsoft 365 & live Exchange, then you should go for Technician version.
System Requirements for Stellar OST to PST
Here are the system requirements for using Stellar OST to PST converter tool.
- Processor: Pentium Class
- Operating System: Windows 11 / Windows 10 / Windows 7
- Memory: At-least 1 GB
- Hard Disk: 100 MB of free space
- MS Outlook: 2019 / 2016 / 2013 / 2010 / 2007
Installing Stellar Converter for OST
To install Stellar OST converter, run the stellar converter for OST executable file. On the welcome screen, click Next.
Accept the license agreement and click Next.
You may change the default installation path for this tool. However, I recommend leaving it to default. Click Next to Continue.
On Ready to Install page, select Install.
The Stellar Converter for OST software installation is complete. Click Finish.
If you have already purchased the Stellar OST Converter, you can activate the product by clicking the Activation tab. In the Activation box, enter the product key and click Activate.
Convert OST to PST using Stellar OST Converter
Let’s look at the steps to convert OST to PST using Stellar OST Converter. When you launch the Stellar OST converter, you see some a box to select an OST file for conversion.
Click Browse button and select the OST file. You may also use the Find option, which takes a bit longer to find the OST files on your computer.
In the next step, click Convert. The software now runs and converts your OST file to PST file.
While most users aren’t aware of the OST file location, the Find option is really useful. When you click Find, the software searches OST files for you. Specify the search location as C:\ drive and click Find. In addition, ensure you enable the Search Subfolders option to search all the sub-folders within C:\ drive. The Stellar OST converter now looks for OST files under C:\ drive.
If there are multiple OST files, you should see all of them in the results pane. Select the OST file and click Convert. You can convert multiple OST files at once in Technician version.
The OST file is successfully converted to PST file. The time it takes to convert the files depends upon the size of OST files. In my case, the OST file was 50 MB and the Stellar converter completed its operation in 5 seconds.
Click OK on conversion completion window.
In the next step, click Save Converted File. Before you do this, remember to close the Outlook. In the save as window, select PST. To choose a different destination path, click Browse.
As of now Stellar OST Converter supports exporting OST file to below formats.
- PST
- MSG
- EML
- RTF
- HTML
In Technician version, there are more saving options like Microsoft 365, Live Exchange etc.
Import PST file in MS Outlook
In the above steps, we successfully converted OST file to PST file. Now, let’s see how to import PST file to Microsoft Outlook 2021 or 2019.
First launch Microsoft Outlook application on your computer. From File Menu, select Open & Export and click Import/Export.
From Import and Export Wizard window, select Import from another program or file, click Next.
Select Outlook Data File (.pst) and click Next.
Click Browse and locate the OST file. Click Next.
You may select specific folder to import to your outlook or complete PST file. Click Finish.
Thank you for sharing the helpful review, After read your depth research on the Stellar, I could make my mind to check the demo version, and then I had purchased the licence to convert my entire mailbox data in the PST format.
