Discover SCCM Upgrade Paths
In this post I will list In-place upgrade paths for almost every major release of SCCM. Using the upgrade paths info you can find out if you can upgrade your SCCM to current branch release.
With the release of new SCCM versions, a lot of customers are looking to upgrade their configuration manager environment. Especially upgrade SCCM 2012 R2 to current branch releases.
When you plan to upgrade Configuration Manager, you must know the available upgrade paths. There are many versions of SCCM released till date. Here is a post that lists the build numbers for SCCM and Tech Preview versions. To find out the current branch build numbers, click here.
This post lists the upgrade paths for configuration manager. Before you upgrade it is recommended to check supported configurations for SCCM and upgrade checklist.
SCCM In-place Upgrade Paths
Let’s now look at in-place upgrade paths available for SCCM.
Upgrade paths to SCCM Version 1511
If you are planning to upgrade your configuration manager environment to version 1511, the below table helps you. Most of all to upgrade you need version 1511 baseline media.
After you install a baseline version, additional versions of SCCM are available as in-console updates.
Upgrade FromIn-place Upgrade to Version 1511
System Center Configuration Manager RC InstallSupported
System Center 2012 Configuration Manager with SP1Supported
System Center 2012 Configuration Manager with SP2Supported
System Center 2012 R2 Configuration ManagerSupported
System Center 2012 R2 Configuration Manager with SP1Supported
System Center Configuration Manager version 1511 (Eval)Supported
Upgrade paths to SCCM Version 1606
The below table lists the In-place upgrade paths to Version 1606 of Configuration Manager. In addition, you need baseline media for version 1606 to upgrade. There were 2 versions of baseline media released for SCCM 1606.
One on December 15th, 2016 and other one prior to it. I would recommend you to download the baseline version released on December 15th, 2016.
The table shows the upgrade paths assuming you have downloaded latest version of baseline media.
Upgrade FromIn-place Upgrade to Version 1606
System Center Configuration Manager version 1606 (Eval)Supported
Upgrade paths to SCCM Version 1702
The below table lists the upgrade paths to version 1702 of SCCM.
Upgrade FromIn-place Upgrade to Version 1702
System Center Configuration Manager version 1702 (Eval)Supported
Upgrade paths to SCCM Version 1802
The below table lists the upgrade paths to version 1802 of SCCM.
Upgrade FromIn-place Upgrade to Version 1802
System Center Configuration Manager version 1802 (Eval)Supported
Upgrade paths to SCCM Version 1902
The below table lists the upgrade paths to version 1902 of SCCM.
Upgrade FromIn-place Upgrade to Version 1902
System Center Configuration Manager version 1902 (Eval)Supported
You might also like
14
avatar
5 Comment threads
9 Thread replies
0 Followers
Most reacted comment
Hottest comment thread
newest oldest most voted
Shaaz
Guest
Shaaz
How do I upgrade 2012 R2 to 1902. I tried 1902 manual upgrade however the prereq fails with error LinkID 722800.
I do not see any option to download versions prior to 1902 in Volume Center or Evaluation sites. Please advise.
Davide
Guest
Davide
thanks for all the material You have on internet about SCCM , sharing Your knowledge, make SCCM administrators very confident on that complicated Microsoft product! A question about the upgrade to CB 1802… My supported scenario is SCCM2012R2 Sp1 -> SCCM CB 1802 . Talking with customers , everytime I suggest a Side-by-Side migration … May I ask Your point of view?
Davide
Roseanna McDonald
Guest
Roseanna McDonald
Hi Prajwal, thank you so much for all your help, my upgrade to 1702 has gone very well, and I now have secondary server instated, however the DRS replication never occurs and stays at Initializing connection, when I use the link analyzer it tells me the following Connection failure detected between NAMED PRIMARY and the SQL Server NAMED SECONDARY CONFIGMGRSEC. Check network and firewall settings between these computers. It may take several minutes for firewall changes to take effect. Connection failure message: Failed to get SQ: Connection to NAMED SECONDARYCONFIGMGRSEC.(db instance running on sql express on secondary server) In this… Read more »
Roseanna McDonald
Guest
Roseanna McDonald
Hi there Prajwal, always enjoy your SCCM videos and work since Ive been working with SCCM, just wondering if you can advise f it is possible t upgrade from SCCM 2012 R2 directley to 1702
MANUEL CASTRO
Guest
MANUEL CASTRO
If I have version 5.0.7958.1604 System Center 2012 r2 can I upgrade to version 1606 base?
If so, how do I do it? Because in Administration / overview / cloud Services I do not see the update and servicing option
Roseanna McDonald
Guest
Roseanna McDonald
Did yo manage to get sorted with this, I am planning similar upgrade , but with me will be to 1702 as that’s the media now that MS have available
